Question about Epson Aculaser C1100 Printer
Get the message service required E527 - Epson Aculaser C1100 Printer
    Guru:
  • Epson Master
  • 452 Answers
E527 is the error of the home position sensor its dirty with toner you should clean it Get the message service required - b0a512e.jpg
Posted on Oct 12, 2010
Service required E527
E527 indicates a developer home position error. With the front cover closed you should be able to freely rotate the cartridge "carousel" from the top with the PCU removed. If it does not rotate smoothly then something is broken and the printer will require stripping completely and the broken parts replaced. If this is the case then it is unlikely to be economically repairable. If the carousel does rotate freely however, then it is one of the following: Either the MCU (engine) Board itself is faulty, there is a wiring fault or the Sensor Rotary Home Position is faulty/dirty. The sensor is the first and most obvious thing to check but it requires taking off the L/H cover and removing the Low/High Voltage power supply board to get at it. I would recommend getting someone experienced at repairing printers to do this, but if you really want to give it a go then follow this link;
http://www.fixya.com/support/t1865287-epson_c1100_service_req_e527
Jul 27, 2009 | Epson Aculaser C1100 Printer
Epson cx1100 e527 error
Please provide the model and the make
Apr 16, 2008 | Epson Aculaser C1100 Printer
Message error E527
What firmware version have you updated to? Check the sensor for the carousel. It could be that the sensor has got a nudged and knocked out of alignment. Remove the PCU and you will see the sensor on the left side above the carousel. Adjust it so it lines up better with the carousel. If it's still bad, check the sensor behind the LV/HV power supply. To do this you will need to remove the two power supply's. If you want a service manual with full details and error code translation get in touch with http://www.TheServiceManualShop.com (cheap as chips!)
Aug 14, 2007 | Epson Aculaser C1100 Printer
Epson Acculaser CX11NF Error 'Service Req E527'
Hi.. To fix the E527 error, close the front panel (cover A) and open the top cover (cover B). With the photoconductor unit removed, the toner carousel will rotate. It only rotates if cover A is closed all the way. You can easily rotate the carousel to a position where you can remove/reinstall the toner cartridge if stuck.
Thanks
jim report_dis_text_13954 = 'We\'re sorry but you must be signed in to report inappropriate material. Click the button below to sign in or register.
  • Sign In / Register »
  • Cancel »
Feb 18, 2009 | Epson ACULASER CX11NF All-In-One Printer
I have a service req E527 error on my Epson printer. how to fix?
To fix the E527 error, close the front panel (cover A) and open the top cover (cover B). With the photoconductor unit removed, the toner carousel will rotate. It only rotates if cover A is closed all the way. You can easily rotate the carousel to a position where you can remove/reinstall the stuck toner cartrdige. report_dis_text_13954 = 'We\'re sorry but you must be signed in to report inappropriate material. Click the button below to sign in or register.
  • Cancel »
Jan 17, 2009 | Epson Aculaser C1100 Printer
C1100 service req e527
Hi-
Try reseating the Photoconductor unit, or for step-by-step instruction to resolve this call 562-276-1300.
Hope this helps
Oct 29, 2008 | Epson ACULASER CX11NF All-In-One Printer
I have a new printer (lexmark E120N Mono Laser) is bringing up a error code, saying service required E527? This machine is only a month old?
it will be better if you ask the vendor for help because your printer is on warranty and they will not charge you anything
Jun 23, 2008 | Lexmark Office Equipment & Supplies
Service req E527 error
Try this (as per Epson Tech Support): To fix the E527 error, close the front panel (cover A) and open the top cover (cover B). With the photoconductor unit removed (as you have already), the toner carousel will rotate. It only rotates if cover A is closed all the way. You can easily rotate the carousel to a position where you can remove/reinstall a stuck toner cartrdige.
I hope this works for you. Let me know please!
May 24, 2008 | Epson Aculaser C1100 Printer
Epson C1100 aculaser
E527 Dev home position sensor error:
Possible causes:
MOTOR ASSY MAG
SENSOR ROTARY HOME POSITION
HARNESS ASSY MAIN
PWBA MCU
LV/HVPS
Apr 11, 2008 | Epson Aculaser C1100 Printer
xfa podria decirme k parte de sensores o motor esta para cambiarlo en mi impresora epson aculaser C1100 el service req E527, y no se puede hacer nada, ayudame xfa mi correo es dayeralb3@hotmail.com, de antemano le agradesco su gentil ayuda
dayer...
Mar 05, 2008 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer Logo
467 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
