Question about Asrock 775VM800 Motherboard
Asrock 775VM800 not detecting sata HDD and usb port malfunctioning
d2704
  • 101 Answers
SOURCE: Problems with Asrock 775VM800 Motherboard?
try to download and install drivers for VIA USB CONTROLLERS from www.asrock.com
Posted on Dec 18, 2009
  • 1027 Answers
SOURCE: I am using Asrock 775VM800 Motherboard with 80GB
There should be a jumper on the hard drive to select between 3G and 1.5G speeds. It appears that your MB only supports the 1.5G speed.
Posted on May 15, 2010
  • 23 Answers
SOURCE: unable to detect SATA hard dik drive.
Not much info to go on but..
1. Try swapping the connector between SATA port 1 & 2.
2. On boot enter BIOS, if it is recognized as a device in your BIOS then it is simply a formatting/windows issue.
3. Does it show up in windows Device Manager & is the driver installer/working properly? If not, uninstall driver and let it install again automatcally.
4. in control panel under Adminstrative tools open Computer Management, in left-side menu select Storage->Disk Management, it may show up as unallocated drive / disk space, quick format it with NTFS file system.
Posted on May 27, 2010
  • 6 Answers
SOURCE: Today I installed SATA HDD
there is no diffrence between primary & third ide hdd ,if you install nay booteble hdd in master so system try to from that frist . boot sequence of motherboard is try to boot from primary master first then Primary slave then secondary master and then master secondary ..................,
Posted on Jun 14, 2011
  • 1288 Answers
SOURCE: what is the maximum size
I think the actual size of hard drive is unlimited, certainly Asrock make no claims that there is a maximum size. I would however, to be on the safe side, install only a 1TB drive. You could of course get a larger drive and partition it into smaller partitions, which should bypass any possible size restrictions
Posted on Jul 26, 2011
Does the mother board Asrock 845GV (P4I45GV) support pci sata card
If you are trying to install Windows XP then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Nov 19, 2011 | Asrock 845GV (P4I45GV) Motherboard
What is the maximum size of hdd will support for asrock 775vm800 motherboard?
Jul 26, 2011 | Asrock 775VM800 Motherboard
Hi there i have SATA multimedia Hdd 500 gb now i connect it to my computer it dosent detect it , i dont know wat the problem is , do i need to install drivers ?
If you have a SATA HDD that connects with E-Sata, the device needs to be plugged into a power supply as well as the sata port.
If it connects via USB, your computer should just pick it up.
If it is USB and has no power supply, you may need to use a Y connector to plug it into 2 usb ports to get the power it needs
Oct 07, 2010 | Computers & Internet
Unable to detect SATA hard dik drive. on asrock 775VM800 motherboard.
May 25, 2010 | Asrock 775VM800 Motherboard
Asrock Motherboard problems with SATA HDD
It is possible that you are trying to use a SATA II HDD in a system that supports SATA. SATA II devices are not backwards compatible usually,
Dec 20, 2008 | Asrock P4V88 (P4V88 RAID) Motherboard
CPU OR Motherboard
its your motherboard problem if its have a warranty then send it to the asrock service centre if not then repair it
Sep 27, 2008 | Asrock 775VM800 Motherboard
Asrock 775VM800 Motherboard Logo
607 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
