Question about Sony PSP (Piano Black)
Graphing linear equalition x-8 _> 7 - Sony PSP (Piano Black)
  • 75 Answers
One of my friend got this problem once and he gets fix by using repair guide.......... you too use this repair guide and fix your problem by your own..........
click here to download repair guide........--------------------
Posted on Oct 05, 2010
The equation of the straight line PQ is 3-2kx+k+1=12,calculate,in each case,the numerical value of k if the line PQ is parrallel to the line y=4x+7;is perpendicular to the line y=4x+7;
that sounds like a problem about "slopes" so I am looking at using the derivative, which is basically the slope of the graph.
- the equation of line PQ can be simplified to y(x) = -2kx + k -8
- derivative relative to X (k is a constant) gives you -2k
- derivative of y(x) = 4x + 7 relative to x gives you 4
if the lines are parallel then the slopes are equal:
-2k=4 gives you k = -2 => your function becomes y = 4x - 8
if the lines are perpendicular the two slopes multiplied together give you -1:
-2k * 4 = -1 gives you k=1/8 => function becomes y = -1/4x - 7/8 or in other words y = -(2x+7)/8
I have made graphic representation and it looks to be correct.
I hope it makes sense.
Apr 12, 2017 | Homework
How to find the arithmectic or geometric for this Q. -2/5+(-3/20)+1/10+7/20+...+8/5
Input: -2/5-3/20+1/10+7/20+X+8/5
Result: X+3/2
Geometric Figure: Line
Alternate form: 1/2 (2X+3)
Oct 24, 2012 | mathway.com
Non linear graphs
All graphs, except the linear function y=ax+b, are non-linear. To graph a function, just enter the GRAPH utility, type in the functions Y1=, Y2=, ... and press the Draw tab.
If you have a specific question, ask it.
Mar 26, 2012 | Casio FX-9860G Graphic Calculator
How to use ti 84 plus calculator to graph linear equations
You have to use Y Editor to define functions on the both sides of the equation and then graph it. Finally option is F5: Intersection.
See captured images for equation 5x+10=-2x-7, y1=5x+10, y2=-2x-7 and x=-17/7
Feb 25, 2012 | Texas Instruments TI-89 Calculator
Linear graphing on the TI-nspire
Turn Calculator ON.
In scratchpad, add a Graph.
After you press enter to graph the function you will not see anything because the y-intercept is at ordinate 254.47. To see anything you need to zoom out.
You will be prompted for the Center of new graph. Move cursor along the y-axis, upward. After a while you will see the graph.
You can also, and it is quicker, to set the graph window
Set the values as on the screen capture
Here is what you see
Enjoy.
Jan 07, 2012 | Office Equipment & Supplies
I am trying to graph a least-squares line on my TI-84 Plus. I have the numbers correctly plugged into my Stat Edit tables, and I am able to access my linear equation, and the first time I entered my graph...
After you enter the data draw the SCATTER plot first.
When you perform the (linear) regression analysis LineReg, save the regression equation to a function, for example Y1
The syntax is
LineReg L1, L2, Y1 ENTER
From the Stat>CALC menu press LineReg
The command echoes on command line
Press [2nd][1] to enter the L1 list on command line
Press [,] to separate
Press [2nd] [2] to enter L2 on the command line
Press [,] the comma again
Press [VARS][>][Y-Vars][1~Function][1:Y1] [ENTER]
Press [GRAPH] to have the regression line equation drawn
on the same screen as the Scatter Plot you drew before.
Sep 13, 2011 | Texas Instruments TI-84 Plus Calculator
How do u store linreg(ax+b)as y1 on ur graphic calculater
When you press [STAT] and right Arrow to highlight CALC you see two linear regression model [4:LinReg(ax+b)] and [8:LinReg(a +bx)]
If you select [4: ...] the command echoes on main calculator screen as LinReg(ax+b) and a blinking cursor
If you press [ENTER] you will get your equation, a, b, and r^2 if DiagnosticsOn command has been executed before. However you will not be able to see the line of best fit on top of the raw data scatter plot.
To save the equation of best fit in a function variable, ex Y1, you complete the command as follows
LinReg(ax+b) [VARS][=>][Y-VARS][1:Function][1:Y1]
The Y1 variable will appear on main calculator screen, and you have
LinReg(ax+b) Y1
Press [ENTER]
Screen display the equation, its parameter and its correlation coefficients (if so configured).
Press [GRAPH] to draw the line of best fit on top of the scatter plot.
Here are two screen captures to show you the equation and the line of best fit.
As you can see from the value of r^2, and the graph, a linear regression does not seem good.
Feb 01, 2010 | Texas Instruments TI-84 Plus Calculator
How do i calculate limits on my Casio fx-115es? Ex. lim x->3 for (x2'-0)/x-3
Sorry, but you cannot calculate limits of functions with this calculator. It does not have a Computer `Algebra System (CAS). For that you need a graphing calculator with CAS: Casio ClassPad 300, 300PLUS, 330, HP 48 GII, HP49 G/ G+, HP 50G, TI-NSPIRE CAS, TI89 Titanium, TI 92/92PLUS, TI Voyage 200 PLT. It is still a very good scientific (non graphing) calculator
However, you can calculate numerical derivatives, and numerical integrals, solve linear and non-linear equations.
Even though this post does meet your expectations, do not let that prevent you from rating it.
Jan 21, 2010 | Casio FX-115ES Scientific Calculator
Functions?
I am afraid I am missing something here. You can start with the expression of a function and have it graphed on a graphing calculator.
Or you can enter the experimental data, represent them on a graphing calculator and ask the calculator to find the curve that fits the data best, and once that curve is found to give you the equation.
However your calculator does not have the graphing capabilities. All you can do is enter the data and ask the calculator to perform a regression to obtain the expression of the function that fits best.
The available options for the calculator are accessible by pressing [MODE][3:Stat] and
2. A+BX linear
3: _+cX^2 quadratic
4: ln X logarithmic
5: e^X exponential
6:A*B^X power
7: A*X^B Polynomial
8: 1/X
Hope it helps.
Apr 14, 2009 | Casio fx-300ES Calculator
Sony PSP (Piano Black) Logo
77 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
