Question about Zanussi ZWD12270 Front Load Washer / Dryer
Hello.i have washin machine zdw12270w1.my module not working.could you tell me where i can buy or repair module?
I need buy panesonic full automatic washine machine drain water system
Are you asking about the washing machine or a drain for the water in the machine?
Sep 02, 2014 | Washing Machines
Ariston ar6f105 washin machine not working
Machine start normally but after some time it display H20 and stop. When i switch off the power it restart but again after few minutes it is same. Kindly help.
Aug 18, 2012 | Ariston Technologies Washing Machines
What does the LE code mean on my washine machine and how do I fix it?
Welcome to FixYa.
I have a suspicion of what may be at fault, but the easiest way to explain the problem and solution for the LG washer "LE" error is to direct you to my repair tip page.
Click on the link here and you should find the info you need to diagnose and ultimately repair your washer.
http://www.fixya.com/support/r8488460-lg_washer_le_error
Hope that helps resolve your troubles. good luck.
Regards,
Macmarkus :)
Apr 08, 2011 | LG Washing Machines
It works only 10 min and then stops the energy in the house. whats the problem?
Hello
Either the circut breaker for that receptacle is too small,or you need to unplug somthing in the washine machine circut,lamp,iron, what ever.
If it continues you may need to upgrade your circut breaker to a 2o amp.
Apr 04, 2011 | Washing Machines
MY WASHINE MACHINE DOES NOT SPIN
hello. andrew check the pump first it has drain before it spins if the pump is ok then the cause could be the module board this sits at the back of the machine usually has a load of wires coming off it hope it helps
regards
shaun
Mar 12, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Tumble dryer not working
SOUNDS AS THOUGH YOUR HEATER ELEMENT HAS GONE..
IT IS POSSIBLE TO FIX IT YOURSELF BUT VERY COMPLICATED, CALL OUT FROM A REPAIR PERSON IM AFFRAID, COMBI WASHER/DRYERS ARE RENOWNED FOR THIS & ALSO BEARING KITS
May 22, 2009 | Indesit W 123 Front Load Washer
Leaking out of the bottom
The water drainage pipe is probably tampered. You need to replace it. Take apart the washing mashine and find the drainge pipe. If it is not tampered, some pipe is loose or broken in the washine mashine. If all this is too hard, call a repair man to fix it.
Apr 07, 2009 | Washing Machines
MY phone got wet. NOw my SGH-t819 says DOWNLOAD. POST COMMENT NOW
Give it a week to fully dry out. If it doesn't work then it will never work again. Cleanliness is next to Godliness but ................................
May 08, 2017 | Samsung SGH-t819 Cellular Phone
Washine mashine aggitator
Rob, sounds like you need an agitator repair kit. Not a hard job, under the dispenser cap you have a set of ears, spring and plastic bearing. The kit is cheap, you can find it here http://www.repairclinic.com/0080.asp Catriver...post back
Dec 03, 2006 | Kenmore 15864/15862 Top Load Washer
Zanussi ZWD12270 Front Load Washer / Dryer Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
