Question about Panasonic Microwave Ovens
Food is taking forever to cook in my new Panasonic inverter NN-CT870W! Had the previous one 7 yrs no problem, in new one convection seems not to get to hot enough temperature & my food is not properly cooked. Could there be a fault with it?
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave does not heat food placed in the center of the turntable. Leaves a cold spot in the middle of the food.
This is normal. That's why I always recommend to my customers that the food be placed slightly off-center on the turntable. An analogy I refer to is stirring paint: If you stir paint with a stick by simply rotating the stick in the center of the can, it's far less effective than pulling the stick around an imaginary circle halfway bewteen the center and the edge.
Posted on Sep 15, 2006
MicrowaveSvc
  • 9047 Answers
SOURCE: Panasonic Model NN T964SF inverter
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Posted on Aug 02, 2008
SOURCE: Panasonic NN-CS596S Convection Combi Steam Oven
Thanks for this. Thats exactly what I did. It didn't work at first, however, I think it was my impatience! After selecting the Microwave, you MUST wait until you are told via the screen to input the time. It now works fine. Thanks again. Just needed perseverance! Mike
Posted on Aug 18, 2008
ginko
  • 19396 Answers
SOURCE: everything runs but food does not heat up
est the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
Thediode and capacitors can br tested. The capacitor must bealloweddischarge before testing, or you risk to get electrocuted, evenifpower is off. Capacitors can get discharged by shorting theirtwocontacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
Posted on Apr 27, 2009
bestdarngood
  • 3037 Answers
SOURCE: My Panasonic Microwave Genius 1300W will not heat
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Posted on May 26, 2009
Glass turntable broken
microwave should work with out the plate as the plate turning the food is for cooking evenly for warming porpuses there should be no problem
Oct 19, 2013 | Panasonic NN-T888S Convection/Microwave...
No mater time salected only cooks for 17 seconds
i think you have a problem with your magnetron or the inverterpcb if your unit has inverter inside writen on the front it could be an expensive repair please contact me to let me know iffell up to tackling this repair as it can be dangerous
Dec 09, 2012 | Panasonic NN-T888S Convection/Microwave...
Nn-ct559 Very noisy when used on convection.
It appears you have a bad batch in that group, take it back and let them deal with this, and I would consider taking your money back or go with a different brand and model.
Mar 28, 2012 | Panasonic NN-S563 Microwave Oven
Discussion on the appearance, aesthetics, form and colur
Hello dutch.
This is an excellent microwave, over the range, white only. Here is a link to all of the features, and even the owner manual http://www2.panasonic.com/consumer-electronics/support/Home-Appliances/Microwave-Ovens/Over-the-Range-Microwaves/Technical-Specification/model.NN-S254WF.T#ts
Microwave Type: Over-the-Range Cooking Power: 1200 Watts Capacity: 2 cu. ft. Convection Cook: Without Convection Cook Dimensions Exterior Depth: 15 in. Exterior Height: 9.5 in. Exterior Width: 23.25 in. Miscellaneous Product ID: 22541798 More Information Details: Over the Range Microwave with Panasonic Inverter Technology provides true multiple power levels. When the user asks for 60% power, the oven delivers a true 60% power, not a pulsed delivery of 100% power 60% of the time. This method is called linear power delivery
Dec 08, 2010 | Panasonic NN-S254WF Microwave Oven
Panasonic NN-C980B stopped working. Blown fuse.
Sometimes when the mag shorts it takes out the inverter. I would measure the mag leads to ground and they should be open or 20M or so. If you have both a mag and inverter bad it's probably time for a new oven.
Apr 19, 2010 | Panasonic NN-C980 Convection/Microwave...
Microwave not cooking and cuts out prematurely
Hi! the problem you have stated indicates that the magnetron its not functioning, check for busted fuse.
Sep 16, 2009 | Sharp R-1510 Microwave Oven
Operates for 3 seconds on microwave then stops
It could possibly be as simple as a loose connection in that area. The repair shop your friend used may not have been Panasonic-authorized.
Sep 15, 2008 | Panasonic NN-C980 Convection/Microwave...
Microwave light door turn table works but does not heat up food
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 01, 2008 | Panasonic NN-C980 Convection/Microwave...
Panasonic Microwave NN-A770S getting hot on right side externally
If you described this to Panasonic very carefully, and they said it's normal, then I would say keep using it until such time that you get other symptoms. The inverter has some parts mounted on a large chunk of aluminum called a heat sink. It draws the heat out of the parts and the heat radiates and/or convects away. This keeps the circuit parts from overheating. As long as you have good air flow through the vents, it sounds okay.
Sep 13, 2007 | Microwave Ovens
Microwave Ovens Logo
49 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
