Question about Maytag Neptune MAH5500B Front Load Washer
Hot water fill problem
When choosing HOT termperature settings at cycle setup, washer will not fill with water. When choosing COLD settings, washer runs fine.
  • 5,911 Answers
Replace or clean your water inlet valve. It appears that the hot water solenoid has either become clogged, or had failed. You can find a replacement at Type in your COMPLETE model number in the Search window and there will be two of them located under the "Water Valve/Float" heading. Depending on WHICH type of valve you have, a replacement costs between $28 and $74. Refer to the part illustrations to make sure you are ordering the correct part. If you require assistance in accessing the inlet valve, let me know. I hope this helps you.
PS If you attempt to clean the valve, you will need to turn off the water supply and disconnect the hoses. Check the inlet screens for sediment or debris.
Posted on May 28, 2008
Hot/cold cycle stops before filling up
Your washer has a set amount of time to fill. If the flow is low and the time runs out, then all you will get is the amount of water that was able to fill. Check your lines to be sure that they all fully opened.
Aug 12, 2012 | Admiral 32 cu. ft. Washer
When set on delicate cold/cold water, it starts to fill with cold but switches to hot water after a few seconds
Sounds like you've got the hoses switched, and the cold water you're feeling is just what is in the hot water lines until the lines get purged. Try filling on the hot setting and see if cold or hot comes out; my guess is you'll get cold water on the hot setting.
Nov 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washer no longer produces cold water, only hot, except for the start of the cycle. The machine will tell me that it's not getting cold water. It doesn't matter whether I set the water temperature at...
It sounds like the fill hoses are inverted. Most of the Fisher washers only fill with cold water after the initial fill. So if the hose are inverted then it will only fill with hot. Beyond this I'm at a loss. Good luck
Apr 23, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Water continues to fill into the washer drum on the spin cycle.
You could have a stuck solenoid valve
Try this: Set the water temp on cold. Turn on only the hot water.
Does hot water try and fill the drum?
If so then there is a problem with the hot solenoid.
Next set the water on hot. Turn on only the cold water. Does cold water try and fill the drum ?
If so then there is a problem with the cold solenoid.
Jan 05, 2011 | Whirlpool LTE6234D Top Load Stacked...
Warm water filling up washer, with no hot water hooked up to wash
it will maintain 60 degrees but cycling hot cold
Sep 29, 2009 | Maytag Performa PAV2200
Washer will not fill up with hot or warm settings, only cold.
kenmore washer hot or cold fills ok but will not fill with warm but only cold water
Mar 15, 2009 | Kenmore Washing Machines
Washer tub will only fill on the hot setting
Is the tap to te cold water turned on
I would check that
Jan 13, 2007 | Maytag MAV3905EWW 13 Cycle Washer
Maytag Neptune MAH5500B Front Load Washer Logo
119 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
