Question about Nikon F2AS Photomic 35mm SLR Camera
Hello, I recently purchased a nikon F2AS, it was in top condition, except there was no battery in the meter. Installed a new battery, and it occurred to me that the metering in the viewer was not clearly visible. It kind of 'flashed' on and off, like there was an electronic contact point not working as it should. After a few days the meter started to work as it should (clearly visible in the viewer), but now, after a month or so, and with the second film in the camera, it doesn't work at all. I checked the battery, and it's gone empty. I realise that the problem lies within the meter, but is this something that can be repaired at a reasonable cost? Could I possibly repait this myself?
  • 747 Answers
In Canada the cost of such repair would be about $100.00. I'd suggest not attempting the job yourself because the meter and shutter will need to be timed and a repair facility would have the necessary tool for doing this. An internet search will reveal several service places other then Nikon to have this done. I've even seen auctions on e-Bay selling service and had a Canon A 1 serviced. If the camera is in otherwise good condition and you enjoy the creative aspects of a manual film camera then you have a great classic to work with.
Posted on Dec 01, 2010
How ifix a fatal error
Below is a listing of the more commonly experienced processor exceptions ranging from 00 to 0F.
00 = Divide Fault
Occurs if division by zero is attempted or if the result of the operation does not fit in the destination operand.
02=NMI interrupt
Interrupt 2 is reserved for the hardware Non-Maskable-Interrupt condition. No exceptions trap through interrupt 2.
04=Overflow trap
Occurs after an INTRO instruction has executed and the OF bit is set to 1.
05=Bounds Check fault
The array Index is out of range
06=Invalid Opcode fault
This error can be caused by one of the below conditions.
  1. Processor attempting to decode a bit pattern that does not correspond to any legal computer instruction.
  2. Processor attempts to execute an instruction that contains invalid operands.
  3. Processor attempts to execute a protected-mode instruction while running in virtual 8086 mode.
  4. Processor attempts to execute a LOCK prefix with an instruction that cannot be locked.
07=Copressor not available fault.
This error can occur if no math coprocessor is present. This error can also occur when the math coprocessor is used and a task switch is executed.
08=Double Fault.
This error occurs when processing an exception triggers a second exception.
09(OD)=Copressor Segment Overrun.
Floating point operand is outside the segment.
10(0Ah/0A)=Invalid Task State Segment Fault
Can be caused by a number of possibilities as Task State Segment contains a number of descriptors.
11(0Bh)=Not Present Fault
The Not Present interrupt allows the operating system to implement virtual memory through the segmentation mechanism. 0B fault occurs when this segment is not available.
12(0Ch)=Stack Fault
Occurs when instruction refers to memory beyond the limit of the stack segment.
13(Odh)=General Protection Fault
Caused by any condition that is not covered by any of the other processor exceptions. The exception indicates that this program has been corrupted in memory generally resulting in the immediate termination of the program.
14(Oeh)=Page Fault
Occurs when a paging protection rule is violated (when the retrieve fails, data retrieved is invalid or the code that issued the fault broke the protection rule for the processor).
16(10h)=Coprocessor error fault
Occurs when an unmasked floating-point exception has signaled a previous instruction.
17(11h)=Alignment Check Fault
Only used on 80486 computers. Caused when code executing at ring privilege 3 attempts to access a word operand that is not divisible by four, or a long real or temp real whose address is not divisible by eight.
Find out the reason of Fatal Error if that is due to Software related then go in safe mode and uninstall the software recently installed or udate them/patch them. or if the same is related to hardware then unplug the recently added hardware,
please vote
Aug 21, 2011 | Computers & Internet
The spring loaded release knob on d11 finder for F2A broke
Hi there for solve the problem you need to visit camera repair store. Because its hardware damaged and we can not fix it from here. Thanks.
Mar 09, 2011 | Nikon F2AS Photomic 35mm SLR Camera
We put new batteries in a Nikon EM and the light does not come on when battery is check...they are in correctly. Does anyone know how a light meter can get broken?
The battery check is by pressing a very small silver button on the top plate by the shutter release and the little red light come on right? there is only two small button batteries in the EM but without them it's a brick. So look inside the battery compartment and at the bottom you will see a spring piece of metal which the batter makes contact with. If it is corroded then you will have to clean that off to make contact again. Take a new pencil with a new unused red rubber eraser and form a piece of sand paper over the end of the pencil and tape it securely. Lightly twist the pencil back and forth between your fingers to sand off the corrosion, make it shinny. Blow out the dusty dirty stuff with a puffer make sure the batteries are installed correctly. Yes I know you said the batteries were in the right way install the batteries check wiht the battery test button. Also don't forget the EM is a totally battery dependent camera for the meter AND the meter will not work until you have the frame counter at frame # 1 and beyond. My Nikon EM has been slightly modified yours might not be the same but I can close the back and advance the lever trip the shutter and again until it reaches frame one and then the light meter works. Cheers great little camera hope you get it working
Jan 21, 2011 | Nikon FE 35mm SLR Camera
Camera always says Battery Exhausted and turns self off
HI there,
Well it's a error message indicate that the battery is dead and you need to change the battery with new one. you can purchase the battery from nikon store or if you want to purchase the battery online  then follow the below link -
http://www.amazon.com/Nikon-Rechargeable-Batteries-CoolPix-2-Pack/dp/B00008WD8U
Good Luck!!
Thanks
Aug 02, 2010 | Nikon Coolpix 3200 Digital Camera
Nikon F3's light meter always underexposed
needs repairing at a qualified shop
when was it last cleaned or serviced ?
if you think the camera is worthy, since its old how much is it worth to you vs a new one
Mar 06, 2010 | Nikon F3/T 35mm SLR Camera
Old Practica SLR camera shutter not working
I have a practica mtl 50 with a couple of extra telephoto lenses if interested.Very good working comdition.
bob
r_nichols@hotmail.co.uk
Sep 06, 2009 | Nikon F2AS Photomic 35mm SLR Camera
Compatibility with more recent Apple Mac computers
http://imaging.nikon.com/products/imaging/lineup/software/index.htm
You could use virtual box ( unless you want to purchase vmware fusion or parallels ) to run windows or you could use boot camp on one of or both of the macs to run the software
May 17, 2009 | Nikon Super Coolscan 5000 ED Film Scanner
Shutter
This is a fairly common problem with Nikon FE . It is usually caused by poor connection ( usually dry joint ) between the light meter board ( all of this is just under the top cover on the right hand side and the top cover is quite easy to remove ) and the shutter and you fix it by resoldering all the connecting wires between the two.
Dec 04, 2007 | Nikon FE 35mm SLR Camera
Shutter remains open
It may be fatal as there are no parts available for the FE series. The main components that cause this problem are the FRE/ASA unit and the meter itself. The FRE is located under the rewind knob side of the top cover. It is made of glass and can be damaged by impact. The meter is under the speed dial and can also cause this type of problem. Neither is a easy repair.
Nov 25, 2007 | Nikon FE 35mm SLR Camera
Nikon F2AS Photomic 35mm SLR Camera Logo
108 people viewed this question
Top Nikon Photography Experts
Ric Donato
Bart Pulverman
Are you a Nikon Photography Expert? Answer questions, earn points and help others
