Question about Sungale DVD-2026 DVD Player
Hi my audiosonic dvd player KM0001 just wont open, the red light is on but nothing happens, it wont even play the dvd. And if it dose open and start to play the dvd it will ramdonly stop and jam up. dose any one have a solution for me plaese?
AUDIOSONIC TV/DVD COMBO KM1412D I NEED THE CODE TO PLAY MULTIZONED DVDS PLEASE.
The danger in using DVD unlock codes is that they can invalidate your warranty, or if done incorrectly, "brick" the device. Essentially it's not legal to give out these codes.
Nonetheless, many people find unlock codes by googling the brand and model of their DVD.
Jul 18, 2008 | Televison & Video
TDV-98FB4 audiosonic portable dvd player picture
After some experimenting, I have found that the TDV-98FB4 player will play files from USB if they are encoded using MediaCoder and the video output is set to MPEG-4 inside an mp4 container, or if the video output is xvid inside an avi container.
Oct 21, 2013 | JC Whitney - Audiosonic 3-way Custom-fit...
Dvd is not playing on the player
hello,
you can solve this by opening the back cover of the player, first use a cotton bud to clean the lens,and observe a beam up red light from the lens when the player is power on, if the there is no red light from the lens, that is the lens could be bad or the ribbon cable used to contact the lens to the printed circuit board.
Replace if any is faulty.
Hope this will help...
May 24, 2010 | Samsung DVD-P191 DVD Player
Sylvania DV220SL8 won't play DVDs, DVD tray won't open
One simple solution is to unplug the unit for 30 seconds then plug it back in. Worked like a charm for me.
Jan 09, 2010 | Sylvania DV220SL8 DVD Player/VCR
I have a lasonic portable dvd player. When I plug
look for a switch to select DVD or Monitor or IN OUT
Dec 04, 2009 | Lasonic DVF-982 Portable DVD Player...
Cannot open dvd.
hey i have the same problem! did you manage to fix it? if can u contact me at mesheluvz@yahoo.com. thanks
Apr 17, 2009 | Televison & Video
Audiosonic DVD player no sound
Try using a diferent rf cables.I would suggest that red,white and yellow colour coded RF cable is still the best.(yellow for Pictuer,White for sound and red also for sound(surround).
had similar problem than i cahnge the cables and found out that it worked with that cable...
thanx,
FIJI
Jun 21, 2008 | Televison & Video
NOTHING WORKS ON DVD PLAYER
My daughters had the same problem, try replacing C411 (I think that was the number on the board), its a 10V 1000uf capacitor in what appears to be the 5V power supply section toward the right rear of the main board, that fixed it. On hers the capacitor was swelled up on the end. I checked it out of the circuit and the DVM I used only indicated it had about 500uf capacity.
Sep 05, 2007 | Memorex MVD2042 DVD Player
DVD tray won't open
Hi kjflynn06 let your DVD player stand for about 2 days then you plug it in back if that does not work call a tech could be a faulty power supply good luck.
Apr 25, 2007 | Cyberhome CH-DVD 300 DVD Player
Sungale DVD-2026 DVD Player Logo
35 people viewed this question
Top Sungale Televison & Video Experts
janman
Chris Baker
Chris Baker
Level 1 Expert
Are you a Sungale Televison and Video Expert? Answer questions, earn points and help others
