Question about Samsung 206BW Monitor
As I worked the monitor went out and no picture. I reboot several times, but no picture.Monitor is Samsung Syncmaster 206BW
  • 11,361 Answers
Look for bad caps first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 05, 2010
I rebooted my PC and now screen is darker and my colors are off
Check the contrast (darkness/lightness) on your Samsung LCD. There's a menu button on the monitor, press that and select contrast setting from the Menu.
Apr 29, 2010 | Samsung SyncMaster 932B LCD Monitor
My Samsung monitor 244T blinked several times and went black. A few days later I rebooted my computer and it blinked twice and went black. Now power light doesn't even go on. Help!
1).check your monitor cable and power cable.search google for how to check if you do not know...
2).change your RAM into another slot and check if u have 2 RAM interchange it and check..i prefer this must be the RAM problem..
normally when u insert any new RAM..sometimes it does not matches.. in this way the blinking can be happened...
3).disconnect all the cables of CD drive and DVD drive and any other except harddisk cables...and start the system with harddisk and without connecting the CD and DVD drive..
4).clean your processor cooling fan..search google for cleaning cooling fan..this makes the processor to reduce heat or apply cool paste to processor..
let me know that your computer monitor works fine with the above steps...."rate"
Feb 02, 2010 | Samsung SyncMaster 244T Monitor
No display on SyncMaster 920NW after reboot from power failure
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. Look in our monitor repair section for step by step repair guide for this model it should be the same power supply as the 930. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 22, 2009 | Samsung SyncMaster 920NW Monitor
SYNCMASTER BM SREEN WILL NOT ACTIVATE JUST A FLOATING SQUARE BOX SAYING NOT OPTIMUM MODE RECOMMENDED MODE+ 1280x1024 60hz analog
I tried the following options and neither worked. 1) Hitting the monitor buttons as stated only got me a "digital" message and then the monitor went black as usual. Never got to any menu options. 2) Going into Safe Mode and changing the monitor settings or downloading/installing the correct driver didn't stick once you went back to the normal startup.
I didn't have another monitor handy to swap out so I had to be a little more creative. The only solution that worked for me is re-booting (F8 during startup) into the mode "Enable VGA Mode". This allowed me to go into the normal desktop with a screen resolution of 800x600. I went online, found the driver, downloaded it to the desktop. Deleted the video driver (Device Manager), installed the downloaded version, rebooted and....no problems.
I have Windows XP. Hope that helps. :)
Jun 06, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
Window screen problem
I'm guessing you may need to download the proper software and drivers for this monitor. Have you always had this problem and now want to change it? Try this website: http://static.tigerdirect.com/pdf/samsung-206bw-manual.pdf
Jun 21, 2007 | Samsung SyncMaster 214T 21.3" LCD Monitor
Samsung 206BW Monitor Logo
111 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
