Question about Samsung LE40M91B 40 in. LCD TV
While in stby mode I push the power button in the telecontrol and it opens and closes many times before opening
2 Suggested Answers
sunrisenohch
  • 95 Answers
SOURCE: DVD disk tray will not open at all
Usually 90% malfunction main Board 10% power Board
Posted on Mar 27, 2015
Dell 8200 beeps 10 times monitor won't come on says power saving mode
Hi
Remove the sound card and blow the slot with dry air to rid off dust.
Examine it to make sure nothing's damaged and fix it again.
Checkout the RAM's.Probably remove them,wipe the slots off dust and fix them again.Make sure they're well seated on their slots.
Feb 05, 2012 | Computers & Internet
Change the time
You must enter Standy mode to adjust the clock. To do this Press the (SRC) button. Select the "STBY" display
1. Select Clock Adjustment Mode Push the Control knob (the one on the right) towards (FM) or (AM) Select the "CLCK ADJ" display.
2. Enter Clock Adjust mode Press the Control knob for at least 1 second. The clock display blinks. 3. Adjust the hours Push the Control knob towards (FM) or (AM). Adjust the minutes Push the Control knob towards ( '>' ) 4. Exit Clock adjustment mode Press the (MENU) button.
Nov 09, 2010 | Kenwood DPX-301 CD Player
Cdr drawer won't open on Philips cdr 800.
looks like the rotor is jam or broken,try to unscrew it and open the top cover so you can see the rotor and then plug it in to the power source ,then always press the open/close button and check the rotor if its jam or broken and see what happen.
Jun 06, 2010 | Philips CDR800 4-Disc CD Recorder
I bought a new Keyless remote for a 2007 Forester from a Subaru Dealer to replace an original one that went bad after 2 years. I have followed the directions in the owner's manual to program it, but can't...
IMPREZA: 2005, 2006, 2007 and
FORESTER: 2005, 2006, 2007, 2008
Check for Immobilizer key on Forester XT models only.
information is always subject to change and correction imp05keylessremote1.jpg
new remote for 2005 Imprezas.
This is not the same remote as the 05 Legacy/Outback remote which also has truck/gate release on the front and a red panic button on the back.
Lock: press Lock button for 2 seconds or so to lock car, and arm optional security system. The car with chirp once and turn signals flash for locked, 5 short chirps and signal flashes if any door is not fully closed. The dome light goes on for 15 seconds and ignition key ring (if present) will light for 30 seconds when unlocked.
Unlock: press unlock one time for driver's door, press again within 5 seconds to unlock all doors inkling rear gate (wagon). The system does not open the trunk.
Panic mode: press and hold lock button for approx. 3-4 seconds to activate Panic mode. I panic model the horn honks and turn signals flash until either the lock or unlock button is pushed again.
Finder mode: Press lock button 3 times within 5 seconds to activate Vehicle Finder mode. The horn will honk once and the turn signals will flash 3 times
Distance: works within approx. 30 feet depending on battery strength, nearby concrete walls and etc.
Audible Chirp On-Off: the system will chirp when locked or unlocked. To turn OFF the chirps, unlock the door and then push both lock and unlock buttons at the exact same time for 2+ seconds. There will be 2 chirps indicating the the audible is off. To turn the chirp back on, repeat the process and the system will chirp one time when it is back on.
Battery: as the battery ages it will only work as you get closer to the car. When a battery is replaced, the transmitter must be re-synchronized with the Keyless control unit. To synchronize, press the lock or unlock button 6 times.
Programming: 4 codes may be programmed.
Sit in driver's seat and unlock all doors. Open and close the driver's door
Turn the ignition key from LOCK to ON position 10 times within 15 seconds. Be sure to stop at both lock and on. The horn will HONK once to indicate transmitter programming mode is activated. Leave key in LOCK position and don't remove it from ignition.
You now have 45 seconds to complete the programming as below.
Open and close driver's door again.
Push either lock or unlock button on the remote you want to program. The horn will honk 2 times when successful.
To continue and program other remotes at the same time: open and close the driver's door and push lock or unlock on the remote. The driver's door must be opened and closed between each remote you want to program.
Done programming? remove the key from the ignition and the horn will honk 3 times.
DELETE old codes? Reprogram 4 times, it will overwrite old codes.
Alarm Security System: optional on all models. When locked there is one chirp (can be turned off, see above), the turn signals will flash and the red 'security' light will start to flash once every 2 seconds except for STi which flashes twice every 2 seconds.
There will be 5 chirps if a door, hood, and trunk or gate is not fully closed
You can also arm the system by using the power lock button on the driver or passenger door as you get out of the car and then closing the door behind you.
Disarm the system: push unlock for 2 seconds
Lost remote, alarm activated? When you can't use a remote to turn off the system: open the door with a key or try to start the car and the horn will start to honk. Turn the key on-off 3 times within 5 seconds and the alarm will go off and you can start the car. It's simple!
VALET mode: To set valet mode or just to disable the security alarm system: 1. unlock all doors 2. physically open the driver's door 3. hold the UNLOCK button on remote for 2+ seconds. The red 'security' light will then flash 2 times a second until the car is turned on.
System has been Tripped (except for STi): if you unlock the door with the remote and it chirps the signal light flash 4 times, the system has been triggered;
Identification mode: To find out what happened and why the system was triggered:
Open and drivers door, leave it open. Turn ignition key from LOCK to ON 2 times and then leave in LOCK position.
Tripped code: 1 security light flash: a door has been opened, 3 flashes when the impact sensor was triggered, 4 flashes when the ignition was messed with or battery disconnected
Nov 19, 2009 | 2007 Subaru Forester 2.5X L.L. Bean...
Toshiba MT200 videoprojector won't start
if there are no leds lit on the top, the power supply is gone. if there are leds on the top, which ones, are they blinking, how many times, and what color?
Sep 01, 2009 | Toshiba TDP-MT200 Multimedia Projector
When I turn on the tv, green light blinks for a
Its your ballast. it has as short. i recommend changing the ballast. while you are inside the set, i would run a break point test on the power board to be safe but, im sure its the ballast.
Mar 09, 2009 | Televison & Video
Chrysler T&C Power Door Problem
If it stops in roughly the same spot every time, and won't respond after it has stopped, it sounds like a broken wire. It is likely losing its electrical current to run the motor. It should be right where the track bends when the door has stopped. Check for loose or frayed wiring inside the flexible plastic track just below the door. The wires will often wear after being bent over and over again. If you find a broken bit of wire, cut out that section and splice in a new length of wire. Be sure you do a good job splicing, or you may end up with the same issue again soon. I am not a mechanic by any means, this just makes sense to me, and I'm considering buying an 01 town and country with this issue, which is why I'm on this site to begin with. Best of luck -
Jan 22, 2009 | 2008 Chrysler Town & Country
FW-R7 displays "Locked" when attempting to open CD Trays
You were close, but didn't explain it very well. If you push on the 'DISPLAY' button (left side of machine as you are facing it, about half way down) when the unit is off, it will say something like "DEALER MODE", push it again to return it to regular mode. You may have to press and hold the button to get it to display 'DEALER MODE', then when everything is normal, "DEALER MODE" just goes off and isn't replaced by anything. Hope I explained it well. nyati585@aol.com
Feb 09, 2007 | Philips FW-R7 CD Shelf System
Open Questions:
See all Samsung LE40M91B 40 in. LCD TV Questions
Samsung LE40M91B 40 in. LCD TV Logo
20 people viewed this question
Jerry Greenberg
Jerry Greenberg
