samsung tv MODEL CS-21Z58ML.no picture and low brightness problem has been re solved by replace the crt .if you found 4voltage for heater 190volt for scren still no picture you have to replace crt.but some times might be the micro chip on the circuit that its not pushing up the RGB's colors but most and common problem is CRT board.if you'll try to replace the transistors or ic.it will not change any thing.so guys letme know if you fixed it at [email protected] thanks
DLP/mirror chip is going bad. A common problem on Sammy TVs after 2-3 years. Chip is user replaceable (try samsungparts.com or ebay) for about $150-200. Sammy was (last year) repairing the DLP White Spot problem for free. You MUST talk to ECR (executive customer service) to even think about getting that consideration--forget the standard CS people. Don't know if they are still covering this out of warranty in 2010.
Acoustic Solutions 32 lcd hd Tv screen has green/blue contrast shadows all over the light images on the screen. I have tried changing all the picture setting to no avail.
Check and replace the following on the smps:
Cs-860 & Cm-860 1500uf/10v With 2200uf/16v Cm-856,Cm-858,Cs-859,Cs-861 With 1000uf/25v Replaced Cm-854 & Cs-857 With 2200uf/25v
then let me know if it will power on...
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
