Question about Tomtom GO 510 GPS Receiver
Charging the Tom Tom - unit shuts off with car charger plugged in
Tom Tom 720 new user - connected to home dock for 2 hours (not sure if the unit should be on or off???)
Took Tom Tom out for a test naviagate = worked for about 90 minutes - very cool, then battery icon came on the screen, unit shut down. So I plugged in the car charger to the cig lighter and that worked, but it kept shutting down every 3 minutes and asking me if I wanted to connect to the computer when I turned it back on. I'm taking a 5-hour trip tomorrow and I do not know if my Tom Tom is charging, how much battery life is left, and if I have to keep tapping the blessed screen every 3 minutes. HELP! shutting down your Tom Tom Go 510 in 10, 9,8,7,5, seconds "message" on the screen, but it does not shut down, it shows a map for a couple of second and the message appears again
  • 4 more comments
  • purekarma321 Jul 16, 2008
    went on a long journey, tomtom battery showed empty and then it shut down. it is not recharging, please help!
  • disneytokyo Jul 31, 2008
    Tom Tom battery run low in five minutes after 2 hour battery charging.
  • Interiagal Sep 01, 2008
    I have the same problem - the Tomtom shuts down all the time when on a trip. Especially fustrating when in a congested area and not wanting to miss a turn. Is there a solution? Anybody know what causes it?
    Love the Tomtom except for this major problem.
  • Anonymous Sep 29, 2008
    When i plug my tom tom in my car cig sokcet....my tom tom does not say if itz charging... is it charging if the green LED is on ??????????
  • gary598 Nov 02, 2008
    I bought a brand new TT 720 last month and it shuts down approx every 4 min.
    The message comes up
    Tomtom is shutting down in (countdown from 15 seconds).
    I have it plugged into the car and the green light is on the TT case.
    Any ideas .... or it meets the bin.
  • Chrystin Pleasants Jul 31, 2012
    I bought a TomTom GoLive 1535 for these kinds of problems. So far, both Garmin and TomTom sell extremely expensive devices that are absolutely horrible.
Your rechargeable battery inside has a limited life and has to be replaced when this problem happens.
Posted on Oct 27, 2008
    Sergeant:
    Champion:
  • Tomtom Expert
  • 373 Answers
The shut down' problem is caused by a faulty 'USB' charger socket
Swap out the socket and make sure you resolder ALL 5 terminals and the 4 pcb clamps.
Only attempt this if your skilled enough. A botched repair will not work and cause more even fatal damage to the pcb.
Sorry if I just depressed you but that's what need to be done.
TomTom support lie and tell you its the navcore, NOT
I have carried out this repair myself and it did cure the problem.
Posted on May 15, 2009
My Tom Tom XL 325 wont hold a charge while left off
Hi, leaving the unit in the cradle exposed to the sun during hot days has been known to fry the battery causing loss of battery capacity. perhaps this could be your problem. I replaced the battery in my last GPS 4 times because of this before I analysed the problem. This will most likely be outlined in your user manual too. You might also compare the output capabilities between your blackberry and tomtom charger - it is entirely possible that you are starving the unit of a decent charge if the blackberry charger is not to the same current capacity as the tomtom charger.
Mar 19, 2010 | Tomtom One XL GPS Receiver
My tomtom will not turn on. I have had it plugged into the car charger for several hours. Help?
try a reset first, i will assume you cant do this, get a clip or pin switch off the unit and remove the sd card, then push the tool into the small reset hole underneath and hold for 15 seconds, then turn your unit back on and replace the sd card, it should then work if not it could be the battery has worn out as they are attached to the charger all the time when driving, hope this helps
Jan 02, 2010 | Tomtom ONE GPS Receiver
Battery not holding charge
hi dave_hanc93
you say its not holding a charge, but is it charging?
plug the charger in and make sure the light is on on the charger, then on the map screen, tap the screen where the satellites are. on that screen on the top right is the charge indicator. is it green and moving from left to right? if not, then its not charging.
try hooking it up to the home dock to your computer and check and see if its charging on the home dock.
let me know how you make out.
bill
Oct 08, 2009 | Tomtom GO 910 GPS Receiver
I have a go720 and it shuts off every 20 minuts it gives a warning first and if you see it you can cancle the shutdown. any sugestions on how to stop this.
If your device is on a USB DOCK and Computer it will shut down within 20minutes so it will give your tomtom optimal charge while on computer.
If your device is doing the same but on the USB car charger, there is a problem with the USB cable, its recognizing it as connection to a computer.
Best thing to do is try another car charger and see if that works.
Also make sure you don't use the home dock in the car.
Thanks
Pabz
Sep 24, 2009 | Tomtom GO 720 GPS Receiver
Tom tom just stopped working
my tomtom does it now and then. solution is to take it to the car plug the car charger in to it, then press the reset button wait about 3 or 4 secounds and should come back on you don't have to remove your card. plging in to the computor does nothing it needs power when you press the reset botton
Sep 07, 2009 | Tomtom GO 720 GPS Receiver
Tom tom home does not see my tom tom go 520
Hi canal_boat_m
Try this solution:
STEP 1 Un-install Tom Tom Home from your PC
STEP 2 Click on the link below:
http://tomtom.com/lib/img/cs/S4S/files/RemoveRegEntries_TTGOv1.exe
This will download a little removal program for the Tom Tom Home program.
A Black window will appear briefly then close.
• Make sure that you have got Administrator rights on the PC. Otherwise you may not be allowed to connect new hardware (especially the case when using office computers)
• Reboot your PC
STEP 3 Visit Tom Tom website and download the current new version of Tom Tom Home and install it to your PC
STEP 4 Connect the TomTom
• Make sure the device is fully charged before connecting it to the computer. Ideally a mininum of 4 hours charge.
• Reset the device using a paper clip (see http://www.tomtom.com/6965). When resetting, keep the reset button pushed in for at least 20 seconds, but DO NOT turn the device back on just yet.
• Ensure that your TomTom has power connected to it. There should be a green light on the TomTom unit. If your device came with a Home Charger, please make sure that is plugged in to the TomTom also.
Your Tom Tom should ask you to 'Connect to Computer' if it does tap YES.
SOLUTION:
Your unit should now be recognized by your PC.
IF IT DOESN'T then follow the instructions below:
1. Connect your unit to your PC;
2. Copy two folders to your PC (namely 'Raster' and the one which holds all your maps - probably called 'United Kingdom and Eire';
3. Using Windows Utility, right click on the Tom Tom drive unit and select Fomat;
4. Switch off the unit and soft-reset it with a paper clip (but hold it in for at least 20 mins) and then re-connect it and power it up;
5. Tom Tom Home should now detect the unit and your unit should ask you to 'Connect to Computer' so tap YES;
6. Tom Tom Home will now say your device needs updating - and if you apply all the changes it will restore it to Factory Finished!
7. Then all's needed is to replace the two folders you backed up and any other items like mp3's and sounds, pics, etc.
Feb 27, 2009 | Tomtom GO 520 GPS Receiver
Tom Tom Go 710 - Won't turn on
not sure but try an other device on the car plug to see if it works??????????? could be the plug.
Dec 17, 2008 | Tomtom GO 700 GPS Receiver
Mx 3000 universal lcd remote
There are 4 reasons why your unit is behaving this way:
1. Charger is the problem.
2. The docking station is the broken.
3. The battery is broken or not accepting charge.
4. The actual unit is the problem.
It is very hard to tell which one is causing this to happen.
Let us do some troubleshooting first:
1. Plug your charger in an A/C outlet and make sure the red power light (left) is lit, otherwise the charger or the docking station is broken.
2. You can test the charger with a multimeter. Unplug the charger from the docking station and measure the voltage across the outside and inside, it should register more than 5 volts DC. If there is a 5Volt DC the docking station is the problem otherwise the charger is broken.
3. If the red power light is lit and the status light (right) is lit too, your docking station is broken.
4. If the red power light is lit, dock the unit into the charger, the status light (left) should turn red when your battery is accepting charge or turn blue when your battery is fully charged.
5. If the status light will not lit at all (while the red power light is on), tap the screen while the unit is docked on the charger. If the unit will become alive, you need a new battery otherwise you need a new unit.
12 hours is very long time to charge, the status light should turn to blue in less than 2 hours especially for a new battery.
Aug 29, 2008 | Universal Remote Control MX-3000 LCD...
Tom Tom Go 720
Reset the unit by pushing a bent paperclip or pin into the hole on the bottom marked 'reset' turn it back on, plug it in & charge it via USB overnight or as long as you can in the car, make sure the led on the top is green, tap the bottom right of the screen & check the battery symbol on the unit says charging underneath.
If this doesn't help.
contact them about the problem...
http://www.tomtom.com/support/support.php?ID=2
Dec 15, 2007 | Tomtom GO 700 GPS Receiver
How do I recharge my Tom Tom One?
I talked to TomTom support about recharging. They say that the unit uses more power than it gets, but if you turn the power off while the car is running, it will recharge.
Aug 28, 2007 | Tomtom ONE GPS Receiver
GPS Logo
2,209 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
