Question about Pioneer Audio Players & Recorders
I have an AVIC Z2 and I’m trying to connect a GEX-P10XMT. The manual says to hook only the IP-BUS cable only. I have the IP-BUS cable connected to the IP-BUS output (black) and to the IP-Bus input (blue) and I’m getting nothing. What could be wrong?
  • 20 Answers
SOURCE: HDMI connection problem
On your TV set remote are you selecting the proper input; for example when you have different devices connected to the back of your tv set, dvd player, vcr, cable box etc; you have to tell the tv which device you want to use by selecting the right one on your tv remove input selection. Hope this was any help.
Posted on Sep 08, 2007
  • 17 Answers
SOURCE: ONKYO TX-SR606 Single output to TV
Hi there. for your receiver, the only time it can upconvert is when you go out as HDMI. In your current hookup (component out to tv) the signal from your cable (using a composite) will not be able to pass through the component cable. This means you either have to hook up your cable box using a component cable as well or add a composite cable (yellow) from monitor out of the receiver to the tv. Page 22 of the manual will show a diagram of the video signal flow. hope this helps.. ^_^
Posted on Dec 03, 2008
SOURCE: the HDMI "input" ports damage output ports of connecting devices
i know this sounds stupid, but have you "toggled" or "played" with the HDMI cables? are they the same manufacturer? HDMI channel connections are very fickle. If just one connection is not exactly correct, they go to a limp, no go status. Since they run at such a minimal voltage, i can't see them "blowing" the outputs on the devices.however....if your cable has a serial type output for video only, I would connect the hdmi convertor to it and see if it works.
Posted on Jan 10, 2009
  • 233 Answers
SOURCE: connect Macbook Pro to Component input
you should be able to use an SVGA to component rca connector on any component input - i have a wd-65513, and thats how I have my pc hooked up to it. I could also never get a clear picture using the SVGA plug on the back of the set.
Posted on Jan 12, 2009
  • 4 Answers
SOURCE: NAD T753 s-video in, component video out problem
I have the same amp. You have to have the same input as you do output for s-video in/s-video out, composite video in/composite video out. I know it sucks but thats how NAD designed it.
Posted on May 07, 2009
My Pioneer AVIC Z2 can only hear sound when radio is on. I can play dvd and cd but no sound. Can someone help me please????
your blue wire(power antenna) is connected to your factory amp. this wire only sends out audio when the radio is on(power antenna)
disconnect this wire and hook up the blue/white instead
problem solved
Aug 20, 2010 | Pioneer AVIC-Z2 Car DVD Player
My avic z2 turns on however it says can not use HDD on the screen. thanks.
i'm trying to install the avic z2 and the display say starting navigation sistem and it does not disaper am i doing something wrong
Jul 07, 2009 | Pioneer AVIC-Z2 Car DVD Player
Cant get ipod to work on avic=n2
I have reset the systems before WITH the new ipod cable connected. Try that, I know that it will reset everything, but that has worked for me as it sees all the new hardware through IP bus
May 31, 2009 | Pioneer AVIC-N2 Car DVD Player
Pioneer 5.1 dolby surround multichannel processor ?s
You will need extra amp(s) to run 5.1 surround sound using out IP-Bus at the brain to in IP-Bus at the processor and rca output to the multi channels amp(s) and control the surround mode which is automatically activate by the format of the disc. The IP-Bus cables is colored polarized at each end to inter connect all components. Just hook them in series follow the color you may add all the components you have. You can also down load wiring diagrams at Goodluck.
Apr 16, 2008 | Pioneer AVIC-N2 Car DVD Player
Trying to install i-pod adapter CD-IB100
go on crutchfield. It's called a passthrough which will allow you to have both items.
Dec 29, 2007 | Car Audio & Video
Connceting a pioneer cdx - p670 to avic x1 head unit
the changer is either incompatible or the changer wire has been intrnaly dammaged to much bending shorts them out as the wires are no more than alluminum foil enclosed in shrink wrap
Dec 28, 2007 | Pioneer GPS AVIC-X1 car radio
Pioneer Bluetooth
The Z2 default code is 1111
Oct 23, 2007 | Pioneer AVIC-Z2 Car DVD Player
Pioneer AVIC-Z2 DVD Function
I installed my pioneer avic z2 DVD/Navi myself and I realized that the wire that connects to the parking break is just a power wire that comes on when u pull the parking break. I think, all you have to do is to connect it to any other power wire that will be constantly provides the on power while driving. I'll try it out tomorrow and let you know!
Oct 06, 2007 | Alpine CDA 7893 CD Player
Wiring Installation - Satellite Radio
The wire that runs along with the P-bus cable connects to constant power; the other wire needs to be grounded.
Jan 08, 2007 | Pioneer GEX-P910XM Satellite Radio...
Top Pioneer Audio Players & Recorders Experts
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
