Question about Whirlpool Duet GHW9150P Front Load Washer
Washing machine won't turn on
I have it plugged in and have power to the outlet. all hoses are connected. the lock button will come on and off if pushed and held for 3 seconds but can't get any other buttons to light up and turn on.
  • kcalleja Oct 11, 2008
    I just experienced the same problem this evening, sears will come to look at machine its not even one week old.
    Stop working after one use, no power. I hear the start button but no lights come on. What could be the problem?
    Problem Solver:
  • 7 Answers
REPLACE THE CONTROL PANNEL IF THIS IS A HE3- HE5, IF IT IS A DUET MODEL CHANGE THE COMPUTER BEHIND THE CONTROL PANNEL
Posted on Jun 01, 2008
I was getting the F H error code on my washer. I hit cancel twice to clear the code to see of a cycle restart would remedy. Now the wash cycle is stuck on 45 min. remaining & the cancel button is no...
The FH error code on your Kenmore Elite washing machine is an indicator that there is a problem with incoming water. When there is little water coming into the machine, the FH code will appear and the washer will stop. There are a couple of common problems you can check while you are resetting the FH error code. You will need to remove the power supply to the washer to reset the code.
  • 1 Look for the "Pause/Cancel" button on the washer control panel. The button will be below the digital time clock and to the lower right of the wash cycle selector.
  • 2
    Press the "Pause/Cancel" button twice to cancel the wash cycle. Unplug the Kenmore Elite washer from the wall outlet.
  • 3 Check for kinks in the water supply hose while the washer does not have power. Turn off the water supply spigots and remove the hoses from the back of the washer. Check the port screens at the hose connections for sediment buildup and clean as necessary.
  • 4
    Connect the water supply hoses back to the washer and turn on the water spigots. Plug the washer cord back into the wall outlet.
  • 5
    Select the wash cycle and press the "Start" button.
  • Apr 29, 2013 | Washing Machines
    Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
    see this causes and fix it. God bless you
    Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
    Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
    User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
    Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
    Line Fuse If the washer won't start the line fuse might have blown.
    Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
    Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
    Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
    Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
    Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
    Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
    I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
    seethis causes and fix it. God bless you
    Oct 02, 2012 | Crosley CCW5294W Top Load Washer
    When you push start button nothing happens
    Sep 28, 2012 | Washing Machines
    We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
    I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
    If you banged the water inlet valve in moving it back, it might be damaged.
    Suggest you unplug everything and start over.
    Sep 04, 2011 | Frigidaire FEX831F Top Load Stacked Washer...
    FH appears
  • 2
  • 3
  • 4
  • 5
  • If the error code come back you will probably have to change the water inlet valves. No hard to do and you can fdo this yourself
  • Dec 14, 2010 | Whirlpool Washing Machines
    Whirlpool Duet WFW9400S - Nothing works but lock button
    YOU HAVE A PROBLEM WITH THE CONTROL PANNEL. REPLACE CONTROL PANNEL AND YOUR PROBLEM WILL BE RESOLVED
    Jun 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    211 people viewed this question
    Dan Webster
    Dan Webster
    Mike Cairns
    Mike Cairns
    prem mathew
