Question about Dryers
Maytag model no: de410 Looking for manual
Cfs Looking for Manual on a maytag dryer model no. de410? We are putting a new belt on our Maytag DE410 dryer. We got the belt on but now the drum is loose. What have we done wrong?
  • Dryers Master
  • 13,433 Answers
I need the 6 digit model number from your dryer.
Posted on May 28, 2008
Maytag electric dryer de410 trouble shooting! How do I remove the cabinet?
There should be an element behind the spin drum,take cover off the back to undo drum.
Jul 26, 2014 | Maytag Dryers
Re Maytag dryer model DE410, serial number 285802, series 01. How much of machine needs to be taken apart to tighten blower fan on end of motor shaft. Thanks. Murray bally.duff@sympatico.ca
Sorry to read about your problem, I hope this helps you out.
all most all of it
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 28, 2010 | Maytag Dryers
How do I change the tumbler belt on a MayTag DE410 Electric Dryer?
simple remove the two phillips head screws at the bottom of the front panel lift up from the bottom and remove the front panel don't forget to unplug the two wires that go to the door switch and set the front panel aside remove the 4 5/16 inch screws that hold the bulk head on remove the front bulk head and set it aside take out your old belt ,put your new belt around the tube and run it around your spring loaded tension roller and around the motor pulley reassemble the dryer and test thats it
Apr 03, 2010 | Maytag Dryers
Changing a dryer belt on a Maytag DE410
in some models you do it from the front the drum sits on 2 bogie wheels and the belt sits behind ,lift drum off bogie wheels and thread belt around pulley it should be on a spring tensioner and it allows you to swing pulley up or down try to thread belt around drum and replace drum back on bogie wheels.... in some dryers you may need to thread belt on drum and then onto pulley good luck
Dec 18, 2009 | Dryers
Belt change on a Maytag DE410
Most of the time these models have screws in the back of the machine on the top lid. You'll need to get over behind the dryer to access this panel. You'll need a "star" type screwdriver (most come in a set). Remove the top lid to expose the drum. The belt will run around the drum and down around the safety cut out switch. This switch is most likely a teflon or plastic wheel that the belt loops around. After installing the belt, replace all of the screws and you're good to go!
Dec 11, 2009 | Dryers
Dryer quit spinning.
If the blower is working, then it's most likely the belt, a belt pulley or a tensioner spring.
Open the dryer, it will power off, and then spin the drum by hand. If it moves with little resistance, it's your belt.
Dec 11, 2009 | Maytag Dryers
Belt broke on Maytag dryer DE410. I purchased a
The squeak may be coming from the drum rollers, check them to see if they need lubrication.
I recommend that you use a good grade of machine oil to lube them such as 3 in One oil. Lube them at the shaft of the roller. Also check the rollers to see if they have flat spots on them, if they do then they will need to be replaced.
Recheck your location of the idler arm bracket with pulley to see that you have it in the right location and that the spring is also in the right location. Look for wear spots on the frame and idler arm and match them up.
Good Luck,
I hope this helps
Oct 12, 2009 | Maytag Dryers
Maytag DE410
Replace the drum seal. To do this you need to get under the machine and start removing the pieces, IE pulley, clutch, brake. Until you get to the main bearing and the seeal. At the same time check to make sure that the bearing is still good since the seal has blown
Feb 13, 2009 | Maytag PYE3300 Dryer
Belt replacement for a Maytag dryer - Model No. DE410
Peace Friend,
ngfam1 At your service!
There are many variables!
Every year thousands of people die trying to repair electrical appliances them selves!
You are worth more than that!
Bless you!
Only a trained laundry tech can make the electronic diagnoses.
Below I referred you to a great service nation wide!
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505 near me they only charge $75 service call which is reasonable in today s market!
Unfortunely, another point to consider!!
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm1
*****PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF*****
Sep 02, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer stopped working
does this drum go round, if not replace the capacitor which in most models is fastened to the main motor, if this doesn't cure the fault you could be looking at a replacement motor, assuming you have checked for any jamming of the drum, does it rotate be hand as well a working motor will just buzz if the drum is jammed hope i have helped, if so please rate me well
Oct 06, 2007 | Dryers
Dryers Logo
363 people viewed this question
Top Dryers Experts
