Question about Amana Refrigerators
Hi, I am looking for the schematics for an Amana side-by-side refridgerator AC2225GEKB. I live in the Czech Rep. and transported the fridge from the UK. It was repaired once by a serviceman who didn't replace the heating element and subsequently the fridge would freeze up about every 4 weeks. I had a maytag serviceman order and replace the missing element and now the fridge and freezer are only chilled in the bottom third. The serviceman came back to repair the fridge, but as is the way here, it took more than 6 months between visits and the problem still exists. I have found someone else to help but any information on what the problem may be and the electrical drawings would be much appreciated. Thanks for your advice in advance. Paris
  • 331 Answers
SOURCE: 'ice dam' on bottom of freezer, now problems with fluctuating temps
Kat, you only have 1 problem happening.And no this is not due to the original repair. (though I have to admit... replacing the filter/drier, starter and compressor is NOT part of routine maintenance and has me a little befuddled.) Your evaporator drain is plugged. Most likely with what we in the biz call "bio-gookus". This is normal, but must be cleared to keep the water from puddling and coming out your freezer door. With the evap panel removed and the drain hole exposed, pour 1/4 cup of HOT water into the drain hole. Use a small screwdriver or other small instrument to pick out the ice buildup. Once this is clear, use something like this to blow out the rest of the lines. After doing this, pour more hot water into the drain to verify free flow. This will take care of your leak problem. Now... the frost buildup. NEVER RUN YOUR FRIDGE WITH THE PANELS OFF! They are there for a reason, believe it or not. They direct air flow across the coils (both evaporative and condensing). Frost buildup is normal, though you may be experiencing higher levels of frost because of the panel missing...Your fridge utilizes an automatic defrost system. It'll initiate every 8 hours. This is controlled by a timer located in your fresh food section. The defrost heater RARELY fails on these. Fix the evaporator drain and replace all panels. This will solve your dilemma.
Posted on Aug 09, 2007
  • 1122 Answers
SOURCE: fridge was in storage 4months fan work but not freezing.
is there ice building up in back of freezer?mike
Posted on Nov 11, 2008
  • 1239 Answers
SOURCE: Fridge stopped working, freezer still works
If the compressor doesn't run, it is likely that the defrost timer is malfunctioning. This part is located near the compressor. To test the defrost timer:
Step 1:
Unplug the refrigerator.
Step 2:
Disconnect the wires from the timer and timer motor. Remove the timer from its brackets by backing out two retaining screws.
Step 3:
Test the defrost timer with a VOM set to the RX1 scale. Clip one probe of the VOM to each defrost timer -- not motor -- wire, and turn the timer control screw shaft until it clicks. If the defrost timer is functioning, the meter will read zero. If the needle jumps, the defrost timer is faulty. Replace it with a new one of the same type.
Step 4:
Connect the new defrost timer the same way the old one was connected.
To check the defrost timer motor, clip one probe of the VOM to each motor wire, setting the scale to RX100. If the meter reads between about 500 and 3,000 ohms, the motor is functioning properly. If the meter reads higher than 3,000 ohms, the timer motor is faulty. Replace it with a new one of the same type. Connect the new motor the same way the old one was connected.
Posted on Dec 07, 2008
  • 15935 Answers
SOURCE: GE TFX20SA back wall of freezer freezing (snow
CLICK HERE for an expanded view of your freezer section.
Can you see the evaporator fan moving when it is plugged in?
Otherwise your defrost timer has failed.
#257 in THIS diagram
CLICK HERE to see the part.
CLICK HERE for testimonials about installing the defrost timer yourself.
Thanks for using FixYa - a VERY HELPFUL rating is appreciated for answering your FREE question.
Posted on Jul 13, 2009
SOURCE: Water leaking and freezing at bottom of freezer in
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
First Choice Appliance
Posted on Jun 03, 2010
Amana green water filter light off
If your machine is only 2 months old and wasn't used when you bought it call the number on the label that has the model and serial number on it that is located either inside the refridgerator on the upper wall somewhere or somewhere on the frame. Being that whirlpool now owns Maytag, which encompasses Amana, you have a one year manufacturer warranty where parts and labor are both covered free of cost.
Apr 27, 2012 | Amana 22.6 cu. ft. Side-By-Side...
I have a side by side ref/frez Amana ars266zbw the freezer works fine but the refridgerator isn't coolig
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
Jul 12, 2011 | Amana ARS266ZBS Side by Side Refrigerator
Hi there.I have an Amana Side by Side Refridgerator.We are having a problem with the fridge side not cooling enough.The Freezer side is working well.Have you any tips on how to fix it myself ?Cheers.
Check fan which blows cool to fridge compartment is working. Check fridge is defrosted automatically. If not do it manually and check, there will be cooling in fridge compartment. Over frosting will cover up the fan throw behind the freezer. If not auto defrost works, switch off and restart after 5 minutes. Still auto defrost problem, do it manually or replace board.
Jan 27, 2011 | Amana 22.6 cu. ft. Side-By-Side...
I have a stainless steel Amana model ABC2037DES that was given to me. It has been plugged in for 24 hours and it is not freezing anything or making ice. The refridgerator is not cold enough either. ...
if the compressor is working it could be a thermostat problem
I think that if you check for a reset button at the back to get the compressor running , that will fix the problem
Mar 13, 2017 | Amana ABC2037DES Stainless Steel Bottom...
My freezer side isn't freezing. fridge side seems to be working
If it worked fine to them, look at the heating and cooling C. in the back of the frig. Depending on how you transported it and how many bumbs you hit could of damanged them
Apr 03, 2010 | Amana SXD524VW Side by Side Refrigerator
Freezer door wont seal and stay closed
Your pushing air from the fridge part over to the freezer door when you clos it,the only thing i can suggest is make sure that the seal (which is magnetic) is clean and not falling apart,inspect it all around the door,and when closing the door i would close it gently.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 25, 2009 | Amana ARSE66MB Side by Side Refrigerator
Amana Side by side refridgerator Model SBD20TPE P1190006WE
one question : are the units under warranty ?
if not its pretty easy to swap the dispenser paddles and the membranes
infact i have been using this site for many years and have found it helpful: :
May 04, 2008 | Amana ACD2232HR Side by Side Refrigerator
This is Gene's solution not mine, for a Ge fridge.
Assuming the ice dispenser works fine, the first thing I would check is the water filter, then the water inlet valve on the back of the fridge.
If the water filter is more than a year old it will cause restriction to the water flow.
Locate the water inlet valve on the back of the fridge. Remove the wires from the blue solenoid and check for 120V coming to the solenoid while the water dispenser lever is depressed.
If there is 120V then the water inlet valve has to be replaced.
May 03, 2008 | Refrigerators
Amana refridgerator
water valve is in the rear on the right side at the bottom
unbolt it from the ref frame and pull it outward remove the hoses the white plastic ones place a pan under the valve and depress the qater in the door paddle if water comes out of the valve then it is good if no water out of the valve verify the voltage to the valve if 120 to the valve then replace the valve
if no voltage problem lies in the wiring harness or the despensor mech. has a problem
Apr 25, 2008 | Refrigerators
Refrigerators Logo
78 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
