Question about SanDisk Sansa e250 MP3 Player
Please send the process to Sansa e260 Mp3 Player solve the problem of Recovery mode
Hai,
I got the problem to Sansa e260 (4gb) mp3 Player, problem occures message is like "Load main image failed, Switch to Recovery mode". One more problem, In shipment my software installation cd is broken, when i am purchased still no installation & features of software of this product. But I will ask to u Plz send the mp3 player recovery mode and also send the installation cd contain the features of sandisk.
I have trouble trying to install this sansa mp3 to my computer to put music on it and i have itunes so i dont know if it can go on there and my songs can be draged from there to the mp3 sansa of not so i need to know if and how i can install the sansa mp3
Posted on Jun 09, 2008
  • 31 Answers
If your CD is damaged, you can obtain a replacement from Sandisk.
To enter Recovery Mode, turn off your device, ensure the HOLD switch on top is slid to the right (towards the headphone jack), connect the cable to the device (not the computer yet), hold down the RECORD switch on the side, and connect the cable to a USB port on the computer.
If this does not solve your problem, you will need to re-install the firmware.
Try using the Sansa Dispatch to upgrade your firmware. If this does not work, we may need to manually update the device. This is kind of technical and (in most* cases) voids the warranty.
[*in this instance, the word "most" is used to denote "all".]
Posted on May 30, 2008
I formatted my sansa e260 4gb mp3 player and now it says I have zero memory available.
get in recovery mode holding the record button and lock and power on. connect to the computer. a folder named 16mb format. create a new folder sansa.fmt and remove from computer. it will formatted correctly and will work fine.
Mar 13, 2013 | SanDisk Sansa e260 MP3 Player
Sansa e260 doesen't detect 4gb micro sdhc card
I will have to double-check the documentation that came with that specific MP3 player, but I know that some Sansas will only support upto 2 GB in the expansion slot.
Jun 09, 2009 | SanDisk Sansa e260 MP3 Player
My sansa e260 dosent read in the computer
well if you are trying to use itunes, then it won't show up. Only ipods or iphones do.
Nov 17, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e250 white screen
did they send a recovery programme.
Sep 02, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260
Donwload the Sansa Recovery Tool form Sandisk's website
Jun 26, 2008 | SanDisk Sansa e260 MP3 Player
Sansa 4gb mp3 player
perform recovery mode on the player and create a file named sansa.fmt and put that file in the 16 MB format that should reformat the whole player after you have put that file in the drive and unplugged the player from the computer. After that has been done try to update the firmware of the player.
by this u can delete fully and clear
Dec 27, 2007 | SanDisk Sansa e260 MP3 Player
Recovery Mode, Updated Firmware... Memory Capacity Deleted!!!
It probably changed the mode of the player to MTP instead of MSC. There is a setting in the mp3 player for that.
let us know if it helps.
Dec 21, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e280r "not enough space for music db. please free 6mb."
RECOVERY MODE
Switch your Sansa E260 to its Recovery Mode:
1. Make sure the player is powered off
2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface
3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button.
4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode"
5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above)
6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6.
Next, Apply the firmware for the E260 (your player should be connected to your PC at this time):
Step 1:
Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop":
http://www.sandisk.com/Assets/File/Downl...
Step 2:
Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred which caused the player to keep resetting.
Step 3:
When the process is complete, unplug your E260 from your computer, and please make sure you disable the "Hold" switch
Step 4:
Power up your E260 and 90-99% of the time, it would boot up successfully. If not, try to repeat steps 1-4 again.
I hope this helps.
Aug 01, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
106 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
