Question about Pentax Optio A10 Digital Camera
"memory card error" Tried a new card but it did not work.
    Brigadier General:
  • 3,006 Answers
First check that you are using an SD card with a capacity which does not exceed 2GB as that is the maximum your camera can handle and it will give error messages with larger capacities, especially if you have fitted a later specification (incompatible) SDHC card.
If you need one, you may download a free user manual for your camera by clicking here.
If you are using the correct type and capacity of memory card then this is such a common question that I hope you don't mind if I paste my generic answer below. Note that cards may appear to be unlocked when they're not. The answer also covers what to do if the card is faulty.
Your camera uses SD memory cards. On one edge is a slider switch: towards the electrical contacts is the unlocked position and away from them is locked.
Unfortunately, the switch is easy to move accidentally and it's also easy for it to appear to be unlocked when it isn't. Like any mechanical component it's also possible for the switch to fail.
If the switch is in the locked position then slide it fully to the unlocked position; if it's already in the unlocked position, slide it fully to the locked position and then fully back again. There should be a soft click at each end of the switch travel, if not then the switch is definitely faulty or obstructed.
If that fails, then try looking closely at the switch in both positions to ensure that there is no debris obstructing its movement, if not then check the electrical contacts to ensure that they're completely clean and grease-free. Don't touch the contacts with your bare skin, but if the contacts need cleaning then a cotton bud (Q-tip) moistened with a little alcohol or methylated spirits can be used to clean them.
If you still have no fix, then try a different SD card as yours may have an irreparable faulty switch. If the card does prove to be faulty then on most major brands you may be able to return them to the manufacturer for exchange: I've found that they will often do this on a goodwill basis even if the card is out of warranty. Just check the manufacturer's website for support details.
If all options regarding the memory card are unsuccessful, then you have a faulty camera and further remedies require either a professional repair or replacement of the camera.
I hope that my free answer has been of use and has given you options to fix your problem. Please let me know by taking a brief moment to rate my reply. If your problem has not been fixed, then please add a comment instead and I will suggest another solution for you.
Posted on Oct 05, 2010
My camera Canon sd 940 shows an error memory card error and card lock, how to fix it?
Have you tried unlocking the card with the small slider switch on the side of the card
Feb 15, 2015 | Canon Cameras
Memory card error
Make sure you're using SD cards. If the cards are larger than 2GB then they're actually SDHC cards. While they fit in the slot they are electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
Aug 05, 2012 | Pentax Optio MX Digital Camera
Memory card error message
Cards are coming in different formats and it might be possible that you brought a card which is not suitable or functional with your camera. The other reason could be that we are having options to lock our memory card in digital camera and you might have taken out your earlier card without unlocking it. The system might be broken from inside and this could be a reason that you are still getting a message that memory card is locked. It seems possible based on problem you are sharing.
May 28, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
Lumix DMC-TZ1 Memory Card Error
Try formatting the new card in the camera. Also, download any pics from the old card using a card reader and then, format it in the camera.
Apr 16, 2010 | Panasonic Lumix DMC-TZ1 Digital Camera
Card error
Buy and format a new memory card
Sep 12, 2017 | Samsung Cameras
Card Initialize Error
What size is the original card? I don't think it is your camera, possibly the size of the new card.
Aug 03, 2008 | Fuji FinePix A340 Digital Camera
Memory card
Unfortunately, the A520 does not support SD memory cards with more than 2GB capacity, and doesn't support SDHC at all. (1GB max for MMC cards.) I know memory is much cheaper than when the camera first came out, but in 2005 2GB was about as large as you could get.
Jul 20, 2008 | Canon PowerShot A520 Digital Camera
Memory card error
Try a smaller memory card size . I was trying to install a 4gb card and the guy at Kmart told me to try a 1gb card and that fixed the locked card error . No where in the instruction book did it address this problem.
Sep 24, 2007 | Canon PowerShot A530 Digital Camera
Error 10 message
The error 10 message is trying to tell you that the new memory card you have tried to put in is not compatable with your camera. AS you have already tried turning it off/on, replacing batteries etc, you can try taking all cards out, and attempt to get it to fuction correctly with original cmaera memory. After taking out all cards, and with a fully new set of batteries in, use your cameras menu to format the camera memory. Now try and take photos with just normal memory. Is it working? If it does, and error is gone, put in old memory card and reformat it. Does camera pick it up and recognise it. Can you now use it. The new card you tried to install may have been an incompatable brand. Check your manual for approved brands or your local dealer. The card could also be faulty.
Aug 08, 2007 | Nikon Coolpix 4600 Digital Camera
Pentax Optio A10 Digital Camera Logo
88 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
