How to install sound system for big halls? - Audio Players & Recorders
  • 32,281 Answers
I suggest you get a professional installation because depending upon what type of equipment you need, microphones, amps, record and play back devices and speakers etc. The various pieces of equipment needs to be matched for best performance. The placement of speakers and microphones to reasonable audio levels without acoustic feedback problems. All this requires a professional especially for a large hall.
Posted on Oct 05, 2010
2001 saturn lost keys to it. Got it to crank cut right back off secrity lights on bought a brain box for it and got 2keys with it. Still want crank I need to know what to do t could the box be bad ..
No ,the box is probably not bad , but you need to have it programmed . The dealer is the only one that can do that ? The keys don't matter .
The passlock sensor mounted to the ignition switch assembly is located inside the upper right side of the steering column. The passlock sensor contains two hall effect sensors: a tamper hall effect sensor and a security hall effect sensor. The tamper hall effect sensor is mounted on top of the security hall effect sensor. Should someone attempt to defeat the system by use of magnetic experimentation, the tamper hall effect sensor will activate first.
The passlock system is a vehicle theft deterrent system which deters drive-away vehicle theft by disabling engine operation if the ignition lock cylinder is not rotated with the proper mechanically cut key.
The passlock system is made up of an ignition switch assembly, passlock sensor, body control module (BCM), instrument panel cluster (IPC), and a powertrain control module (PCM).
The ignition switch contains a magnet mounted on the lock cylinder and a passlock sensor assembly which consists of security hall effect sensor, tamper hall effect sensor, and output resistors. A drill proof metal shield is also staked over the sensor housing.
The BCM has the passlock controller integrated into it which controls the majority of the security systems logic. The BCM reads the data from the passlock sensor continuously. If the data is correct and has been received by the BCM within a specified time, the BCM will send a coded password to the PCM. The PCM will then allow the fuel injectors to operate.
The coded password for the security system is sent from the body control module to the PCM via the class 2 data link. If the password is correct and received within the specified time, the PCM will allow the fuel injectors to operate.
Sorry but you can't just replace parts , you need to know how the system works . You need to take this to a ASE certified repair facility that knows how it works .
Oct 10, 2015 | Saturn Cars & Trucks
Maytag front load washer mah9700a
I am not used to this appliance as I am from the UK however:
As hall sensors are used on direct drive machines the hall sensor is located on the back of the drum underneath the big round metal motor part, this will need to be taken off to gain access to the hall sensor. (this is how it works with the LG hall sensors as they are also direct drive)
Apr 05, 2014 | Washing Machines
The sound coming from my speakers connected to the pc sounds as though it is in a big hall.been fine for months suddenly happened,plugged headphones directly into the pc thinking it would be ok and get...
yes what happened? Headphones bypass some circuitry so that you can test if speakers are good or not. You are probably bypassing the DSP which emulates different settings.
Apr 10, 2010 | Dell Vostro 200 Desktop Computer Intel...
I want to have one a/c unit in the hall 15x36feet and also another in a room 10x12feet.can you depute one excutive to study the place and to sujjest how to install .
need to see blue prints, also square footage will play a big role as to size you need in each area, and where you want to place them so copper an drain lines will be able to run, and where you want outsid units.
Jan 30, 2010 | LG LSC121PMA Split System Air Conditioner
On the display it came up as LE in the book it
You have a bad hall sensor or possibly a bad motor which should be warrantied for seven years on the motor. To replace the hall sensor un plug unit and remove back cover. Remove the large bolt on the big round rotor and slide it off of the spline shaft. Look down on the motor where the wires plug into an odd shaped plastic connector. This is the hall sensor. Use a 10mm socket and remove the bolts holding the motor to the machine do not let it fall. Unsnap the hall sensor after unplugging wiring harness and plug new one in SAME SPOT. Reassemble machine and try it.90% of LE codes are hall sensors.
Jan 09, 2010 | LG WM2077CW Laundry XL Front Load...
Humming sound washer won't spin
It sounds like you have a hall sensor failure, if your machine fills with water and then does the buzz thing without the drum ever moving in the cycle.
The Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in the US). Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000
Aug 13, 2009 | LG WM-2277HW Front Load Washer
Hall sensor
No. Actually, the Hall sensor, part number 6501KW2002A, is covered by a 7 year part warranty.
Dec 10, 2008 | LG WM-2277HW Front Load Washer
Need electrical diagram of ignition switch
ac51c05.gif send me a email I will send you the hall system It don't let me dowload the file is to big
Jul 21, 2008 | Jeep CJ5 Cars & Trucks
42 people viewed this question
 Grubhead
Grubhead
