Question about Acer Aspire 3003WLCi Notebook
Dll error I get an error msg: load needed dlls for hal
    Champion:
  • 207 Answers
Lots of tech t/s is needed in this case ill suggest to go for recovery..
Posted on May 28, 2008
Iam getting an error which says "Reload needed DLLs for HAL"
Try these: Do a system Restore: http://pcsupport.about.com/od/fixtheproblem/ht/systemrestorecp.htm < that will show you how
Restore hal.dll from XP CD (or w/e operating system you have) http://pcsupport.about.com/od/fixtheproblem/ht/restorehaldll.htm
Those are the ways that i typically fix the error. If they both fail, you probably need to reinstall your operating system.
Mar 01, 2011 | Dell Optiplex GX280 Intel Desktop PC -...
Unable bootup & error prompt that HAL.dll file missing or corrupt
CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location. Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
Resolution
  1. Restart the PC. The hal.dll error could be a fluke.
  2. Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
    Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
  3. Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
  4. Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
    Note: If repairing the boot.ini does correct the hal.dll issue but the problem reappears after a reboot and you've recently installed Internet Explorer 8 in Windows XP, uninstall IE8. In this specific situation, IE8 could be the root cause of your hal.dll problem.
Nov 09, 2010 | Acer Aspire 4720 Notebook
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
The file <windows root>\system32\hal.dll.
Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the hal.dll error.
Recover data from any bad sectors on your hard drive. If the physical part of your hard drive that stores any part of the hal.dll file has been damaged, you're likely to see errors like this.
Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
Note: While this will almost certainly resolve any hal.dll errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
Feb 15, 2010 | Dell Latitude E5500 Laptop
Windows system 32 hal.dll error after restoring e-machine
There's actually a number of reasons why these annoying little DLL errors happen, but the most common, is caused when new programs are installed over all old ones and the old ones are not completely uninstalled 100%, causing registry pile ups and of course, getting a .DLL error messages.
Another reason, is damage that's been done by malware/spyware/adware programs, attaching themselves to your PC and wrecking havoc, deleting crucial DLL files from your PC.
The hal.dll file is created during install from 5 other dlls. HAL is the Hardware Abstraction Layer and it's the interface between the system drivers and the actual hardware.
Copying hal.dll will not resolve the problem.
A lot of times the file will be reported missing due to corruption of the boot sector or of the file system
Causes of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll file or a hal.dll file that has been deleted or moved from its intended location.
Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged HDD.
Suggested remodies-
5. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the hal.dll error.
6. Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
7. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
8. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
Important: If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
9. Replace the hard drive. Finally, if all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
10. Perform a new installation of Windows XP after installing the new hard drive.
I have not tried it - but HERE is a free program purporting to fix the error.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Apr 10, 2009 | E-Machines eMachines Desktop PC
Lode needed dlls for kernel
Use the ERD disk and repair the installation. Choose to replace all files, and then replace only the Hal.dll and Ntoskrnl.exe files.
If you can start another installation of Windows NT on the same computer, you can expand the correct Hal.dll and Ntoskrnl.exe files from the Windows NT CD-ROM. To do so, follow these steps:
  1. Boot to the working version of Windows NT.
  2. Start a command prompt.
  3. Change to the CD-ROM drive.
  4. Change to the appropriate folder on the CD-ROM (for example, I386 for Intel-based computers).
  5. Type expand hal.dl_ <systemroot>\system32 where <systemroot> is the path of the non-functioning Windows NT folder.
  6. Type expand ntoskrnl.ex_ <systemroot>\system32.
  7. Restart the computer into the other Windows NT installation.
Mar 27, 2009 | Microsoft Windows XP Professional
Dll error
This is an operating system error. You will need to run a system repair or reload with your recovery or operating system disc. Start with a repair, if the repair doesn't fix it, then reformat and reinstall the operating system. If you have any issues or problems during the format or reload, then your hard drive has failed and will need to be replaced.
Jul 20, 2008 | Toshiba Satellite A75-S231 Notebook
Power went outot two error messages:
hal.dll is not good, you need to boot from the windows xp cd and select "Install windows" then select "Repair windows installation"
Jun 10, 2008 | Computers & Internet
Aspire 5100 problem
You can disable this msg through msconfig or you can restore the os through system tools, if msg is again comming then try to edit the regestry & delete the entry(you can try all this).
Feb 13, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 3003WLCi Notebook Logo
48 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
