Question about Gateway 7405GX Notebook
Reformmattin my notebook
I have a gateway notebook model m460 with windows xp it is running so slow that someone told me to reformat it the problem is it did'nt come with a disk to do it with how do i go about doing this
Or just use the easy way....¬_¬ press f10 when loading the laptop up lmfao whats the need for all the complecation you pillock
Posted on Jun 09, 2008
    Problem Solver:
  • 10 Answers
Several ways to do this first see if theres a recovery partion check my computer if u see a second local drive thats usauly it check the gateway web site to see instruction on how to enter it , if not get yourself an xp sp 2 cd and download the drivers from gateway for your machine before you do this or make sure you have a second internet machine u can down load on and burn or usb drive! when rebooting the machine enter the bios make sure the cd is first boot device save exit reboot with cd make sure you format first always read carefully and make sure u understand before you hit next next next..... but heres a link for it anyway...http://support.gateway.com/s/Manuals/Mobile/8510799.pdf
Posted on May 28, 2008
Cannot connect to wifi on gateway notebook laptop
check your drivers, run diognostic on windows, check windows update etc
Nov 19, 2014 | Gateway M460/ma1 Laptop/notebook 15"...
How do format a hard drive in gateway m460
You had better know what your going before you do this as it will erase the operating system too, making the disk unusable until you install the operating system again. Call Tiger Direct and buy an internal HDD adapter cable... it has a USB plug on one end and will allow ANOTHER PC to read it like a Flashdrive. Remove the HDD for our PC and connect the adapter. Using the other PC, format each directory separately, usually there are two: a C: and D:. You can also extract all the data files you have stored on the HDD BEFORE you reformat it. If you don't see files on the old HDD, use the START... type in "cmd"... then the old HDD name as listed in the other PC, for example, if it's Q:, use the command "CHG DIR Q:\" This will change to that HDD. Type in "TYPE DIR/W/P and all the directories should show up. If it's blank, you have a bad HDD and reformatting it won't help you. Buy a new HDD from Tiger Direct, at least 500GB at the fast spool speed. Have you original Genuine Windows CD-Rom ready and the key code and install it in your good HDD.
Jul 01, 2014 | Gateway Computers & Internet
Set my Gateway back to Factory Settings
If the factory restore partition has been wiped or partition removed you are not going to get it back that was wiped to zero's.
Jan 17, 2014 | Gateway 1 Ma1 M460 Laptop 1.7ghz 40gb...
Is the gateway 5412 the same as m460
No, they are different, but may share some components.
Dec 31, 2012 | Gateway M460 Notebook
Hardware graphics accelerator
you will need to go to the computer manufacturers website, look up the model number and download drivers.
Look for drivers specific to your computer, and it will be listed as Intel video. what is the model and who is the manufacturer?
Oct 04, 2017 | Gateway M460 Notebook
Acer Veriton m460 keeps rebooting running windows xp pro. Ran e-recovery now the system will not start in windows. just says error press any key to continue. when you press a key it just keeps coming back...
try booting in safe mode. then scan for possible virus. then restart and login in (not in safe mode). if it still wont work, reformat the drive then do the fresh installation of windows.
Apr 11, 2010 | Computers & Internet
How do I reset my gateway notebook its stuck on the gateway screen?
Hello gibraltarsio,
You can hold down the power button of your Gateway notebook until it shuts itself down.
You can turn it back on & you can go to safe mode. You need to continuously press F8 before you see the Windows screen.
This should let you choose if you want to go to Safe Mode.
Once you're on Safe Mode, you may need to back up important files as there may be a virus that has attacked some vital Windows component like a Rundll file that let's your notebook boot to normal mode.
After that you can reformat your notebook just for good measure.
Check this out, here's a step by step guide in doing a reformat,
http://helpdesk.its.uiowa.edu/windows/instructions/reformat.htm
Once you're finished reformatting your notebook, you may want to disable your Autorun feature so as to prevent exe files to run by themselves w/o you knowing it.
If you're using Windows XP, you can do this.
Click on the Start Menu button, click on run & type "gpedit.msc".
Once you see a window pop up, click on Admin Templates then on the right hand side, double click on Systems.
Find Turn off Autoplay & choose Enable.
On the drop down, choose All drives. Click on apply & ok then you should be all set.
Hope this helps.
Art Pena
Tech Support
Nov 23, 2009 | Gateway ML6732 Notebook
Gateway 7405GX Notebook Logo
42 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
