Question about Electrical Supplies
I have just set up a new mains powered electric fence and i need to install a cut out switch but i wired it in the way i was told and the system dont work. what am i doin wrong
  • 2,100 Answers
Where are you checking the power at? The transformer? Or the fence wire itself? The power to the transformer is basic 110 volt, 15 or 20 amp circuit, need to be in a pipe or somewhat protected, , like through a wall. The transfomrer should be accessible, and can be switched by a light switch in a box. Your fence wire has to be a continuous run, no breaks, and make a complete circuit. It comes in different voltages, And will blow out a tester in a flash if it is on the wrong setting, so start with the high voltage and work your way down when testing. Some are just a tickle, some will knock you on your ****. So be careful. Make sure the breaker is on and good, and the plug is good if it has one. Also, it should hum or buzz when running. The horse will only have to touch it one time and he will never go near it again. Hope this helps.
Posted on Oct 05, 2010
How long does it take to charge battery in solar fence charger?
    1. A solar powered electric fence energizer usually contains a battery for energy storage. The solar panel collects the energy from the sun and charges the battery. Lead acid batteries, which are used in solar fence chargers, typically last around 3 years, or around 1,000 days of charging.
      About Fence Chargers - Zareba Systems
      www.zarebasystems.com/learning-center/all-about/fence-chargers
    Feedback
  1. About Fence Chargers - Zareba Systems
    A solar powered electric fence energizer usually contains a battery for energy storage. The solar panel collects the energy from the sun and charges the battery. Lead acid batteries, which are used in solar fence chargers, typically last around 3 years, or around 1,000 days of charging.‎What can I do to prevent ... - ‎What factors should I consider ...
    [PDF]Fence Controller Installation - Zareba Systems
Jan 01, 2016 | Cars & Trucks
Get a shock from the tap while showering
I assume by main power feed your talking about the breaker box? If so make sure the breaker box is actually grounded. Also check inside the heater and make sure the ground wire in there is connected and has a solid connection.
Feb 17, 2014 | Rinnai Water Heaters
All the power in electric fense is coming out the earth wire, with minimal flow from the main check to see if the fense was earthed walk ed the length of fense and found no major earthing, switch the wires...
i think the fence charger is bad and a safety mechanism has caused all voltage to go to ground. it could be putting out the voltage and be able carry current also which would be a deadly mixture. which is definitely not being a tight wad over. losing one cow over doesn't seem to be worth it either Indent" class="redactor_btn redactor_btn_indent" tabindex="-1">
Jun 29, 2017 | Electrical Supplies
How do you wire in a kill switch
just eliminate and cut off the wire to the existing kill switch the put any kill switch you want on it and take the main electrical lead to the ignition or what ever it is and put the new kill switch in the middle of the new kill switch you installed I did it before it always works just make sure to eliminate the old kill switch and its connections are no longer needed
Oct 30, 2012 | Coleman Electrical Supplies
Xerox 4150 workcenter says fuser module needs to warm up. This appears usually first thing in morning. I have to power off then on to stop this from showing on the screen. also, it wont print until after I...
1. Switch off the machine, then switch on the machine.
2. Enter dC330 code 10-100 to heat the fuser to 180 degrees. Enter codes 10-200 (centre
thermistor) and 10-210 (front thermistor) to verify the condition of the thermistors.
3. Enter code 10-300 to check power supply unit 2. If necessary, install a new power supply
unit 2, PL 1.10 Item 4.
4. Switch off the machine. Remove the fuser assembly. Check that the thermistors, PL 10.25
Item 9 are clean and in good contact with the fuser heat roller. Check the wiring to the
thermistors. Install new components as necessary, PL 10.25.
5. Check for continuity between the two pins on the fuser assembly connector, PL 10.25
Item 8.
NOTE: A cold fuser has a resistance of approximately 11.5 ohms (220V/240V) or 2 ohms
(110V).
6. Check that there is continuity through the fuser heater and across the over temperature
cut-out.
7. Check the wiring between the fuser connector, PL 4.15 Item 20 and CON3, CON8 and
CON9 on Power Supply Unit 2. If necessary, install a new fuser connector, PL 4.15 Item
20.
8. Check the wiring between CON4 on Power Supply Unit 2 and CN7 on the Main PWB.
9. Install new components as necessary:
• Fuser assembly, PL 10.25 Item 1.
• HVPS, PL 1.10 Item 2.
10. Perform the OF5 Main PWB Check RAP.
4250/4260 Checkout
NOTE: The main PWB has test points. The location of the test points is shown on the Main
PWB PJ location illustration.
Refer to Wiring Diagram 17, Wiring Diagram 18 and Wiring Diagram 21. Perform the following:
unit 2, PL 1.15 Item 4.
4. Switch off the machine. Remove the fuser assembly. Check that the thermistors, PL 10.28
thermistor assembly. Check the wiring to the NC thermistor, PL 10.28 Item 19. Install new
components as necessary, PL 10.28.
5. Check for continuity between the three pins on the fuser assembly connector, PL 10.28
Item 8.
(110V).
6. Check that there is continuity through the fuser heat lamps and across the over temperature
cut-out. Install new components as necessary, PL 10.28.
7. Check the wiring between the fuser connector, PL 4.15 Item 20 and CN5 on the Main
PWB. If necessary, install a new fuser connector, PL 4.15 Item 20.
8. Check the wiring between CON1 on Power Supply Unit 2 and CN7 on the Main PWB.
• Fuser assembly, PL 10.28 Item 1.
• Power supply unit 2, PL 1.15 Item 4.
May 10, 2012 | Xerox WorkCenter 4150 Black and White...
C lightening hit my mark 7 fence charger is it worth repairing
If lightning hit the unit itself then it more then likely destroyed any electrical components inside the unit. I would say get a new one and dont even bother repairing it.
Apr 16, 2011 | Parmak Solar Fence Charger
I have a promble,i want my ligths to have a switch,but i dont now how to connect the wires from the switch
This is difficult to answer, as you did not mention what you are working on. So, I presume house lights and 110 volts.
TURN OFF THE POWER. There should be three wires going to the light, black, white, and ground.
The black wire is the power wire and it is what gets cut and the switch installed to connect the cut black wire.
If you have any question, get an electrician to do this, as electrocution exposure is what you risk.
Apr 06, 2011 | Electric Garden
Cd play wires have been cut and dont know what the wires are?
one thing I learned as an electrician is to never expect a certain colored wire to mean anything specific. If you do not have an electric circuit tester get one and I'll explain to you what to do. First lets just say you're installing a basic standard cd player with 2 front channels and 2 rear channel outputs, and the factory system had 2 front and rear channels your wires are already in place and you don't need to run any new wires. Your new cd player's wires should be marked or you have an installation guide telling you what each wire does now you need to identify the vehicles wiring. You vehicle will have a ground wire, an antenna jack, a power wire that is constantly powered for the memory/clock, a power wire that is hot when the key is on to operate the player and 4 sets of speakers wire a positive and negative lead. Use your circuit tester to identify both power wires. Install your ground wire first or you risk shorting out or blowing the inline fuse if there is one on the main power wire to the player, next your antenna, then your main power, followed by the constantly powered wire for the memory. At this point your radio when turned on should light up, you can look in the trunk and identify both of the rear speaker wires to save you some time, you can figure out the front 2 after the rear speakers are installed by turning the fader to the front and connecting your cd players speaker wires to them there is a 50/50 shot so if you need to correct it. I would always recommend soldering wires together and using shrink tubing to shield them. Wires that are just twisted together or crimp connected can come loose and cause arcing from a poor connection which creates excessive heat and could potentially burn up your wiring or short out the radio or other vehicle components. good luck with your installation
Mar 05, 2011 | 1995 Lincoln Town Car
New table saw, timber runninig off away from guide, saw blade running its own line,do i need to reset the guide.
The guide is called a fence. The fence should be positioned to the right of the blade. When using the fence, the largest part of the board goes between the blade and fence. Fences are typically have some relief toward the end, so you don't get the blade cutting on it's way down, and then cutting again on it's way up.
Apr 22, 2010 | Craftsman 10" Table Saw
Brake lights???
cut the wires use the wire connector and reconnect to each other its a simple walmart has a set for 10 bucks to do this and put electrical tape around the wiring 2 seperate wire 2 seperate connectors/ Please rate my response thank you very much
Jan 16, 2009 | 2000 Chevrolet Tahoe
Electrical Supplies Logo
75 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
