Question about Brother MFC-425CN Multi-Function Center All-In-One InkJet Printer
My brother MFC425CN black ink does not work...but the colored inks works perfect, i tried to replace the black catriage and i also tried cleaning it several times but still does not work...
  • Brother Master
  • 378 Answers
This could be several things, some of which may mean your machine will have to be repaired by a Brother agent (probably cost you more than a new one), and/or it's time to bin it.
However, sometimes it's just because the print head, or the pipes that connect the ink tanks to the print head, have become blocked with dried out ink.
If you search on YouTube, you will find a few videos that show how to clear such blockages - you may not find your exact model number, but many Brother machines use almost identical components to many others so the basic technique will be the same. Also search on Ebay for printer cleaning/head blockage kits - quite a few printers (not just Brother) suffer similar problems and a few businesses have sprung up on EBay that sell kits to help you sort this. They sometimes have links to a video they have produced showing how to use the kit which can give you ideas. Again, your exact model number or even make might not come up but these kits might be adaptable to your machine. Got to be worth a tenner or so before binning it ! Good luck
Posted on Oct 05, 2010
Won't print black
TRY CLEANING THE INK CARTRIDGE. If it doesnt work, go to service center with the printer.
Jun 30, 2012 | BROTHER INTERNATIONAL CORPORAT BROTHER...
BLACK INK IS NOT WORKING
May be problem on your printer head nozzle jam.So you should to need clean or replace.If itself clean with worm water or other way clean all surface in on nozzle with tissue paper.With the best luck.
May 15, 2010 | Brother MFC 490cw Color Inkjet...
I have a brother MFC-490CW and replaced the black ink, and my color ink has run out. It will not let me print as it says ink is low, so it won't even let me use the black? How do I print with only using...
By design, Brother printers stop all printing when one of the cartridges is empty. This is done to avoid cleaning cycles sucking air into the system, which could possibly damage the printhead.
Even if you print in black only by changing the print settings to "Mono" or "Grayscale" to avoid printing in color, cleaning cycles would still **** air from the empty color cartridge because they are programmed to clean ALL the ink nozzles. The only way to continue printing is to replace the empty ink cartridge(s).
After replacing the empty color cartridge, you could print in "Mono" or "Grayscale" to make better use of just the black ink.
Jan 21, 2010 | Brother MultiFunction Center MFC-440CN...
I replaced the black ink cartridge, Innobella, LC61Bk, all correct, for the first time in my MFC-990CW Brother fax, etc.times 3!!!! And I get "white" lines through the text. Yes, I have gone throught the...
i HAVE A lc61 SERIES BROTHER INNOBELLA AND I AM NOT ABLE TO PRINT. wHEN I TEST THE PRINTING I GET ALL COLORS BUT BLACK ON THE TRIAL DEMO I TRIED CLEANING BUT IT STILL DOES NOT WORK WHAT CAN I DO???
Oct 16, 2009 | Brother MFC-990CW COLOR INK-JET MFC Ink...
Black ink is not dispensing
There may be an air bubble in the black tubing, it will take several more cleaning cycles to clear. You can tell it to clean only the black and save the other inks.
Jul 01, 2009 | Brother MFC 490cw Color Inkjet...
I have a Canon printer/scanner MP210. I ran out of black ink, though at the time, the color ink was working perfectly. I replaced the black ink cartridge and the printer now prints in black perfectly. ...
First try a hard reset - Unplug printer from power supply, wait 2 minutes and replug and see. If that doesnt work, try uninstalling and reinstalling the printer driver and software. Also ensure that the cartridge is properly seated in the holder.
Oct 10, 2008 | Office Equipment & Supplies
I admit it, I used cheapo refill ink! Now the black section of the print head doesn't work...
I'm afraid there is no real sucessful way of cleaning these print heads, tiny micro filters built into the head unit will blocked. I have never unblocked one fully.
Fix is to replace head
These heads are not easy to fit, then once they are you must program in the head id and run a purge with four gen inks, this purge uses like 1/4 of each ink.
Recommennd you replace printer it is cheaper to
LINK to UNRECOMENDED removal of head
I dont have the 420 cn listed but here is link to mfc425cn head info so you can see how much they are not worth buying
below is pic of head
2d7dc76.jpg .
Jan 13, 2008 | Brother MFC 420CN All-In-One InkJet...
Black ink won't print at all
Run the cleaning process a couple of times.  The printhead might have gotten sucked dry.
Oct 30, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother problem
Did you use third party ink? If the ink is pigmented the filter in front of the printnozzels is clogged and cant be cleaned any more. What you can try is to buy a brand new original brother ink cart and do the cleaning 3 times. After that do a testsheet printing. In case its OK, your lucky and it was a problem of the cart. If you cant see any blocks (with the original ink used!!!) the printhead is crashed and has to be replaced (BTW: Its cheaper to buy a new mfc)! Do use only dye ink for brother printers!!!
Sep 10, 2007 | Brother MFC 210C All-In-One InkJet Printer
Black ink not working; but colors are
Use a original brother ink cart. Do the cleaning twice. If there is no more black blocks to see, the printhead is crashed!
Aug 25, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-425CN Multi-Function Center All-In-One InkJet Printer Logo
186 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
