Question about Sanyo PLV 70 Multimedia Projector
Sanyo plv70 projector
Projector turns on but doesnt lite goes straight to cooling fan
  • Anonymous Apr 09, 2009
    I have the same issue, when it first came up I shipped it back to sanyo and they replaced the Ballast ($300 later) and now again I am ahving the same problem and am looking for the ballast part so I can repalce it myself and save soem cash...
  • 563 Answers
Hi Mykoolg
Take out the lamp and check for any discolouration , vein like looking markings in either white or black on the lamp itself.
I'm sure you'll find the lamp to be the problem here.
Posted on May 28, 2008
Why is my sanyo plv wf20 projector shutting down after I turn it on.
The fan may be out that keeps the bulb cool. The shutdown is to protect the lamp from overheating. Do you have any flashing indicator lights on the projector after turning it on?
-GWOOD
Jul 12, 2014 | Sanyo PLV-WF20 Projector
Sanyo PLC XU50 Projector turns on and works for a few seconds then the fan comes on at a higher speed and the projector goes to stand by. Any ideas?
The cooling channel is likely clogged by lint and dust. We usually suggest annual cleaning and maintenance to avoid these kinds of issues. It is also possible that the fans have failed. Feel free to contact me at david@digitronelectronics.com if you would like to hav e a technician take a look. Projector Repair Bulb Replacement
Jan 20, 2014 | Office Equipment & Supplies
Loud fan sanyo xm150
You may need to replace the cooling fan. Sometimes the fan will turn but not as fast as it should, causing over heat on the unit.
Oct 09, 2012 | Sanyo PLC-XM150L LCD Projector
Sanyo pcl-xu50 flashing red power light when i turn on my projector the light goes green it powers up for about 20 seconds then the power light changes to a red flashing one for about 10 seconds then back...
Projectors shut off when they overheat. They overheat when air does not move through the projector cooling it. This happens when the fans are not working or air filters/vents are not working.
Check to see whether the fans are working. If they are working, open the cover and see whether air filters/vents are covered with dust. If so clean them.
Sep 26, 2011 | Office Equipment & Supplies
Sanyo Projector PLC XU83 lamp is replaced 1 everything is fine 2 projector turned on and reset the counter 3 projector switch off and normal 4 Next time imposible to power on the projector After ...
Check the cooling fans. If they are not rotating the Projector will not start.
Did the lamp explode? If it did a bit of glass has lodged in the cooling fan and stopped it from working.
Hope this helps.
Nov 15, 2010 | Televison & Video
After five minutes of working properly, the Cine1000 projector goes dark and the ready lite goes out. The power lite stays lit. The lamp has 881 hours. I checked the menu and auto power selection is off....
The ambient temperature in the room is to high.
Try lowering the room temperature. If that doesn't work
get a small fan and place it near the projector to provide
extra cooling. The projector is running border line on
high temperature and just needs a little extra cooling.
The lamp reset...should only be used when you replace
the lamp..with a new one...The reset will start the clock
running on the number of hours the new bulb has used..
Jul 18, 2010 | ViewSonic Cine1000 Multimedia Projector
Lamp goes out after 10-15 seconds
Recently had a similar issue.
When I took the lamp out (Let it cool for awhile first), there was dust all over one side preventing air from the fans from cooling the lamp, so it shut itself off after getting too hot.
Apr 27, 2009 | Sanyo PLC XU48 Multimedia Projector
Toshiba TDP SC25 projector
The manual says it might be because the power went out when it was on. Just a note here, as projectors age they become more sensitive to power outages. When not in use turn off completely if you can. They have an on/off button.
Otherwise not sure but think you may need to replace the fan. Try cleaning it first but gently.
Jan 31, 2009 | Toshiba TDP-SC25U Multimedia Projector
Sanyo plv70 multimedia projector has yellow rectangle in centre
Either its dust on the mirrors, if so u need to clean then, there are 3 mirrors inside. Or one of the mirrors is bad, then u need to buy a new one. I would recomend you to NOT do that yourself, leave it to someone who knows how to to that.
Good luck
Nov 15, 2008 | Sanyo PLV 70 Multimedia Projector
LCD PROJECTOR GOES BLANK
Check the cooling fan/ air ducts - sounds like it's overheating and shutting off to prevent damage.
Mar 12, 2008 | Computers & Internet
Sanyo PLV 70 Multimedia Projector Logo
187 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
