Question about HTC Tattoo Cell Phone
Copy contacts to sim - HTC Tattoo Cell Phone
How do I copy contacts from phone to sim card on my Samsung 7272r
  1. Find "Import/Export contacts" Tap Contacts. Tap MORE. Tap Settings. ...
  2. 2a - Copy contacts from your SIM to the phone memory. Tap IMPORT. Tap SIM card. Tap Device.
  3. 2b - Copy contacts from the phone memory to your SIM. Tap EXPORT. Tap SIM card. Tap EXPORT.
Nov 28, 2016 | Samsung Cell Phones
Transfer contcs from a blackberry curve9350 to apple 3gs
u cant transfer it directly but u can transfer them to outlook and when u connect ur iphone to the pc u can choose to sync the contacts with outlook.
good luck
Feb 14, 2013 | Apple iPhone 3G
How do I copy my phone contacts to my sim?
Follow the below mentioned steps :
For many phone models
1. With your previous phone, select Contacts
2. Select Options -> copy all to sim or (mark all files then copy to sim)
3. Select Options -> Copy to SIM direct.or( merge the numbers)
4. select ok then wait till the transfer is complete
Once the contacts have been copied, remove the SIM card from your previous phone, insert it into your new phone, and copy the contacts to your new phone's memory:
5. Select Contacts
6. Select Options -> copy from sim to phone
7. Select Options -> mark contacts for this press all
8. Select Options -> Copy to Contacts
and thats it you are all set.
Jun 12, 2011 | Sony Ericsson K660i Cellular Phone
Have a new Sony Ericson W995 and need to transfer contacts etc from Samsung U900. Instructions advise copying all contacts from sim to phone then put new sim in and copy from phone to sim. Have searched...
First delete all contact from your sim. Copy all contacts from your Phone book of samsung into card card. now your sim card have all contacts of your samsung phone contact list. Put sim into your new mobile Sony Ericson and copy all those contact from sim into phone contact list.you will be doing this by go to copy SIM contact into Phone Book option in your Sony Ericson.
This can also happens: When you put sim in ericson and switch on the cell it will ask you to copy contact from sim to phone memory.here you can press YES and all contacts get copied in phone
If you like solution, plz vote me
Sep 22, 2010 | Samsung U900 Soul Cellular Phone
I have changed from nokia to blackberry bold. all my contacts on sd card - how can I import them to the blackberry contacts
You have the easiest option to copy all your contacts to your sim card and then copy it back to black berry. In order to do this you simply have to go to your phone book options and in the settgings you will find copy contacts to sim and then put the same sim in black berry and select copy contacts from sim.If your contacts are more than the capacity of your sim then you can select the contacts to copy and you have to do this twice or thrice depending on your sim's memory.
Aug 19, 2010 | AT&T BlackBerry Curve 8310 Cell Phone -...
I have saved all my contacts onto my sim from my old nokia ph. I am trying to access them now on my new nokia e65 but they are not there what do i do
HI
To copy contacts from a SIM card to device memory,
Go to contacts--------->select Options----> SIM contacts -------> SIM directory to open the SIM directory.
-------->Mark the contacts you want to copy, or select Mark all to copy all contacts.
Select Options --------> Copy to Contacts.
all the contacts wil be copied to you contact list.
Jul 15, 2010 | Nokia e65 Cellular Phone
I have a Nokia E71 and using SIM from my old mobile phone to transfer contact directory to the E71 phone. I have contacts in SIM directory and put my SIM card in new E71 phone. I still could not get a copy...
open "address book", then press "option"scroll down to "SIM contacts" and press the right-navigation key and select "SIM Directory"
It will display contacts on your SIM card. To copy contacts from SIM to phone memory. Select "Options" then scroll down to "Mark/Unmark" press right-navigation key and select "Mark All" then select "Options" again and then select "Copy to Contacts"
That will copy your contacts from SIM to Phone directory.
Apr 22, 2010 | Nokia E71 Smartphone
Save all contacts to sim card
you can save all your contacts to you sim if your sim memory is not full. Follow these steps:
unlock keypad, select "contacts" option from menu then select "copy" option in "contacts". Selecting "copy" will left you with two options : 1. From sim card to phone.
2. From phone to sim card.
Then select "From phone to sim card". It will ask "One by one" or all.
You can select any option and contacts will be copied to your sim card. If its ask for "delete original" or "keep original" , its your choice to keep copy of contacts in sim card or not.
Sep 14, 2009 | Nokia 5500 Sport Cellular Phone
Want to copy all contacts to sim card
To copy a phone, fax, or pager number from contacts to your SIM card, scroll to
the contact you want to copy, and select Options > Copy > To SIM directory.
Apr 28, 2009 | Nokia 6110 Cellular Phone
HTC Tattoo Cell Phone Logo
1,839 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
