Question about Pioneer Audio Players & Recorders
I have a pioneer make portable sterio model SK550 now in working condition of Radio portion only. The belt of the motor of the tape recorder has been torned. I want the belt .My address Baidya Nath Roy P.O: Bishnupur ( Salbagan) Dist: Bankura west Bengal India Pin- 722122
worldvet
  • 859 Answers
SOURCE: JVC CD portable system RC-X270/X260
Sorry to tell you that these players are famous for coming out of the factory with wire leads broken from their mounts.
You will have to dig into the guts of your player and find the loose wiring and resolder it in place.
If you don't feel qualified to do this perhaps you know a friend or neighbor that can. Lacking that a repair shop will fix it for you. But, you have to decide if the cost of repair outweighs the cost of replacing your portable player.
Sorry to bear this bad news to you.
Regards,
Worldvet
Posted on Jun 15, 2008
  • 333 Answers
SOURCE: car audio [KRC-208S] does not turn up with ignition on
spacer.gif Here is the address you are looking for.
Communications
Kenwood Authorized Service Center in India (East)
spacer.gif spacer.gif Kolkata
COMPANY ADDRESS Contact Person LIPI DIGITAL LIMITED 30 Ganesh Chandra Avenue, Suit No. 4, Ist Floor, Kolkata-700 013
PH: 098 - 30606725, 093-30006725
Fax-22159187
E-mail: aditya@lipidigital.net
Mr. Aditya Jaipuria
Posted on Dec 05, 2008
RAhUL_hunk
  • 63 Answers
SOURCE: We urgently need Instruction Manual / owner's
hi, here is the link to the manual of your microwave
http://downloadcenter.samsung.com/content/UM/200709/20070914093233421_CE283GL_XTL-02976H_EN.pdf
kind regards
Posted on Mar 11, 2009
  • 400 Answers
SOURCE: AC is not functioning properly ( not cooling properly)
You can check that the filter is not clogged. If not, it may just be short of refrigerant. I presume the compressor is running and the fanmotor is ok.
Posted on May 08, 2009
rajak2009
  • 527 Answers
SOURCE: Tally backup error
click this link for ur problem. just go through it. this is one of the best site i had ever seen
Thanks Good Luck
Appreciate to rate as "Fixya"
Posted on Jun 26, 2009
I have a Pioneer model CT-F2121 want to connect it to my Radio amp. I has two ports at back of Radio which is marked "switched" and "Unswitched" Radio is a Sansui model 210SS multi receiver. I have tried...
The deck if in working condition can be plugged into any AC wall outlet or the two AC outlets on the receiver. This is only for power, The Line outs and line in also have to be plugged into the Tape in and record out on the receiver as well. If the CT-F2121 need repairs that is what needs to be done first. Probably a whole set of belts.
Aug 12, 2013 | Pioneer Audio Players & Recorders
Tape recorders.
Most tape problems would be mechanical in nature. I am venturing a guess that the belt(s) are cut. If your brand/model uses two (2) separate motors, then either both belts are cut (unlikely) or the regulator circuitry powering these motor(s) are defective. In some instances, the logic circuitry (especially those with dubbing features) maybe at fault.
Corrective procedures would entail opening the unit for a look and see. This of course would require that you be familiar with electronics circuitry & mechanical components, use of a DVM and possibly even soldering. Should you be uncomfortable going this route, perhaps it will be to your advantage to seek the services of a qualified professional.
Incidentally, should the downtime and cost of repair be no longer economically reasonable, then perhaps purchase of a new unit might have to be considered.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 25, 2008 | Audio Players & Recorders
Horn and brake lights
This happend when you put a new sterio? Now your horn and tail lights dont work. Well some models require and extra harness to make the after market sterio work, check in to that. Or a fuse, make you where the wire is and trace it to see if it goes to the radio
Feb 27, 2013 | 1993 Geo Tracker
RCA Selecta vision vcr does not play or fwr/rvs. The motors engage then stop.
did u check the belt may be stretched or dirt dust holding the motor back
Dec 30, 2012 | RCA Vintage Selectavision Vcr Early 80...
I don't know if you can help or not, but i picked up a pioneer stereo/cd/dual cassette player - model xr-p260f at a garage sale. It's really clean and looks like it hasn't had much use. The...
Tape players have several rubber belts in it and if we do not use them frequently belts loosen and become useless and they need to be replaced... . To accomplish this however you need some sort of handy man ability.. Take out the metal cover of the player by removing the screws on the sides .after removing the cover you can access the tape head /transport mechanism. if you look carefully to underneath of tape transport you will see the motor unit which belts will be there...check the belts for the moving mechanism and make sure the belts are not loosen / worn out or broken . You can replace it with a new one that may available in radio Shack stores. Take care..and let me know if it does not work out..
Take care and please Remember to rate/vote for us to
continue f
or Helping out the Community :)
Jul 09, 2011 | Pioneer Audio Players & Recorders
How do I get it to record a voice?
Many portable 'boombox' recorders do not include a microphone for recording ambient sound, but can only record from one internal source to another, like radio or CD to Cassettte. Some do include an input jack for microphones or other audio sources, but you'll need to check your device's specs/ports to be sure.
May 18, 2011 | Sony CFD-F10 Radio/Cassette/CD Boombox
I have a pioneer DEH 525-W car sterio harness and colors do not match to that of the Saturn L2 1999. How do I connect this car sterio?
Just go to Best Buy and buy the Saturn L2 1999 Harness . then it will match. Harness cost like 20 bucks.
1st STEP
Things to get from BEST BUYor RADIO SHACK.
1. Black electrical tape
2. (Optional) for quality connection Solder & Solder gun
3. GM (General Motors) Antenna Adapters
4. GM 1999 Car Harness
5. GM Saturn L2 1999 Car Kit
STEP 2 = Match the colors of the car harness you just bought to the harness of the radio (DONT PLUG IT INTO THE CAR YET CAUSE YOU MAY SHORT OUT THE POWER WIRE TO GROUND) twist the same color wires together and then tape them so it wont be exposed to get shorted out and damage your radio or blow fuses in the car.
STEP 3= plug in the complete harness to the radio and the car and also plug in the Antenna adapter to the small antenna jack of the car that converts it to a larger jack so you can plug it in the back of the new pioneer radio that has a larger antenna hole. Now test the radio it should work unless you had blown your radio fuse in the car already which is easy to replace.
STEP 4 Unplug everything from the radio and install your CAR KIT. Then slide your radio sleeve in the rectangular hole all the way flush and use a flat head screw driver and bend the tabs of the sleeve(Radio Cage) so that the sleeve wont move.
STEP 5 make sure your harness & antenna is sticking out of the sleeve so you dont have to fish it out later when you have finished mounting the car kit to your car. Put your car dash back together and you will see only a rectangular hole with a harness and antenna adapter sticking out only.
STEP 6 plug in the harness and antenna back into the radio and slide it in halfway only and test the radio again making sure everything works. If it does then move it all the way in till it locks into place. last snap in the face trim ring into place to cover the silver cage lining.
THERE YOU ARE FINISHED
Apr 09, 2010 | Car Audio & Video
Pioneer pl 990
Remove any tape from the belt
That is the drive belt for the turntable .
It's not that hard to set up. Take the mat off the platter and wrap the belt around the underneath -slightly-less-diameter portion.
With a pointed end needle or something like it , put the tip between the belt and the platter portion it's wrapped against.
Pull the belt away from that( keeping the rest of the belt on the platter portion) and set it over the motor pulley. This is usually a small diameter brass spindle unit
Mar 27, 2008 | Pioneer PL-990 Turntable
Problem with deck B on Pioneer CT-W205R
Better tape decks, like Pioneer, may use a different mechanism for record/play than FF & REW. So it sounds like a belt or mechanical link for the REC/PLAY has failed.
Dec 20, 2007 | Pioneer CT-W205R Single Dual Cassette Deck
Sony MiniDisc car stereo
It sounds like you have a newer portable minidisc player, and an older deck. There were several upgrades over the years for ATRAC files, and some of the newer recording formats are not compatible with older players.
Nov 10, 2007 | Pioneer MEH-P5000 MiniDisc Player
65 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
