Question about Kitchen Ranges
I just brought my ps3 from the U.S to pakistan and set it up and all.Hooked it up to an old sharp t.v temporarily .Setup all the power supply even an adapter to convert 220 to 110V.but when i turned it on the red light would turn into green for a second and then turn red again making a few beeps.And when i try holding the power buttons infront after a few tries it turns on for like 5seconds but then turns off.and after every 20seconds it makes these beeping sounds which makes the lights on the wireless controller also blink.I really need some help with this.
  • 30 Answers
El problema puede ser su adatador de 220 a 110 pruevelo primero con un toma para 110 y revise con voltimetro si es de 110 v porque puede ser que no este funcionando del todo bien y si no prueve solo el play3 solo y si enciende problema resuelto es adatador
Posted on Oct 05, 2010
Hi, I hooked up a ps3 to my Daewoo DTQ-27U4SC tv and it wouldn't work. From what I understand, all I do is hook up the power to the ps3 and hook up the RCA cables between the ps3 and tv. I hooked up...
if the ps3 is set to hdmi it will not work threw the av cables. you need to change the settings on the ps3 to use av cable. its mostly set to hdmi as factory setup .
Jun 22, 2017 | Daewoo DTQ-27U4SC 27" TV
Hi, i brought Orange? Nokia 6303 mobile set from UK and now I want to use this set in Pakistan but in Pakistan this set wanted Restricted code. Please help me. Faisal Bilal
Go according to the following steps. Please take into account that the restricted code does not depend on your location or area but might depend on the SIM you are using.
follow these steps
(1)Change your SIM to another company's SIM and try to use your phone.
(2) If the phone still asks for restricted code than it is obvious that the settings of the phone is disturbed.
(3) You must be having a pin whole in your mobile phone. Insert something sharp in it like a tooth pick, needle or a common pin. This will reset your mobile phone.
(4) In case when you change the SIM if you get access go to settings of the mobile and change them removing the restricted code.
Good Luck!
Sep 15, 2010 | Computers & Internet
Mfc 6490 shutdown
Fuse blow?? I wish its not over voltage until the board inside the printer malfunction. If it still under warranty, you better send it BEFORE the warranty end. Maybe you cannot use it temporarily but at least within warranty period you can use it.
May 14, 2010 | Brother MFC 6490CW InkJet Printer
How to put playstation where it will show on a regular TV that does not have HD my son took his playstation over his friends who had a HD TV when he brought it back home and hooked it on same TV they had...
With the ps3 already on standby, hold the standby button with the television on the correct channel until the display shows, it will take quite some time. Then change your setup accordingly.
Feb 26, 2010 | Sony Playstation 3 (PS3) Console
I have my 80 gb PS3 hooked up to my STR-DH800. I
You may need to enter the setup menu on the PS3 and enable the decoding for blu-ray discs.
Dec 13, 2009 | Sony STR-DH800
European PS3 HDMI stopped working and AV video is very messed up
Try holding down the power button down for about 10 seconds (until you hear another beep) when powering on. reset video output and just set it up again. this is a diagnostic screen that most people dont know about
Nov 04, 2009 | Sony Playstation 3 (PS3) Console
Powers on but nothing happens
It happened to me too. When you plug in your av cables and are ready to play, follow these steps. With your PS3 off (Red light on), Press and hold the power button on your console. (Do not use the controller to turn it on.) Keep holding the button until you hear a second beep. (it takes about 2 to 3 seconds.) You will notice your screen flickers, then your PS3 will show up on the tv. All you did was reset the PS3 display settings. You can always go back to HDMI or AV cables. Have Fun.
Mar 07, 2009 | Sony Playstation 3 (PS3) Console
This Sucks!!!!
Try this. Shut your PS3 off to stand by mode (when the red light is just on). Hold the power button down for a few seconds (the button on the front, not the back). This will reset the PS3 display settings back to default (480i in North America or 480p in Europe). Then go to the menu (XMB) to "Display Settings" and select your HDMI settings from there. This should do it.
Sep 14, 2008 | Sony Playstation 3 (PS3) Console
Ps3 setup
Plug the PS3 in as normal, turn on the console from the machine not from the controller, and hold the button for about 10secs. The PS3 will come on and then restart itself. Once it has restarted it will use its native resolution and you should be able to see it fine.
Apr 03, 2008 | Sony Playstation 3 (PS3) Console
Ps3 unit stopped working
when on standby hold the power button for 4 seconds, it runs the optimal settings screen, i dont think this is your prob but it might help. What cable was used at your neighbours? was it an hdmi cable? did you knock your ps3 when moving it?
Feb 13, 2008 | Sony Playstation 3 (PS3) Console
Kitchen Ranges Logo
105 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
