GE Profile JT952 Electric Double Oven
Problem for GE Profile JT952 Electric Double Oven
GE Profile JT952 Double Wall Oven
By PJNSAM on May 28, 2008
The oven will not heat when the bake mode is used, but the broiler does work.
Same Problem
Jan 22, 2009
-   i have the exact same problem in that the oven just does not heat-   Guest
Solution #1
posted on May 28, 2008
Not Rated)
soleman13au
Rank: Wiz
Rating: 91%, 62 votes
sounds like the heater element needs replacing. But before replacing it or buying one would be a good idea to check your power point (wall socket) to make sure it is okay. Then check the oven wires to make sure there are no burnt or broken wires. Check for fuses that might have blown - some ovens do have fuses. After checking all of these you will need to check to see if you have power getting to the element. If not chances are you have a faulty switch. If you are getting power to the element chances are the element is faulty and will need replacing. Hope this helps.
Regards
Bryan
Was this helpful?
Yes
No
Popular Solutions for GE Profile JT952 Electric
Questions and Unsolved Problems for GE Profile JT952 Electric
Do you recommend GE Profile JT952 Electric Double Oven?
Answer
Answer
f7 is displayed onthe control panel i have turned off the power and turned back on after about 2min... (More)
Answer
The top oven of our GE JT950 doesn't seem to be getting hot enough. I set the temperature to 350,... (More)
Answer
Both GE JT950 ovens heat VERY slowly. All functions appear to work on my JT950, but both ovens heat... (More)
Answer
please need spanish manual jt952?30″ double wall oven double wall oven
Answer
I have removed my electric wall oven and cooktop and am replacing them with used westinghouse... (More)
Describe your Ovens problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Oven Experts
Top Range & Oven Repairmen
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
(410) 609-0006
A Leader In Kitchen Equipment Sales,...
Allegro Restaurant Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
