Abort!!! code 0x0000999a konica minolta printer what is the solution.. plz help
  • 3 Answers
SOURCE: c451 Bizhub Konica Minolta printer
press utility. press metercount. press metercount details. press stop 0 0 stop 0 1 to access service mode in service mode look for admin initialialation function
Posted on May 22, 2008
  • 60 Answers
SOURCE: Konica Minolta C450 User Manual
http://kmbs.konicaminolta.us/content/products/models/bizhubC450.html?info=Manuals
Posted on May 27, 2008
oranous_comp
SOURCE: proplem with KONICA MINOLTA bizhub C450
c-3451
Posted on Nov 10, 2008
  • 10 Answers
SOURCE: service manual for KONICA MINOLTA Bizhub 210/162
Swithc off the machine Press stop button and hold switch on the machine. problem will go.
Good Luck
Posted on Jan 07, 2009
herminio_hal
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
0000000038572721 erroe always appear ?!! how to fixed ?
ABORT CODE!!! You need to have at Konica Minolta Tech look at that could be a main board or the firmware is corrupt
And to down load firmware is done from a secure KMBS website.
Nov 05, 2015 | Konica Minolta bizhub Pro 1051 Black Toner...
ERROR CODE 0x803C010B MINOLTA color copier
Looks more like a abort code. Might have to have the printer operating software and or main board replaced
Jan 29, 2015 | Konica Minolta magicolor 2430DL
Does anybody know how to overcome this error on a Konica Minolta c200? Also what does it mean?
Found on another site:
Re: C200 abort code 0x06006015
With abort codes a good place to start is always the MFBS board. Swap it it with a known good one and that will likely fix the problem
http://www.konicaminolta.com/
Found you a service manual:
https://www.google.com/url?sa=t&source=web&rct=j&ei=WWOSVIWYBtGvogT37IHoCg&url=http://www.manualslib.com/manual/90079/Konica-Minolta-C200.html&ved=0CCYQFjAE&usg=AFQjCNH61aztogU0Td0ShHkzwq_8fxzosA&sig2=b-NoLa6PfTCInqzptQkprw
Dec 16, 2014 | Office Equipment & Supplies
Why C-FA14 error came in C364e Model MFP?
Any of the following boards may have gone bad. This Series of codes are call abort codes. MFP, Dual Scan Image Processing Board, Memory #1 and Memory#2. Recommend you have a qualified Konica Minolta Rep look at this problem
Jun 19, 2014 | Konica Minolta Office Equipment & Supplies
Konica minolta c353 error 1 llegar operador 0x1
have a tech come out from what you stated you have a abort code need to have the firmware re flashed
Feb 15, 2014 | Konica Minolta magicolor 7450II Laser...
Abort code
contact service use go to www.konicaminolta.com
Oct 06, 2012 | Genuine Konica Minolta Konica Minolta...
Have a konica bizhub c6500 and getting error code 2861 any help please
C 2861= Gamma correction/Y aborted. Patch output voltage is high.
Possible causes: Printer control board (PRCB) Developing unit/Y
PGC sensor (PS11)
Sep 18, 2010 | Konica Minolta Office Equipment & Supplies
What does code 2454 mean on the konica minolta
Developing motor for the Black, working in conjunction with Toner Control Sensor.
Jun 08, 2009 | Konica Minolta Office Equipment & Supplies
What does this mean on my BizHub 200? !!ABORT!! CODE = 0x0000999a TASK ID = MIO-CREATE
MFBS Board, FAX Board, Memory Board*
one of the above boards or they have a connection problem. check the cable each one seperately check each one for a bent pin or worse case the board or boards are bad
Aug 16, 2008 | Minolta Office Equipment & Supplies
2,773 people viewed this question
jasbo
jasbo
