Question about APC (BE500U-WEB) (BE500UWEB) UPS System
I have APC be500 ups, it is not taking input, but it is working from battery mode. what coul'd be the problem in main board.
    New Friend:
  • 56 Answers
Going down the line. Does it have power? Do you use the powershoot program? Plug in the cable to the unit and what does current status say? if it says nothing, you probably dont have power or the unit is toast. If it says the line voltage is low or high, check it and if its really ok, there a number of parts that check the line and using another unit will probably tell which one. APC wont sell you parts or a schematic. So if you are not a excellant tech, send it in for about 40 bucks to get it refurbed or by a new one.
Posted on Jan 11, 2013
  • 37 Answers
SOURCE: 650 APC UPS
try to change with new battery and test. if it does't work it could be the hardware is malfuntion. but that the lastsolution to think, what are the indicator light is stated? can u descibe more detail on the ups. so i can able to asst u?
Posted on Mar 30, 2009
  • 12 Answers
SOURCE: Apc ups legwerkin
You can also adjust the sensitivity of your UPS so that it will accept the Generator's supply. I had to set ours to low sensitivity to get them to work. Depending on your UPS model, you can either connect to it with the supplied USB cable and run powerchute software to set the sensitivity to low, or some models allow you to adjust sensitivity on the front panel. Good Luck!
Posted on Jul 01, 2009
SOURCE: smart apc ups error with all indicator flashing .
APC Smart-UPS 1500VA has an error. All it's pannel lights blinking. what is the best possible solution to this?
Posted on Aug 26, 2010
epettingill
  • 175 Answers
SOURCE: APC UPS is totely deat.
You have to take apart the UPS. Inside you will find a battery. On the battery you will find the make and model of the battery. Buy a new battery install it. Plug in UPS and turn it on.
Posted on Oct 21, 2011
epettingill
  • 175 Answers
SOURCE: low output voltage in apc ups cs500
is that 165 Volts AC or DC? Try to reset the logic. Unplug the UPS from the wall and disconnect the batteries. Push the "On Button" The LED's may flash. This is resetting the logic. This migh help. This should be 120VAC in and 120VAC out. Please give me an update.
Posted on Oct 31, 2011
How can output voltage be adjusted when on battery power?
1. check either it is overloaded or the batteries are weak . check battery voltage to
May 10, 2014 | APC 620VA/390W Input 230V/Output 230V...
Apc hi800sq
follow this steps and fix it. God bless you
Plug the battery backup into a working electrical outlet. If the battery backup turns on when the power button is pressed, then the problem may be that the previous electrical outlet is faulty. Proceed to step three. If the battery backup doesn't turn on, proceed to step two.
  • 2 Reset the circuit breaker on the battery backup. APC battery backups have a labeled circuit breaker button located on the unit near the phone line, fax line, USB, network and coaxial cable inputs. Press the button to reset the circuit breaker. Power on the battery backup by pressing the power button. If the battery backup powers on, proceed to step three. If the battery backup doesn't turn on, proceed to step six.
  • Read more: http://www.ehow.com/how_7266444_troubleshoot-apc-battery-backup.html#ixzz2lwOvPO75
  • 3 Determine if the battery backup is charged and providing battery power. With the battery backup on and plugged into a working electrical outlet, plug a computer monitor into one of the battery backup outlets labeled "battery backup plus surge protection" on the battery backup. (APC power supplies have some outlets that provide only surge protection while the other outlets provide surge protection plus battery backup.) Turn the monitor on. Unplug the battery backup power cord from the wall outlet. If the monitor remains on, the battery is holding a charge, supplying electrical power and the battery backup is working properly. If the monitor goes off, proceed to step four.
  • 4 Charge the battery. Plug the battery backup into an electrical outlet and allow the battery to charge for 16 hours. This will fully charge the battery.
  • 5 Test battery charge. Once the battery is fully charged, repeat step three. If the monitor stays on when power is interrupted to the battery backup, the issue is solved and the problem resulted from an incompletely charged battery. If the monitor turns off when power is interrupted, the battery within the battery backup is faulty and needs to be replaced.
  • 6 Replace the battery backup unit. The unit itself is faulty. If the battery backup is under warranty, contact APC to request a replacement.
  • Nov 28, 2013 | Computers & Internet
    APC BACK-UPS ES 500VA fails to provide back up during power failure
    Get APC Powerchute Personal Edition for free and run it. If it says your battery isnt charged, check its voltage disconnected. Charge it with a car battery charger and see if its still a good battery. If not , replace it. If the battery is good, then check the charging voltage. Should be about 14 volts. if not, check the small transformer on the main board. Should be 120 in and 17 to 18 out. 4 diodes in a bridge for charge. The input to the transf has small fuse into it alone.
    Jan 04, 2013 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
    My ups cannot power on
    For BE500 the switch is a common problem, try to check the switch first, then the battery.
    Nov 22, 2012 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
    APC SUVT 20 kVA power-up on batteries but not on mains
    Dear If UPS working on MAINs but just not wakeup on MAINs then only 3 capasitors need to change.. for further you can diractelly contact @ techdata41@gmail.com
    Nov 21, 2012 | APC Computers & Internet
    APC Smart UPS system tripps mains electricity when i connect. Please help
    UPS MOV is blown, change MOV or input filter circuit. or better send it to APC authorized service center.
    Nov 23, 2011 | APC Matrix-UPS 5000 UPS System
    APC SmartUPS 3000VA
    APC do not release cct diags and these are not easy to repair, if the battery fuse was open and there is some board damage, the thing is toast. Even if you get it going the battery will not be able to be calibrated, unless there the board/processor is 100%, I know this as we have a similar model on the bench right now with new batts in and the unit will not recalibrate, so even though the batts are new, as soon as the mains is dropped it goes to very low battery and shuts down in 2 mins.
    Buy a new UPS save yourself a lot of time. Hope this helps
    Thanks for using FixYA
    Aug 02, 2010 | APC Smart-UPS 3000VA UPS System
    APC Smart-UPS 1000VA UPS System calibation problem
    If battery charge indicator is flashing it should be UPS calibration issue, If all the LED indicator is light up in the front panel and UPS still can go online on battery mode you just need to replace the board on the front panel and the light will just back to normal state.
    Apr 25, 2009 | APC Smart-UPS 1000VA UPS System
    APC BR800 Overload light with beeps
    Your main control board is defective, you need a new unit.
    Dec 19, 2008 | APC (br800) UPS System
    MY BLACK COLORS ARE RED
    steenson
    To be honest with you. Do not waste your time change the main input board, your problem is solved. Because the main input board coul be defective. I can help you get the input board. Please, my e-mail Stevebuy31@hotmail.com
    Dec 10, 2008 | Akai PDP4225M 42 in. Plasma Television
    APC (BE500U-WEB) (BE500UWEB) UPS System Logo
    178 people viewed this question
    Top APC Computers & Internet Experts
    Jax Planet
    Jax Planet
    Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
