I have a philips tv 17PT1565/01 model locked.i do not have the original remote,is there a way of unlockin it using only the volume,program buttons on the tv?
jyackle5
  • 8197 Answers
SOURCE: need codes to program tv, dvd, receiver to philips remote
Here is a couple of links you can go to.
You will nood the remote model for this one.
http://tv.manualsonline.com/manuals/mfg/philips/philips_universal_remote_product_list.html
This one you do not.
http://www.universal-remote.net/philipsmagnavox.html
Good Luck and Please Rate FixYa!
Posted on Dec 31, 2008
dsacco86
  • 1077 Answers
SOURCE: Direct TV remote does not control TV on/off or volume.
I have the same setup like you. Direct TV and Emerson LCD TV. The Direct TV remote stores a limited amount of codes and none worked on my TV. Sadly it's not something you can update. They seem to only stick with the popular codes. Welcome to the "head of the curve" like me. lol
Posted on Jan 12, 2009
Pellepeloton
  • 55 Answers
SOURCE: The on/off button on my original remote is faulty.
You can repair the remote control yourself according to my instructions here:
http://www.instructables.com/id/Repair-your-remote-controls/
Posted on Jul 26, 2009
SOURCE: have a philips universal remote need to program a maxent tv
flickering tv
Posted on May 03, 2010
hi! i have here a couple of codes for your tv, just try them, 1468, 1004, 1011, 1013, 1025, 1028, 1031, 1033, 1036, 1044, 1045, 1080, 1097, 1101, 1102, 1107, 1382, 1383, 1483, 1484, 1512, hope this helps!!!! goodluck!!!!
Posted on Jun 06, 2010
My philips srp5107wm/17 only changes the volume on my tv no matter what device i have it set on
The Philips remote is set to "push trough" the volume/mute to the TV for devices that typically don't have a volume function. Older versions of Philips remote used to allow you to select the device to push volume to, but for some reason this is no longer available (or at least I haven't found out how to). So here is the solution I used.
Teach (learning function) the remote to use whatever device you like for volume/mute.
1, Press the button for the device you would like to change
2. Hold down "learn" and the button you want to teach ex. "volume up" until the red light comes on
3. Place the original remote of the device you would like to change the volume on 5-10 cm away from your Philips remote and press "volume up" for this example
4. Repeat these steps for the "volume down" and "mute" buttons
5. Repeat these steps for other devices you would like to "push through" volume/mute to a device other than TV
Hope this helps others. I did find that some devices like SAT may not allow you to change the volume/mute, but otherwise this workaround does the trick.
May 05, 2012 | Philips SRP5107WM - Universal remote...
I am using a Philips SRU3003WM/17 Universal Remote with my Sylvania TV Model number 64119E. When programming the remote some strange numbers appeared on the screen and now I cannot get them off. The...
Well your Philips universal remote control comes with a list of codes for devices by brand name.
Find the first code for the brand name and type of device you wish to program. Turn all of your devices off, and then manually turn on the device you want to program.
Press the Setup button on your the universal remote and continue to hold it down until the indicator light stops flashing and remains solid. Release the Setup button. Press the Mode button for the type of device you want to program on your Philips universal remote, such as the TV.Release it immediately and make sure the indicator light is illuminated. Enter the first possible four-digit code on the universal remote, and then press another button on the remote to see if the device is now programmed, such as the volume control or power button. If the device responds, you have successfully programmed your Philips universal remote. If not, turn the device off and back on and follow the steps again using the next code on the list. Repeat until the device successfully responds.
If your TV code is not listed on the manual then you can use the Remote Using Code Search Option -
Your Philips universal remote has a built-in code search feature that will find the correct code for your device. This process may take longer than using direct code entry, but can be helpful if you do not have access to the code list or if the brand for your device is not listed.
Make sure all of your devices are turned off, and then manually turn on the first device. Press the Code Search button and hold it down until the red indicator light stays illuminated. Press the Mode button for the type of device you want to program on your Philips universal remote, such as the TV button.  Release it immediately and make sure the indicator light is illuminated. Press either the Channel button until the device responds. You may have to press the button up to 300 times. Each time you press the button, the Philips universal remote tries a new code. When the code works, press the Mute button on the Philips universal remote and the code will be stored.
I thing you wrongly do the second option that creates the problem. No issue, if your tv code not listed on the manuals then you can go with the second (code search) solution. Please post comments for further help or information.........
Good Luck!!
Thanks
Jul 31, 2010 | Televison & Video
I have a philips I got from a hotel but i cant program the channel to 3 to hook up a dvd player even with a universal remote what do i do?
Channel 3 is probably locked out... here is how to fix it....
1) Press the Menu button on the remote or press both Volume buttons on the front of the TV to access the TV's internal menu's
2) Scroll to highlight INSTALL using down arrow on the remote or Channel - on the front of the TV.
3) Press the Right Arrow on the remote or Volume + on the front of the TV to access the INSTALL menu.
4) Scroll to highlight Channel Edit using down arrow on the remote or Channel - on the front of the TV.
5) Press the Right Arrow on the remote or Volume + on the front of the TV to access the Channel Edit menu.
6) Use the Left or Right Arrow on the remote or Volume + / - on the front of the TV until you get to Channel 3.
7) Use the Down Arrow on the remote or Channel - button on the front of the TV to select SKIPPED.
8) Press the Right Arrow on the remote or Volume + on the front of the TV to select OFF.
9) When finished press Exit on the remote or press the power button on the TV and then power the TV back on.
You should now be able to use channel 3.
Good Luck....
Jan 15, 2010 | Philips 20PT6441 20" TV
I cannot auto program tv
Only a universal remote of Philips has the 2 buttons to use the autoprogram,all other won't work.
Aug 29, 2009 | Televison & Video
New RCA RC246 remote with new RCA L40FHD41 TV. Dish remote won't adjust volume. Any ideas?
The Philips Universal Remote SRU4208WM/17 works with this TV. Must use the code learning feature.
Jul 12, 2009 | Universal Remote Control DIRECTV Universal...
Unlockin all the channels
In order to get all the channels u have to have the original remote or a universal remote that has a menu button, an enter button, and directional pad (the directional pad cannot control the volume and channels it must be for navigating). push and hold the menu button, the menu will appear then disappear, once it disappears release the button and enter 9876 then press enter. a different menu will appear and it will b three black lines, one at the top of the screen, one in the middle and one at bottom. the middle line has 3 sections the first part is the item number the second part is the description and the last part is the on/off switch using either a 0 or 1. push down on the directional pad until u get to the 00 factory settings 0 and change the 0 to a 1 with the right button on the directional pad. then scroll up to 20 channel lock 0 (i think its 20, it may be like 22 but it is in the twenties for sure) and change the 0 to a 1. then go back down to the 00 factory settings and change the 1 back to 0 then turn the tv off. when u turn the tv back on it will either automatically ask u to auto tune or u will have to go to auto program to program the channels. there are like 80 different menu items, be sure not to mess with any other ones unless u know what ur doing, u could cause ur tv not to function properly or even be able to turn on.
this problem frustrated me greatly and im very happy to help whoever i can with the solution
Feb 07, 2009 | Zenith C27A24T 27" TV
No remote, channels locked on smart tv
On this set, the volume buttons are the same as the menu button on your remote. The two channel buttons work the same as the scrolling arrows on your remote. It will take some practice, but to turn on the menu, press both volume buttons at once. Then practice using the volume controls to scroll. Once you have the hang of it, you can simply use these four buttons the same way you would have used your remote. If you cannot figure it out on your own, come back here, let me know, and I will sit down and map it out completely for you.
Hope this helps in some small way!
Jan 30, 2009 | Philips TP2784C TV
Tv has child safty lock on cant turn on to program remote
take ur tv to a local tv repairman, they will have a magnavox remote. use it to simultaneously press the tv/av button and the enter button.
Dec 28, 2007 | Philips PH-BIG3 Remote Control
Tv is locked
hi guys got same tv same prob......finally after hours of frustration found a solution.
steps:
  • Turn on tv
  • Press and hold the menu button (you will hold this through the next few steps till the menu comes up)
  • turn the tv off using the silver button on the back of the tv
  • push the button back in on the back of the tv
  • tv should come on and bring up the menu
  • using the channel and volume get to the menu with the v-chip controls there should be a reset menu button change it to on.
  • turn off tv using power button on front of tv.
  • turn it back on and problem should be solved
Sep 08, 2007 | Televison & Video
Televison & Video Logo
119 people viewed this question
Top Televison & Video Experts
Electro Med Services...
