Question about Behringer F-CONTROL AUDIO FCA202 External Sound System
My device does not show up on the computer screen, but blue Fw. light is indicating that everything is fine .. but no sign of the fca202 on the screen, as well as no Sound;/
I have the same exact problem and I've been looking everywhere with no luck.
Posted on Oct 22, 2010
What electrolytic capacitors need changing on a LG W2242S
Start with any which are showing any signs of doming or bulging and any near a source of heat. Use height temp replacements.
Jul 18, 2014 | LG Computers & Internet
I have a VG2245WM Monitor it has power and pc signal but very red
The caps can be bad with high ESR with no sign of bulging/leaking: http://s807.photobucket.com/albums/yy352/budm/Bad%20capacitors/
If you get pinkish glow and dimmed screen, it can be bad lamps: http://s807.photobucket.com/albums/yy352/budm/Bad%20backlight%20lamp/
I will still suspect the caps first. Check to see if you do have about 12~18vdc feeding the inverter circuits.
Jun 03, 2010 | Computers & Internet
Will not come on only the blue navigator button light works
Try connecting it to your computer. Once here, go to My Computer, and right click on the device. Scout for "Format Device" or something similar. If you don't see it, scout around. Try opening the device and looking there. This deletes the device and resets everything.
Jun 07, 2009 | SanDisk Sansa e260 MP3 Player
Mitsubishi wd 52525 Problems, but no blinking lights.
Are you using an hdmi cord or av cables?
Apr 10, 2017 | Televison & Video
2009 map update not loading
Fixed. Called Garmin. It seems that version 4.90 FW on the Nuvi 350 (which came shipped on my 350) has a bug where it cannot communicate with the Garmin software either to update maps or update FW. Tech from Garmin e-mailed me a patch that I copied into the Garmin folder on the Nuvi itself, via USB and Windows Explorer. I then rebooted it; the patch installed itself which then allowed the unit to communicate with the map upgrade software and all is well. 2009 map update is now installed and the Nuvi is working fine again. Haven't tried upgrading to newer FW yet; will probably leave well enough alone.
Jul 01, 2008 | Garmin Nuvi 660 GPS Receiver
System freeze
Which driver are you using now that you have 'converted' firewire to USB? The USB driver or the Firewire driver. I suspect none would work, as the Firewire driver os looking on the FW bus/layer, and the USB there. The devices may not communicate at all in the same way to either interface.
May 02, 2008 | Behringer F-CONTROL AUDIO FCA202 External...
WD-52725 TV loses picture while playing DVD but not sound
replace DM or try to fix it.
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
Jan 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Drive Being Recognized as Removable Disk
Same issue with my 500 GB TFD500U16. A little more description is that my PC is detecting the power when turning on the drive and the HDD itself is spinning up. Also the Blue light that normally indicates HDD activity by turning Red no longer shows activity but just stays Blue. This indicates that the data side of the HDD is not seated properly. Since mine is out of Warranty, I took it apart and found this to be the exact case.
! ! ! ! Please perform this at your own risk ! ! ! ! Especially if your warranty is still in effect! ! ! By loosening the HDD mounting screws inside that will allow the connection to seat properly and data to be seen.
Dec 16, 2007 | Fantom Titanium II (TFD500C16) 500 GB USB...
Behringer F-CONTROL AUDIO FCA202 External Sound System Logo
126 people viewed this question
Top Behringer Computers & Internet Experts
aftab Nawaz
aftab Nawaz
Mike
Are you a Behringer Computer and Internet Expert? Answer questions, earn points and help others
