My daughter cant hook her acer aspire notebook up to my wireless router....its showing that it is full strength...but says limited connectivity or none...cant open internet....she is using windows xp...and I set my computer up with wireless using windows vista....any ideas as to what is wrong...thank you.
  • 32,281 Answers
The wireless card in the notebook needs to be configured with thw router's wireless setings ie. the SSID and the encryption settings.
To secure your wireless network from unauthorized access and toconfigure the wireless card in the laptop/computer, please click on this link and follow my instructions :-
Normal 0 http://www.fixya.com/support/r3559128-wireless_router_security
Posted on Oct 05, 2010
I cant get my Acer 5250-BZ873 to keep a wireless connection
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Aug 23, 2012 | Acer Aspire 5100 Notebook
Why will my Acer Aspire 5552 running W7 only connect to the internet when it's near the router? When elsewhere in the house, it shows 2 bars on the signal strength, but will not connect to the rou
That means you have a crummy internal wireless card. Your best bet would be to purchase a USB wireless card and your problem will be solved.
Mar 21, 2012 | Computers & Internet
Acer Aspire One D250 - Weak network signal strength with Broadcom 802.11g adaptor
2. Have you secured your wireless router from people near your from unauthorized access? ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
Dec 26, 2009 | Acer Aspire One PC Notebook
I have two computers receiving wireless internet via my Linksys WRT54G router. I recently purchased an Acer Aspire one (mini computer) Can hook up to wireless at my daughters and at other places, but...
For you to resolve this problem, you'll need to reset the router. Press and hold the reset button for 5 seconds, and when you are prompted for the user name and password just input "admin" in both fields.
Try connecting your computer to the router after this process.
Good Luck.
Oct 13, 2009 | Linksys Wireless-G WRT54G Router
Samsung NC10 will not connect to any network
If WLAN and Wireless cards are enabled, then you may have to unplug your router for 10 seconds to reset it. They tend to build up a static charge. Unplug wireless router for 10 seconds, plug back in and you should be fine in a minute or two with full connectivity
Aug 20, 2009 | Samsung NC10-14GW Notebook
How do I enable the wireless on my Acer Aspire one?
Open control panel scroll down to Internet connections and click to display. Right click wireless wizard then click choose enable. After this you will be prompted with a box that will show you that the computer has detected wifi connection in the surrounding.
Jun 22, 2009 | Acer Aspire One PC Notebook
Acer Aspire won't Connect Wirelessly Even with Full Strength
do you have security on your wireless network, password etc. like WEP, WPA, WP2 and the likes. that would be the first thing you need to check, second is the type of wireless card and router you are using, on the laptop you might have a wireless N router and a wireless N card on your laptop which might require higher security. you'll need a WPA2 - personal for the key. that you can configure your wireless router manufacturer. hit me back.
Apr 27, 2009 | Acer Aspire One PC Notebook
Wireless connection will not connect coz wanting password
Hi there.
Its asking for the password for the wireless router as it would seem that your network is a secured network.
The password will be on the router unless you have changed it.
Post back if you need more help.
Good luck and thanks for using FixYa!!
Apr 09, 2009 | Acer Aspire One PC Notebook
Can not connect wirelessly with router
The list of wireless routers that are available in Windows is very limited and the signal strength of any router that is detected is weak. This can occur when the Lite-On USB Wireless 802.11 b/g hardware and Windows are not able to fully synchronize the signal strength data. Figure 1: Example of detected wireless devices when the antenna cable wire is connected to secondary port c01153759.jpg Figure 2: Example of detected wireless devices in the same environment when the antenna cable wire is connected to primary port c01153760.jpg To correct this error , download and install Lite-On USB Wireless LAN Driver Update (sp35177) (in English) from the HP Web site. This update should only be applied if your PC has the Lit-On USB Wireless LAN adapter and is exhibiting the symptom. As a work-around, you can connect the wire that runs from the wireless antenna port to the primary port on the cord as follows: CAUTION: This product contains components that can be damaged by electrostatic discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (like a conductive foam pad), and wear an ESD wrist strap connected to a grounded surface.
  1. Open the side panel.
  2. Find the wireless networking board by following the antenna wire connected to the wireless networking antenna port on the back of the computer. Figure 3: Wireless networking hardware c01153761.jpg 1 - Wireless network board 2 - Antenna wire 3 - Wireless networking antenna port
  3. Very carefully, disconnect the small wire from the board by gently pulling the end of the wire away from the board.
  4. Connect the wire to the other available port on the board. Figure 4: Available port c01153762.jpg
  5. Replace the side panel, connect the power cord, turn on the computer, and use the computer again to verify that wireless signal strengths have improved.
Jan 14, 2009 | Acer Aspire 4520-5582 Notebook
Laptop wont connect to wireless internet
click start > run> type cmd> ping <website>
click start > run> type www.yahoo.com (example)
Mar 11, 2008 | Acer Aspire One PC Notebook
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
