FixYa.com
Tags:
Motherboards
Generic problem for all Motherboards
BACK TO MY DUAGHTERS E MACHINE
posted by ROSS125 on May 28, 2008
i took the hard drive out and hooked it up to another computer and can read the drive and see the contents but it will not allow me to move the files. It says that they are protected. I saw something about a security code on the motherboard that has to be changed to allow information to be removed from the hard drive. The power supply is good but her computer still will not run.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 29, 2008
Thanks for Trying (70)
Buschchris1
Rank:Wiz Wiz
Rating: 85%, 120 votes
Remove the BIOS battery on the motjher board and unplug it ffrom the back and wait a few minutes to reset the BIOS. Its a watch battery on the system board, little smaller than a quarter. Once this has happened it should reset the password for the bios and you can boot into the bios on start up. ( usually the DELETE Key or F1 at the splash screen. Set the password or disable it entirely and you shouldnt have that problem anymore.
You could slave the drive to another computer and go into it like another drive on your computer, copy the files you need and then re-install the windows
Rating Locked! (?) ROSS125 has rated this solution as Thanks for Trying
This Problem Also Relates To: ASUS P5PE-VM Motherboard ASUS M2N-MX Motherboard ASUS P5B Deluxe/WiFi-AP LGA775 Core 2 Duo/ P965/ A (MB-P5BDLX) Motherboard ASUS P5N-E SLI Motherboard ASUS P4XP-X Motherboard ASUS P4PE-X Motherboard ASUS A7S333 Motherboard
Can you Help with these Motherboards problems?
Intel Motherboard
bios problem
system didn't booting into cmos... Answer This...
Motherboards
manual needed for Hp 383620-001...
i need a manual for Hp system... Answer This...
Motherboards
carte mere adequat ? mon...
j'ai boitier du mdele... Answer This...
Motherboards
My camera is not working,
My LG KU990 camera is not... Answer This...
Compaq System brd w tray for Evo D510 SFF...
assistance
08/20/08 I need a modem driver... Answer This...
Repair Service
Find Motherboard Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
