Question about Sebo X4 Bagged Upright Vacuum
It just keeps saying that my bag is full and cutting out, bag not full and have tried changing it anyway, but still cutting out
  • 1,040 Answers
I would check the air filter. It sounds like it's over heating and shutting off because it doesn't have good airflow.
Jim
Posted on Oct 05, 2010
Epic 6500 Sr. Why does it keep turning on and off?
Electrolux Epic 6500 - Bag Full Indicator Bypass - YouTube
? 0:55
https://www.youtube.com/watch?v=YrMgoUAHcI4
Jun 23, 2013 - Uploaded by easilen
The rear pops off. There's a vac. ... Yeah, keep it. Undo Close ...Electrolux Epic 6500 - Bag Full Indicator ...
Questions and Answers for Electrolux Vacuum Unit
builtinvacuum.com/help/electrolux/qanda/main-central-unit.html
For Electrolux; Central Vacuum Attachment Kits and Hose and Tool Kits for Electrolux Attachment ... With a clean bag in, the unit starts up and immediately shuts off. If you hold ... From what I have read hear, it sounds like the motor is going. ... How can I fixmy electrolux epic 6500 SR vacuum? ..... It keeps cutting off and on.
Electrolux Epic 6500 SR Shuts off when power hose ...
Dec 28, 2015 | Electrolux Vacuums
Sebo Vacuum runs intermittently and keeps cutting out and restarting
There could be numerous reasons for this. What I would try in this order to help troubleshoot is this:
1. If you wiggle the power cord near where it inserts into the vacuum cleaner itself, does the vacuum turn on and off constantly? If so, you have a damaged cord or loose connections that need to be fixed.
2. Has the bag been emptied, and if the vacuum has a filter element, has this been cleaned? Vacuums may cutout if they get too hot. A vacuum can overheat if either the bag is full, the filter is blocked, or there are other obstructions to airflow, which cause the motor to work harder and draw more voltage, resulting in more heat. It may have a thermal cutoff which is tripping constantly. Solution is to ensure bag is not full, or less than 3/4 full, any air filters are cleaned and check for any other obstructions in the air flow paths.
3. Ensure the power supply is adequate for the vacuum. Try running it without long extension cords if you have been using those.
4. Check and clean the switch. Sticky or dust contacts on switches can cause variable cycling (cutting out and restarting).
Hope that helps!
Mar 11, 2011 | Sebo Automatic X1 Bagged Upright Vacuum
Electrolux 2100 vac dies when you attach hose even with new bag.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Mar 31, 2010 | Electrolux UltraLux 2000 Bagged Canister...
The red light on my electrolux vacuum comes on and cuts power.
Mar 26, 2010 | Electrolux Guardian Bagged Canister Vacuum
Electrolux Model 2100 vacuum won't work
hi from uk may i suggest you remove cover and the new dust collection bag then if you look in the bag compartment there is a gauze filter fitted usually grey in colour ? at opposite end of compartment where bag connects this gauze filter is the outlet from bag compartment that the air exhales when vac is operating ie as vac **** up dust into bag the bag has microscopic holes that allow sucked up air and dust to collect but keeps dust from passing into bag chamber but allows air to escape thro holes and so enter bag chamber then escapes via the gauze filter to outside of vac hope you follow this ?? now if this filter is blocked/never been cleaned/changed ? then the symptoms of indicator bag full light will come on you can remove and wash filter if it is gauze typ? dry and refit then try vacuuming ? or replace filter they are not expensive usually in pack of 3 in uk DO NOT RUN VAC WITHOUT THIS FILTER FITTED ! or you will have some dust in the room ? hope this helps?
Feb 27, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Why does my miele 700 revelution hoover keep cutting out? The bag is not full just loses power?
  1. i have a miele revolation hoover, it doesnt pick up. it has hardly no sucktion. where and how do i get the filter out to clean it??? it was given to me working. ive changed the bag so thats not the problem. and checked the hose. still no joy. need sucktion.. Thankyou jacqui
Jan 01, 2010 | Miele Revolution 600 Bagged Canister...
Bag was full, changed it, the unit now turns off
Try dialing the control valve to the mid way position. If the unit still shuts down with the bag full light on you have a damaged control valve under the dial on the top of the vac.
This valve failure is common in this model and can only be repaired by someone with original AERUS Electrolux repair parts, generally at an AERUS repair shop.
Oct 29, 2009 | Electrolux UltraLux 2000 Bagged Canister...
13 yr Electrlux.Cuts off if hose plugs in.Says Bag Full-bag empty
This sounds like the valve assembly (full bag control) is faulty or one ov the tubes is clogged. You will have to take it to the shop.
Jul 15, 2009 | Electrolux Guardian Bagged Canister Vacuum
Sebo x5 vacuum cleaner
The full bag light comes on when it is getting full or a blockage in the hose or the dirt inlet by the brush roll. Other then that, there is a circuit board called the computer controller, part #5740ER and is giving you a false reading and causing a shut down.
Jun 22, 2008 | Sebo X4 Bagged Upright Vacuum
Full bag system works properly, but doesn't reset easily
Either there is something wrong with your switch. Which it doesnt sound like it. Take it to your dealer or call another one it sounds like the control valve needs to be replaced. I am a dealer 1-866-966-9350.
Jun 19, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Sebo X4 Bagged Upright Vacuum Logo
336 people viewed this question
Top Sebo Vacuums Experts
Nick Olsen
Masters Engineering
Level 1 Expert
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
