I need some instructions for use of a Heatline V120 24 boiler
3 Suggested Answers
  • 104 Answers
SOURCE: boiler whining noise
electric boiler- or other ?
Posted on Nov 11, 2008
mrhotandcold
  • 248 Answers
SOURCE: hi. my heatline vizo 24 boiler not working
overheat stat or fan best of luck
Posted on Oct 24, 2009
Need to decrease pressure on a heatline plus 24 vizo? any ideas? also leaking small amount of water under boiler!
There is a pressure adjustment on the gas valve...make sure you set it with a manometer. If the water is just condensate, its ok except if you don't have enough combustion air for the btu rating of the water heater. If it is a leak, replace the water heater
Dec 11, 2013 | Water Heaters
Hetline sargon boiler manuals
my heatline sargon 35kw boiler is showing f1 fault i have drained boiler and cleaned out relivant peaces but still no change any advice in sorting this out
Dec 20, 2010 | Heating & Cooling
To get heat downstairs i have to turn raiators off
Hi check the water pressure in the boiler check the setting / speed of the pump see if this helps
Feb 07, 2010 | Desa International CBN30T Central Heating...
Hi. my heatline vizo 24 boiler not working
Oct 13, 2009 | Water Heaters
Heating pressure gauge goes up
yes tami
there should be a pressure rellief valve fitted.
it also sounds like the heat exchanger is blocked if the hot water is not as good as it used to be and the boiler reaches temperature too quickly then there is scale in the heat exchanger and needs to be cleaned or replaced
Mar 27, 2009 | Water Heaters
Hot water
there are two main faults with combi boilers not giving hot water. one is a faulty flow sensor, the other is the most common which is a blocked heat exchanger caused by debris and scale in the system. this needs to be flushed out or may require a new heat exchanger depending on the age and condition of the boiler some plumbers may suggest a new boiler.
Mar 02, 2009 | Water Heaters
Very Hot water coming out of overflow pipe
Is your boiler heating your domestic hot water if so i would turn water off to water maker and see if your boiler pressure stays down below 20 psi. If so water maker is bad. The other thing that could cause this problem would be the boiler pump is out.
Jan 22, 2009 | Protech Systems FasNSeal FSWMKE4 4" Vent...
No hot water from combi boiler
i have a combie bolier when i turn the hot water taps on only cold water comes out central heating working fine can any one give some advise ?and can i fix it myself.
Jan 03, 2009 | Combi Centre DX - Mango
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
