Question about Compaq Armada M700 Motherboard
My CMOS batter in Compaq Armada M700 seems to be dead and as I sat down to replace it, I ran into a problem when I found out that the CMOS battery had a plastic covering. My problem is how to remove the CMOS battery and replace it with a new one.
  • Compaq Master
  • 32,281 Answers
You can't, because the leads in this battery are spot welded to the battery. If you could get replacement battery, you cannot solder leads to the battery because the heat will destroy the battery.
Just buy a replacement BIOS battery with the leads attached.
Posted on Oct 05, 2010
Battery not charging
Company is replacing all such batteries. Its a manufacture defect found in your series laptops and Lenevo laptops. So don't panic and just consult compaq customer support for replacement.
Rate this solution if it was helpful to you.
With Regards,
Shyny
May 29, 2009 | Compaq Armada M700 Notebook
I have a Compaq armada m700 and i dont know the power up password i put it in without realizing it
I'm copying someone else's answer; I can't vouch for it.
emove the main battery and mains power supply, hit the power switch to drain any retained charge. then remove the cmos battery and short out the contacts. the cmos battery is on the right under the panel at the top of the keyboard, which can be popped out by gently levering it up at the edges. the key board can then be folded clear, watch for the ribbon cable under it that connects to the motherboard.
Dec 14, 2008 | Compaq Armada M700 Notebook
My compaq M700 does not keep time
it is called cmos battery it will be in motherboard
Jun 23, 2008 | Compaq Armada M700 Notebook
Compaq Armada M700
Try this: Remove the power adapter and battery from the laptop.
Press and hold the power button for up to one minute to discharge the laptop. Try starting it.
Jun 02, 2008 | Compaq Armada M700 PIII 700Mhz/ 128MB/ 12-...
My compaq armada m700 is having problem
this may be because the battery is dead so you may have to keep the charger attaached to the laptop for power. if this does not work then this means that the battery is no longer good so u will need to replace it.
please rate me. thank you,
May 23, 2008 | Compaq Armada M700 Notebook
Help with battery location???
Try this:
http://www.mk-stuff.de/artikel/how_to_disassemble_a_compaq_armada_m700/
Apr 06, 2008 | Compaq Armada M700 Notebook
Where is the CMOS battery?
Yes that was the cmos battery, I'll see if I can find a better solution for this issue for you.
Feb 13, 2008 | Compaq Armada M700 Notebook
Battery for Compac Armada M700
Hello Felcen:
It could be just a coincidence...but lets try a few things...
Remove the battery and unplug from the wall. Hold the power button on...and then plug back into power...after 8 seconds release the power button. Once your computer boots to desktop...shut down...and replace the battery.
Changing the harddrive should have anything to do with teh battery...
See if your battery starts charging after this trick.
Let me know and good luck my friend.
Seek PC Repair
Feb 12, 2008 | Compaq Armada M700 Notebook
Compaq armada m700 power failur...
try removing the large battery and powering off wall supply only...if ok, then replace battery
May 30, 2007 | Compaq Armada M700 Notebook
Compaq Armada M700 Motherboard Logo
253 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
