Question about Gevalia 50041 / 50443 Coffee Maker
My gevalia suddenly stopped working-the water does not heat up and just sits in its cavity--it's not filtering through to the pot-what should i do?--thx!
5 Suggested Answers
  • 82 Answers
SOURCE: I fill the pot with water and push the power
Have you tried cleaning with vinegar, lime buildup can cause the water to stop drawing.
Posted on Jun 19, 2009
  • 93 Answers
SOURCE: coffee maker stoped working
  • Make sure the power supply is all rite (if not try with different socket)
  • If your able to seee light..then try re-programme it using buttons.
  • Still if you face same issue ..i request you to call technician.dont try any thing,Give it to safe hands
  • Thanks
  • Posted on Jul 22, 2009
    • 30 Answers
    SOURCE: The water and coffee grinds sits in the filter,
    Most modern coffee pots have a feature in them to keep you from spilling coffee all over the place when you want to take a cup of coffee before they finish brewing. It sounds like you are having some issues with yours.
    Basically, the way they work is that there is some sort of gasket (rubber disk) that has a lever/spring mechanism that plugs the way out of the filter basket when there isn't a coffee pot under the filter basket. They are designed so that the lid of the coffee pot pushes up on part of the mechanism and forcing the little gasket open. (You can generally figure it out pretty easily by fiddling with it.) It sounds like you may not be assembling the lid on the pot completely (this model has a lid where the dome sticks up) or may be missing the lid all together. It's also possible that a piece of packing material may be clogging this or the gasket could be stuck shut, maybe with dried coffee.
    One sign that the assembly is working properly is there is just a little bit of resistance (not very noticable) when you first start putting to pot in place and it makes a clicking/thunking noise when the pot fully seats.
    Posted on Sep 18, 2009
    kel1guy2002
    • 3740 Answers
    SOURCE: Our office has a Gevalia Deluxe coffeemaker. It
    Most likely the cycle thermostat that turns off the heating element has failed. It is supposed to reset after the it senses the water temp below 130 deg. If it did not reset or has failed it will not turn on the heating element but the clock will work fine.
    By the time you ship the unit to a repair center with parts and labor and get it returned to you the cost would be as much as a new unit.
    Thanks for using FixYa.
    Kelly
    Posted on May 13, 2010
    Testimonial: "Thank you."
    Gevalia 12 cup coffee maker slow brewing
    The pipes are blocked with build up scale or water dirt. You can try to descale the machine by adding in the water half cup of lemon juice and brew it without coffee leave if for 20 min and the clean it by brew it with fresh water these will make a diference then try this again in a week.
    May 16, 2012 | Gevalia CM-500 12 Cup Coffee Maker
    No pot or instructions, how much water do you put in the coffee pot?Need a replacement pot for vp17 series. thank you
    You should be able to pick up a replacement/new pot at your nearest Restaurant Supply store. Make sure you get a 64 oz./ 1/2 gallon pot.
    Before plugging in your brewer, unscrew the sprayhead located just above where the filter basket sits and replace the basket, pour 3 pots of cold water through the opening on the top if the brewer is empty. This brewer has a reservoir that holds about 2 1/2 pots of water at brewing temperature when heated. Make sure you put an empty pot under the filter basket after pouring in the water. Water will flow from the brew basket when the reservoir has reached its capacity. Once water flows you can then plug in and energize your brewer and replace the sprayhead. It will take about 15 to 20 minutes for the brewer to reach brew temp, you will hear the heating stop. Put an empty filter and a dose of coffee (I recommend starting with a heaping measuring cup of drip ground coffee) into the filter basket, lightly shake it level, replace the basket and pour through 1 full pot of COLD water in the top. For best results pour the brewed coffee into a pre-heated thermal server if you plan on holding the coffee for more than 10 minutes or so.
    Enjoy!
    Jan 04, 2011 | Bunn VP17-1 Coffee Maker
    The glass coffee pot is broken on the xcc 12 model -- where can I find an economical glass pot replacement. I have the metal frame
    Gevalia does not make coffee pots. The last one I had came from Melitta but with Gevalia's name on it. I got my replacement pot from Melitta. I would not suggest that road - way too expensive. Check Walmart or Target for a Melitta replacement.
    Nov 24, 2010 | Gevalia 35411 / 50433 Coffee Maker
    It only makes 1/2 pot when I pour the water in after sitting over night some times it takes 2 pot of water or more to make a full pot
    I recommend slowly pouring in about a half a pot of cold water without coffee in the filter basket 5 or so minutes before you brew in the morning. There are 2 good reasons to do this-
    1. Overnight you are having some evaporation due to the fact that your Bunn brewer has a reservoir that keeps a couple of pots worth of water at brewing temperature... a better temp than most "home" model brewers. This will top off the reservoir and you will not "short pot" except for the amount that the grounds themselves hold back.
    2. Also overnight, due to the fact that the water is kept hot, the oxygen can dissipate from the water in the tank. Topping off with fresh water will mean a fresher first pot.
    The Bunn brewers have a low wattage/keep warm heater so the actual heating element isn't doing all of the work over those long periods... it only kicks on when the temperature in the reservoir drops considerably (like after brewing). Be sure to let the brewer heat back up before brewing (you will hear it stop heating)
    Hope this helps.
    Oct 28, 2010 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
    Kelly
    May 13, 2010 | Gevalia CM-500 12 Cup Coffee Maker
    Coffee maker stoped working
  • Thanks
  • Jul 22, 2009 | Gevalia 50041 / 50443 Coffee Maker
    It won't stop beeping. I've unplugged it for hours to reset the clock, but it still keep beeping. I've cleaning it, I've smacked it. It won't stop beeping.
    Hello dmtdds,
    This should be an easy fix. Inside the top of most Cuisinarts there is a water filter stick. Usually in one of the corners. Pull it out and remove the clogged carbon filter. Clean out the debris in the bottom of the cavity. Replace the filter stick into the cavity. (You can buy new filters on Amazon inexpensively, they should be replaced every 60 days.) Flush your unit with 2 parts water and 1 part vinegar, then rinse with a pot of fresh water. The beeping should stop and you should be good to go.
    Hope this helps you. Good luck! Positive feedback appreciated. NormanZ
    Jul 11, 2009 | Cuisinart DGB-500 Coffee Maker
    Gevalia xcc-12
    clean with limeout, or coffee maker cleaner, I used about 1/2 cup liquid limeout 2 cups water, run through bout 2 times, be sure to run several pots water through after cleaning,
    Apr 25, 2009 | Gevalia 50041 / 50443 Coffee Maker
    Gevalia CM500 filter basket
    II have a new a white filter basket for sale for this pot contact me at elfnts@juno.com
    Dec 22, 2008 | Gevalia CM-500 12 Cup Coffee Maker
    Gevalia CM-500 12 cup problem.
    Underneath the hot pad that the carafe sits on, there are two thermal fuses that are inside tubes that are clamped to the heating element with spring clamps.
    Remove the bottom of the unit (5 screws), unclamp the thermal fuse tubes, slide the tubes to one side and check the each fuse with an ohmmeter. If one of them is open, that's your problem.
    Aug 30, 2008 | Gevalia CM-500 12 Cup Coffee Maker
    Gevalia 50041 / 50443 Coffee Maker Logo
    181 people viewed this question
    Top Gevalia Coffee Makers & Espresso Machines Experts
    Henry  Thomas
    Henry Thomas
    ka4iup
    ka4iup
    Are you a Gevalia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
