Question about Nokia N73 Cellular Phone
How to reset or reformat my N73 - Nokia N73 Cellular Phone
I would like to reformat my n73 phone but i forgot the lock code for restore factory settings?
turn off your cell phone
Press and hold button * 3 Green Call Button and then turn on the power
hold the buttons until format complete
Your phone will be reset
Mar 07, 2011 | Nokia N73 Cellular Phone
I am having N73.......Two days before msg memory was full...I cleared all msgs...Now i don have even a single msg in the phone.........But even nw if i try to send msg,it sits in the outbox without getting...
your phone might be infected with virus, reformat phone will do, also reformat mmc, but make sure if you have some important file back it up on your pc,
hard reset is effective, switch off phone press hold green key, * and 3, switch on while holding this three keys
Oct 04, 2010 | Nokia N73 Cellular Phone
I got a new n73 phone in second hand.i want to reset it. when i reformatted its asking for a security code.what should i do?
the default code is 12345, if it didnt work, maybe the ist owner activated it in other code.. post your imei here i will calculate the master code
Apr 04, 2010 | Nokia N73 Cellular Phone
How to reformat my n73?
nothing wrong. plz remove your memory card in then insert it againg after turning the phone off man!
Mar 23, 2010 | Nokia N73 Cellular Phone
N73 reformat
have you tried reformatting it??
try this
12345 is a standard code and 00000, but if you change it and you have forgotten your unlock code, you'll just have to reformat it
key combination which is used to hard reset the phone (similar to #*7370). It is useful in some cases, for example when the phone cannot reboot.
The trick is
Switch off the phone.
Hold down the following three buttons: Green (call answer) button, * button, and ‘3′ button
While holding these buttons, press the power button and switch on the phone
When the message ‘Formatting’ appears on the screen, release all of the buttons...
reformatting your phone will delete all your data and also will restore all the defaults of your phone, and any corrupted application will be reinstalled, but if the formating doesn't work, you'll just have to re flash it, the safe way is to go to a near repair shop of your phone and have then to re flash your phone,
Jan 27, 2009 | Nokia N73 Cellular Phone
Camera loss...
guys just reset ur phone
try *#7370#
Oct 05, 2008 | Nokia N73 Cellular Phone
UNLOCKING NOKIA N73
key combination which is used to hard reset the phone (similar to #*7370). It is useful in some cases, for example when the phone cannot reboot. The trick is by switching off the phone then press and hold Call key (Green key) + * key + 3 key + power button for a couple of seconds
but all your data will be lost
Aug 18, 2008 | Nokia N73 Cellular Phone
Reformat N73
easy! press and hold * and 3 and Green while pressing the on button. if that don't work, try *#7370# and security code which should be 12345.
Jul 16, 2008 | Nokia N73 Cellular Phone
Reformating n73
Reformat the phone
To format:
  1. Turn phone off
  2. Hold the following keys WHILE it's turning back on: (3 + * + green call key)
  3. DO NOT let go till it asks you about your LOCATION
  4. DON"T forget to back-up all pictures and videos on the phone memory to the memory card before doing so
Jul 02, 2008 | Nokia N73 Cellular Phone
How to format n73
hi there. here are some codes that you can apply with if you really want to reformat the phone memory. i am not sure if it works out with N73 but on my 7610 before it worked fine. you can just try. Be sure to back-up the your phone first.
Full Reset: (clears everything off the phone memory!! Be sure to back up your contacts!!): *#7370# and then Yes.
Please Rate Thanks
Jan 07, 2008 | Nokia N73 Cellular Phone
Nokia N73 Cellular Phone Logo
57 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
