Question about Health & Beauty
When I switch on it beeps 8 beeps a pause and then repeats its self and it will not move.
You possibly have a bad or disconnected motor. Check the freewheel lever. Check motor connections. Make and model of scooter would be helpful.
Posted on Oct 05, 2010
3 Beep Warning
Staying in the freeze cycle too long. Usually about an hour. Several things can cause this. Look for water running even if machine is off. Possible stuck float switch. And more.
Nov 08, 2013 | Hoshizaki KM-61BAH 49 Pound Self-Contained...
How do i fix my ipod
Toggle the "Hold" switch to the "On" position, then "Off." The "Hold" switch is the small sliding switch on the top of the iPod. Move it to the "On" position to show an orange rectangle. Move it back to the "Off" position to show a white rectangle. Hold the "Menu" and "Center" buttons. Press the 2 buttons at the same time for between 8 and 10 seconds. Your screen will go blank and then boot up with a dark Apple icon. The icon eventually turns bright and brings you back to your main menu once the reset is complete. Check your iPod to make sure it plays properly. If the iPod still does not work repeat the reset process. b> Scroll Wheel and Touch Wheel iPods Move the "Hold" switch from "On" to "Off." Press the "Play/Pause" button and the "Menu" button at the same time. Press both buttons together for approximately 6 to 8 seconds. This initiates the self-running reset process. Make sure the reset was successful. If problems persist you may need to perform the reset process once again. b> iPod Nano Move the on-off switch to the "Off" position that shows the green strip. Leave the iPod Nano in this position for 5 seconds. Move the switch back to the "On" position. Use your iPod Nano to make sure the reset worked properly and all your music is intact.
iPod into Diagnostic Mode
http://www.methodshop.com/gadgets/ipodsupport/diagnosticmode/index.shtml
Apr 18, 2013 | Apple Audio Players & Recorders
How can i restart the ipod
How to Reset Your iPod b> Toggle the "Hold" switch to the "On" position, then "Off." The "Hold" switch is the small sliding switch on the top of the iPod. Move it to the "On" position to show an orange rectangle. Move it back to the "Off" position to show a white rectangle. Hold the "Menu" and "Center" buttons. Press the 2 buttons at the same time for between 8 and 10 seconds. Your screen will go blank and then boot up with a dark Apple icon. The icon eventually turns bright and brings you back to your main menu once the reset is complete. Check your iPod to make sure it plays properly. If the iPod still does not work repeat the reset process. b> Scroll Wheel and Touch Wheel iPods Move the "Hold" switch from "On" to "Off." Press the "Play/Pause" button and the "Menu" button at the same time. Press both buttons together for approximately 6 to 8 seconds. This initiates the self-running reset process. Make sure the reset was successful. If problems persist you may need to perform the reset process once again. b> iPod Nano Move the on-off switch to the "Off" position that shows the green strip. Leave the iPod Nano in this position for 5 seconds. Move the switch back to the "On" position. Use your iPod Nano to make sure the reset worked properly and all your music is intact. Hope this helps
b>
Jan 22, 2013 | Apple iPod Audio Players & Recorders
Reset i pod
iPod Nano
Hope this helps
Oct 22, 2012 | Audio Players & Recorders
I'm trying to recover my system, but everytime I push F11 to get to the System Recovery Manager, I get a repeating Beep.
That sounds like it might be "POST" code beeping out at you. If it goes beep beep beep (pause) beep beep (pause), or something like that, etc.... then it is definitely a POST code. It can be anything from a bad or unseated video card, to a loose memory DIMM card.
The computer's BIOS chip is hardwired to a dedicated speaker, if something goes wrong (like your video card is roached), it beeps out a series of beeps (not unlike Morris code). Check the manufacture's website, see what BIOS your model is using (AMI, PHOENIX, ETC..), and then look up their website to interpret the code you are getting. The computer Mfg.'s manual might also have that BIOS POST code information in it too.
Please give more detailed information about the beeping sequence. Like, does it ONLY beep after pressing the F11 key once, or because your holding it down (keyboard buffer is full then). Are the beeps continuous, or are their pauses between beeps (if pauses, count number of beeps between pauses until it repeats, usually has a long pause before it repeats if BIOS POST CODE). Also, did something happen just prior to your computer going belly up, or did it just not want to turn on one day? Give as much information as possible (make, model, OS, etc) about your computer, and what its symptoms are. The more info I have, the better I can help you.
Jul 29, 2011 | Computers & Internet
THE RED LIGHT IS ON AND BEEPS EVERY MINUTE
What motherboard do you have? If you don't know, provice make and model of your system and maybe we can find out that way. Is it one long beep? Are there any other beeps and/or a sequence. A good place to start and alot of times, depending on your bios, 1 to 3 beeps means a problem with the RAM(memory). If you have more than 1 stick, you can pull them out, restart and if the beep is the same, you've probably found your culprit. You can then insert one at a time in one of your slots, then restart. If this works, you've found a good stick. If not, try another slot and restart, etc. Try all sticks in all slots.
Apr 06, 2011 | Computers & Internet
A beeping noise came on and the air bag light does not come on
If you are hearing a series of 5 beeps, 5 beeps and then a pause and it repeats, the airbag light is burnt out, and there is an error that the LFC ( light Flash Code ) needs to report.
Pull the cluster, and replace the airbag light, and then pay attention to the LFC that will be given ( example, 1 flash short pause, 8 flashes, slightly longer pause, then repeat the 1-8 pattern again, jsut as an example ).
Feb 05, 2011 | 2004 Ford F150
When I turn the hard drive on it beeps 6 times intermittently and doesnt boot up as normal. The monitor is switched on but there is no picture. I tried another monitor with my hard drive and that worked...
Unplug power from the machine for a period of 5-10 minutes.
Plug it back in and attempt to boot. Carefully notice if there are any beeps again, and listen for pauses in between. Dell beep codes go in a three pulse pattern I.E. 4-Slight Pause-4-Slight Pause-2-Pause/ and repeat.
After this, you may have to open your machine and assure that everything is well connected.
There is a chance however that a major system component has failed and needs to be replaced.
Hope this helps.
Apr 13, 2009 | Dell Dimension 3100 PC Desktop
SAMSUNG 50" Switches off with beep-beep
the problems capacitors try to look the 315v/10uf
Sep 19, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Health & Beauty Logo
91 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
