IN Technics SH-GE90 equalizer how can we set memory. I mean user 1, 2, 3, 4 and 5?
2 Suggested Answers
rommelalilin
  • 2178 Answers
SOURCE: I have technics reciever sa ax 6 (without tape
Click here.
Posted on Nov 23, 2010
Technics SH-GE90 DSP gives off high pitch sound, no display in the window,only the red dots down the side and the demo button dose not change demo modes.
Check power supply capacitors.
These are prone to leakage on the SH-GE90 and can cause various
symptoms such as no display or in some cases a flickering display.
Dec 12, 2012 | Technics SH-GE90 Home Equalizer
Good day...My unit works 100%...i just wanna know why the two vertical red lines on the display flashes. Never did it before. Any reason for this ?
The 2 larger power supply capacitors need replacing.
These are prone to leaking on this particular model and cause
the display to flicker.
Depending on how bad the leakage, if you take the lid off you
may see evidence of this around where the power transformer lead
plugs into the main PCB.
Aug 18, 2011 | Technics SH-GE90 Home Equalizer
I bought SH-GE90 DSP And I pluged into 240V source while the indicator was on 110v and now its not working will replaceing the transformer will help or it just simply gone.
It is not possible for us to be able to determine the extent of the damage. It is possible that only the fuse has been damaged. It is also possible that the rectifiers have been dmaged. The bottom line here is that there needs to be some examination of the unit and some testing of the internal components. The best case will use parts in the $5 range. Worst case you are looking at $50 or more in parts. If the cost is not too high, take this to a servicer and ask for a detailed repair estimate.
Dan
Dec 02, 2010 | Technics SH-GE90 Home Equalizer
I have a Technics Stereo graphic equalizer. Trying to find out why it's not getting any power. it has no fuse inside. I hook the plug into the outlet and nothing. atleast the light on the equalizer does...
The power supply unit has failed in your equaliser. If it is the main transformer check for the continuity of the primary and if open you will need to replace with the same one or rewind with the same parameter.However if the thermal fuse is blown you can short the winding with a fuse wire. Also check on the dc side for any fusible resistors that would have opened out. Hope you check this out. Good day
Aug 03, 2010 | Technics SH-GE90 Home Equalizer
The dislay flickers SH GE90.technics .it seems to be a common fault.. can this be fixed
replace the 3 electrolytic capacitors in the power supply section near where the lead from the transformer connects to.
they're sat side by side.
you may notice only 1 might be leaky but replace all 3 for good measure.
i've had quite a few with exactly the same fault and all were cured by replacing the above.
hope this helps?
Mar 11, 2010 | Technics SH-GE90 Home Equalizer
Having a hard time connecting various audio components
Yes, it is a little tricky...
1) CD Changer (output) -> CD input on Amp
this is tricky... this will allow you to record to your tape deck, and control the sound via the EQ:
2) Tape Deck (tape out / recout) -> TAPE PLAYBACK on EQ
3) Tape RecOut on EQ -> Tape 1 Playback on Amp
4) Amp Tape 1 RecOut -> Tape Deck Playback / Input / RecIn
in essence, your creating a loop starting from the tape deck, going to the eq, then to the amp, then back to the tape deck to record.
Your EQ has another set of LINE IN and LINE OUT - use the second Tape 2 on the amp to create another loop. This will
allow you to control the EQ for any of the other sources.
5) LINE IN on EQ -> Tape 2 RecOut
6) Tape 2 Playback on Amp -> LINE OUT on EQ
5) Radio Tuner (output) -> Tuner input on Amp
6) DVD/VCR Combo Output -> AV/AUX on Amp
7) PC Computer... you don't have room for this. You can either use the PHONO input, and you'll have to purchase a Line Level Phono Converter
or, get a Y cable and split the signal and share with some other source.
Hope this helps.
- OPTiC
www.djproaudio.com
www.repairny.com
Dec 13, 2008 | Technics SH-GE90 Home Equalizer
USER MANUAL NEEDED
Hi - You can download the manual from the link underlined in blue below:
SH-GE90
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 28, 2008 | Technics SH-GE90 Home Equalizer
56 people viewed this question
 Grubhead
Grubhead
