Question about RCA Televison & Video
Rca L46WD22 will not turn on red light flashes 5 times we have unp[lugged it time and time again each time u plug it back in the screen flashes briefly then goes black the green power light turns red and flashes five times
davebies
  • 43 Answers
SOURCE: Sony KDF-E55A20 55 in. LCD... Problem red light flashes 5 times
A 5 blink error indicates a bad lamp driver. However a lamp may possibly cause this too. I suggest putting a new lamp in if you have one just to verify the lamp is not the problem. If it still fails with a new lamp then the lamp driver is the problem. This part should be replaced by a Sony authorized servicer. The lamp can be replaced easily by you. The lamp replacement instructions are in the TV's owners manual. Good Luck
Posted on Jan 06, 2008
  • 718 Answers
SOURCE: TV was playing, then the screen turned black.
If the screen is black and you have sound then lightly press and shine a strong flashlight against the screen. If you see an image around the edge of the flashlight, an image is being 'displayed'. The problem is probably in the Inverter/CCFT or the power going to the Inverter.
Posted on Feb 24, 2009
welcomejee
  • 10594 Answers
SOURCE: Sony Bravia kdl-46S3000 flashing red lights
Sounds Lamp is weak in this TV.
Please replace lamp and procedure is written in TV user manual.
Posted on Mar 14, 2009
roety
  • 585 Answers
SOURCE: MAGNAVOX 32MF605W/17
Hi my name is Eric,
I hope I can help you with your issue ,
 You main a bad mainboard, a repairman will charge about $450 to replace it , use google to try and locate one yourself
If I have helped you with your issue please click accept.
If you have more questions you can still respond
I will reply asap
Thanks
Eric
Posted on Sep 26, 2009
SOURCE: RCA L46WD22 firmware
I have same problem, any solution?
Posted on Nov 10, 2009
Rca tv L46WD22 and green light followed by 5 red flashing lights
These blinks (Flashes) are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check these link s
http://electro-medical.blogspot.com/
Dec 13, 2013 | RCA L46WD22 Television
Tip
How to fix your gas furnice
most gas furneses have a red light on circuit board wich is located on intake. turn heater off then have someone turn it back on while you watch the circuit board. count the # of times the red light flashes before it pauses. it will flash in a cycle. for instance it flashe 3 times then pauses for 5 secounds then flashes 3 times again on and on. look on the back of the panel cover,their will be a diagram, in the diagram their will be dianostic report that will include what that # of flashing red light and what it means. for examle 3 flashing red lights ps stuck open. that means pressure switch stuck open. replace the part and your back up and running.
on Dec 18, 2009 | Heating & Cooling
Sony kds-60a2000 power light flashes 5 times, no picture
5 flashes - Lamp Driver - (lamp driver faulty)
This is the error code that usually means the ballast (it is the power supply for the lamp) is bad.
SD TECH
Apr 20, 2012 | Sony KDS-60A2000 60" HDTV
I have a SONY KF-WE50 rear projection tv, a few weeks ago it started to turn the pic and sound off while the green light was flashing around 30 times. After the light finished flashing both the picture and...
the green is the reboot process and is normal.
the red light is an error code indicator.
count the blinks of the red light...it cant be 30 times (I think)
it will blink a sequence, pause, then do it again for a total of three times.
count carefully, it gives you three chances to catch the number it is blinking.
Apr 13, 2011 | Sony Televison & Video
It is a 46 inch lcd flat screen model l46wd22. It is 2 years old and this problem just happened this morning. Do you remember those old disco lights that flash really fast on and off? I get a clear picture...
It could be many things that cause this. Try all inputs IE: DVD, cable etc. If it is doing this on all inputs, try unplugging the TV for 2 minutes to allow for a reset and then power it back up again. If it is still doing the disco flashing time to call fro a service technician...
Nov 20, 2009 | RCA L46WD22 Television
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Tv turns off but will turn right back on
Service Manual of KV-32XBR400 shows error info regarding red light flash 2, 3, 4, 5, 6, & 7 times only. Each flash corresponds to different problem in TV. Please check red lighe flash count again.
Aug 10, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
RCA L46WD22 won't turn on after being off overnight
RCA are beautiful televisons, what is happening is that when the faulty fan that cools down the processor stops working, your processor over heats and a temperature gage inside reconizes this and shuts down the television. unlike some other models that i choose to remain nameless
*cough sony cough cough* where you need to replace the t.v,
RCA has a safty feature that allows the t.v to shut down with out it doing any harm. Ok folks, this is the easyest answer that i am going to ever give anyone.
All you need to do is Replace the FAN! that fan that cools down the processor to allow the fast movements to give the vibrant pictures in stunning accurate pixle compounds. it will cost about $50 for the fan and $200 for the guy/girl to install it.
So there you are a complex problem with a simple answer. you are one lucky person, you choose the right television the only factory defect was the fan. your t.v should last 15years without any serious problems.
I hope this has helped you folks. i am called the flat pannel Guru in my buisness.
Jun 16, 2008 | RCA L46WD22 Television
have you gotten any resolution on this yet?
Dec 23, 2007 | RCA L46WD22 Television
Televison & Video Logo
96 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
