Question about Cell Phones
Cannot charge my phone comes up 'charger not supported' what does it mean?
  • 677 Answers
Hi, when a phone displays "charger not supported", It is usually caused by the charger.When the charger is damaged it display "charger not supported".The only way to solve this problem is to replace the charger with a new one and the phone will charge normal.
Posted on Oct 05, 2010
3 Suggested Answers
  • 21 Answers
SOURCE: when connected to charger it says 'CHARGER NOT SUPPORTED'
clean the battery contact inside + battery
Posted on Mar 10, 2008
  • 3 Answers
SOURCE: Nokia 3600 not charging (it says "charger not supported")
I had the exact same problem. There is something wrong with the new charger, either the voltage or something... But when i changed to the old Nokia chager (same small pin) It worked. One can prob just deliver it back and get a new charger.
Posted on Jul 11, 2009
Wont' stay on and wont' charge
If your telephone wont stay on and wont charge, then you need to carry out some test to know where the fault is from. First, test your battery if it is working by inserting it in another phone then charging it for about 3 hours then power on the phone to see if it will come on, if it does, then it means the battery is alright. But if it does not come on, then you know the battery is bad and needs to be replaced.
Now test the phone by inserting a well tested battery inside the phone then power it on, if it comes on, then the phone is alright, but if it does not come up, try to prop the battery so it will connect tightly with the terminal of the phone, then power it on, if it comes on, then it means the battery was loose and just need some propping, but if it still does not come on, then there is a problem with the phones power panel.
Test the charger also, by trying to charge another phone with it to see if it will work, if it charges, then it means the charger is alright and if it does not charge, then it means the charger is bad and need to be replaced.
After carying out these tests, you will be able to tell which component is faulty and needs replacement.
Take care and good luck
Dec 29, 2010 | Cell Phones
My phone won't charge
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if the charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Sep 14, 2010 | Motorola Mobility RAZR V3
Charging problem
If you are unable to charge your phone, there are two possible reasons that can cause this, first, i suggest you get a similar charger to charger to charge your phone, if the similar charger charge your phone, it means the charger of your phone is the problem, but if it did not, then it mean the problem is the charging port of your phone.
The charging port of your phone is bad that is the phone is not charging, i advice you replace the charging port of your phone after you have confirm the charger is not the problem.
The problem is limited to two above, either a bad charger or a bad charging port.
Take care.
Jul 18, 2010 | Sony Ericsson W200i Cellular Phone
I put my charger into the lg cookie charger and it wont charge
hi, try using the charger with another lg phone that it is compactible with to confirm if it will charge..if it worked, it means the charger is fine but if it does not it means the charger is bad...also, it could be that the charging port of the phone is faulty...so if that charger charges another phone, it means you will need to change your charging port.
cheers
Jul 01, 2010 | Lands Phones
Sir plz hep me nokia 2626 charger not supported any solution
I advice you try use a similar charger to charge your phone, if the problem still persist, i mean if the similar charger did not charge the phone, it means the charging port of your phone is bad and will need to be replace, i advice you replace the charging port of your phone if no charger charges the phone, replacing the charging port will help and get your phone charging.
Take care.
Jul 06, 2010 | Nokia 2626 Mobile Phone
Motorola L9 no cherging
I suggest you try to use another charger to use another charger to charge your phone, if it does not charge, it means the charging port is bad and will need to be replaced.
You can also use your charger to charge a similar phone to see if your charger is not the problem, if your charger charges the similar phone, it means the charging port of your phone is bad and will need to be replaced.
Replace the charging port and your phone will charge.
Take care.
Apr 23, 2010 | Motorola Mobility SLVR L7 Cellular Phone
The charger slot on the phone does not work when plugged in, think it needs a new port
Why don't you use the charger to charge a similar phone or use a similar charger aside yours to charge your phone to see if it is the charger or the charging port.
If your charger charges a similar phone as yours, it means the charging port of your phone is bad.
But if it does not, the charger is the problem.
If it is the charging port, all you need to do is to replace the charging port and your phone will charge.
Take care.
Apr 21, 2010 | Samsung Instinct Cell Phone
My phone wont charge
Try to remove the battery and put it in a similar phone, charge with your charger, if it charges, it means the charging port of your phone is bad and will need to be replaced.
But if the charger did not charge your phone, it means the charger is the problem.
You can also use another charger to charge your phone to see if it will charge it, if it does not, it means the problem with your phone is the charging port.
Replace it and your phone will charge.
Take care.
Apr 21, 2010 | Motorola Mobility BT50 Cellphone Battery
When i try to charge my samsung icon phone it comes up with an exclamation what does that mean
I believe that means that the charger is not working corectly or it is not supported (If it is a generic charger the second is most likely).
If it is not supported: Then buy one that is form Samsung, not a generic.
If it is not working correctly: Try contacting their costumer service.
Apr 20, 2010 | Samsung Cell Phones
I am getting a message that the charger for the 5310 is not suppo
the charger of your phone is either beginning to malfunction or the charging port.
To know where the fault is coming from, use another charger to charge your phone and if the message still comes up, then you should know that the phone charging port is not good and needs to be replaced.
But if the message does not come up, then you need to change the charger.
I hope you got the message.
Best wishes.
Jan 10, 2010 | Nokia 5310 Cellular Phone
Cell Phones Logo
269 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
