Question about Garden
Hi ya got a old ish tiller in for repair, it is a ISEKI AC40 problem is hard to start & when it starts it will only run for about 10 seconds, so far checked plug which has a good spark, compression ok, stripped & cleaned carb (mikuni) now spotless & filters all fuel lines, tank/cap, Gravity feed I think it could be flooding abit haven't got float setting or screw on side setting, so I'am a bit lost any idea's please.
    Scholar:
  • 150 Answers
From your description we will assume it is flooding. If you suspect float problem, check float level, holding the carb upside down the float should be parallel to carb body when needle seat is closed. On metal floats this is accomplished by bending the tab that rides on the needle, units with plastic floats you may have to replace it. Also remove float and shake it, should not be any gas in the float, this will make it flood. Also set carb adjustment screw at 1.5 turns out, may need a little tweek from there.
Posted on Oct 05, 2010
I have a Gilson rear tine tiller Model 51114 is there a way to repair the transmission, or used transmission avaliable
Posted on Jun 13, 2011
The tiller starts and runs well for about 10 to 15 minutes but then will bog down and stop running . It will restart and run for about 30 seconds and then stop again. Any ideas about what is causing this,...
It sounds like a carburetor fuel issue. Which you could try attempting to adjust the carburetor (or have someone else do such) to see if that cures the problem.
May 16, 2014 | Honda 25cc 4-cycle Mini Tiller
I bought a Troy built tiller. used once two years ago. then it has been sitting in a shed. It had old gas in it. I drained gas tank. I am getting a spark. when I pour gas in air breather, it starts, but...
I have had good luck using an engine starting fuel, sprayed into the air cleaner/intake. Any auto repair store will carry this product. CAUTION, HIGHLE FLAMMABLE!!!!!!! Many mechanics frown on using starting fluids, but I have a bad shoulder & that is what I do on the 3rd pull.
Louie Almond
Mar 27, 2011 | Troy-Bilt Pro-Line 160cc FRT Tiller
My mantis starts easily - but then dies. it sometimes doesn't even rotate. i can do about 3 seconds before it dies. help. what do i do?
The Carb is either cracked or needs to be rebuilt - OR - you might get luck and just blow it out with a professional dose of AIR from a larger compressor like used at mechanics shops.
Gary @ Fix Ya
Sep 05, 2010 | Mantis 2-Cycle Tiller
I have a Hoffco Lil'l hoe and it will start for a few seconds and then stop. Last year I took it to a local small engine repair shop and they just half fixed it because a couple uses it became hard to...
Make sure your air filter is clean and you are using brand new petrol. If you left old petrol in it it may have clogged up the carb. It sound like no fuel is getting to the spark plug. If you have a rubber priming bulb, press it slowly and regularly to try and keep the engine going once you have it started on starting fluid. Good luck.
Jun 25, 2010 | Hoffco TILLER PRO HOE WITH HONDA ENGINE
It will start OK and run for a few seconds then I hear a click and it stops running.
Had a similar prob. Are you fIooding? I don't know how old your critter is but I replaced the diaphragms, a.k.a. fuel pump, in the carb. (About $10) Then screwed in the idle adjustments all the way-LIGHTLY-and backed them out 1 1/4 turns. Once running, adjusted to a smooth high and low idle and per instructions.
Jul 09, 2009 | Mantis 2-Cycle Tiller
I can't get it to start, it just sputters for about 10 seconds and cuts out.
If your tiller sat all winter it will need a little work. Drain all of the old fuel out of the tank, install a new spark plug and install a new air filter. Put new fuel in the tank [if you still have old fuel in your portable gas tank dump it into your car or truck so you start fresh for all of your small gas engines.
Now crank it over and it may start. If it doesn't start you need carbeurator cleaner. But an aerosol can of carb cleaner and put two squirts in the air intake [remove the new air filter and leave it off while you get the engine running]. Pull your cord, turninng the engine over and possibly starting it. If it starts, great. If not, let it sit for half hour while that carb. cleaner dissolves some of the gum built up in your carberator over the winter. Two more squirts of carb cleaner and try to start it again.
Generally it will start by now. If it doesn't start your carbeurator must be really dirty. You will have to remove it, and soak it in carb. cleaner for about three hours to clean it out.
May 27, 2009 | Mantis 2-Cycle Tiller
Tiller will not keep running
Have you tried squirting gas into carburetor to see if it will keep running? If that keeps it running as long as you are squirting gas in it, your carb need to be cleaned out/repaired.
May 26, 2009 | Troy-Bilt Garden
Tiller won't stay running
If you choke or prime the engine, it starts up for a second or two and dies, the carburetor need to be cleaned/repaired.
May 25, 2009 | Mtd Products Yard Machines 158CC Tiller
Tiller starts then stalls
The air filter should be replaced. Also remove the old gas and put in new from the gas station. Finally, if you didn't change the spark plug from last seaon, do so as it is a small amount of cash for a lot of easy starts.
Apr 24, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Garden Logo
655 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
