Question about Samsung Heating & Cooling
Ice forming on fins of Samsung Vivaldi split air conditioning unit
  • 105 Answers
SOURCE: air conditioner freezing up
Your unit is low on freon. Take the unit to a service facility & have it recharged & the leak repaired. Note that ice formation may normal if the outside temperature is below 45-50F. If you must use it in the meantime, leaving the unit on fan only will melt the ice much faster.
Posted on Jul 17, 2007
  • 5 Answers
SOURCE: blue ice air conditioning unit (portable) not heating erro message E8
Every co. has their own logic control and error codes , however in my knowledge it may be of :
1. motor connection
2. Defrost sensor error-chk condensor/ evap. coil
provide some more clue to explore option of trip.
Posted on Feb 01, 2008
  • 958 Answers
SOURCE: Ice on the coil fins of my Window AC unit......
set your unit to fan mode only, to thaw the ice, after the ice melts, look at your evaporator coil, see if its dirty, if its dirty, then you might just need a good cleaning. if the coil is clean, look at your thermostat setting. it should not be all the way cold. the compressor would run continously and it would freeze the coil. third, the refrigerant system could be partially clogged up or it lacks refrigerant. these problems initiate freezing of the coil.
Posted on Feb 19, 2008
  • 86 Answers
SOURCE: Supplier of Wireless Remote for Fujitsu Split Air Conditioner
why want to replace remote.no idea abt w.canada
Posted on Mar 17, 2008
crouchdash
  • 83 Answers
SOURCE: Recharge air condition
if little air is coming out there maybe a problem in the blower or filters. But if there is air and its not that cold or warm then its a refrigerant problem or the lack of.
A simple check for lack of refrigerant would be to look at the refrigerant pipes on your rooftop unit and see if its freezing.
Altghough you can charge the unit by yourself, I would suggest to have it done by technicians because you would need to know how much refrigerant to put in there; what's the correct pressure; system integrity. You'll get your money's worth since it would not just be recharging but also system check.
I hope this helps.
Posted on May 27, 2009
LS-1260HL split A/C. Why isn't it blowing at full speed in cool mode?
ice on indoor units can be from blocked evaporator fins / blocked filters
inspect the fins under the filter pads and if they look greasy and dirty have the indoor unit professionally cleaned as it is messy
Jan 23, 2016 | LG Heating & Cooling
Ice is forming on coil fins
Either your coil is dirty or filter is dirty. Worst case your low on freon which would make a coil freeze.But freon doesn't evaporate if your low there must be a slow leak.
May 19, 2010 | LG Heat cool Window Air Conditioner
I got a sam sung split A/C while switch on the
just check the gas pressure and gas pressure is ok,may be out door unite is blocked.do the high pressure service
Oct 17, 2009 | Samsung AS1293L Air Conditioner
1.5T Voltas Vetris window AC. Ice formation
I think the more likely problem is that the unit is slightly short of gas\ refrigerant, which is a common cause of icing up evaporator coils and this sound you describe. First check that the air filter is clean. Another cause could be the defrost sensor is faulty, but I would think not. Some ice isn't actually a bad thing, but quite common as long as it doesn't form over too much of the coil, or get too thick.
Aug 15, 2009 | LG Heat cool Window Air Conditioner
Coil and fins start ice up
The fins are dirty. They need to be washed every year or two with an acid based cleaner. They MUST be rinsed completely.
Jul 21, 2009 | Carrier 38CKC030 Air Conditioner
Split unit samsung
Have the freon checked, quickly. This condition can damage the compressor if you let it run like that.
Jul 22, 2008 | Samsung AS18A6RB Air Conditioner
Feb 18, 2008 | Carrier 52PQ307 Wall/Window Air...
LG LST243C-2
- Check your air filter at the indoor if clean.
- Check your evaporator fins if clean.
- Check if no icing in your evaporator and outdoor pipes.
- If your air filter and evaporator fins is clean and icing is present then your unit is under charge.
- When your indoor drips check your drain pipe if there are water comes out. If no water drain from your drain pipes then your drainage is restricted.
- Flush your drainage with water using your garden hose to flush out dirts from your drainage.
Jan 14, 2008 | LG LSC121PMA Split System Air Conditioner
Loud whistle noise kelvinator split KSR25F-01
It may be the small vent fan motor on the inside if the control panel. When the noise begins remove the panel and you may be able to catch it in the act.
Dec 27, 2007 | Carrier 36KCARMS Air Conditioner
Heating & Cooling Logo
82 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
