Question about Fisher and Paykel GWL11 Top Load Washer
Water filling in squirts then fault codes 10000011
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.The error number you have is 131.This error is called REPETITIVE ROTOR POSITION SENSOR ERROR.This means the wiring to the rotor sensor or the rotor sensor or the control module is faulty.Unfortunately to test the rotor sensor you need an RPS tester.I can help you test the wiring but without an RPS tester you can not test the rotor sensor easily. The rotor sensor is underneath the machine attached to your motor.Please reply on how you would like to proceed and I will help you as much as I can.Looking forward to your reply.
Posted on Oct 05, 2010
Maytag msd2758ges ice maker squirts water
Sounds like the water solenoid is not shutting off cause once the tray fills it should stop sending water located in the back bottom with the water lines connected
Mar 24, 2013 | Maytag MSD2756GES Side by Side...
What is error 240 on a Fisher & Paykel IntuitiveEco IWL16 Top Load Washer
240. (11110000) Phase 6 - Hall Out of Order. RPS Fault
Same as previous Hall Error faults, just an extra fault code for Phase
6. See fault codes 130 and 131 for directions.
130. (10000010) Phase 1 to 6 - Single Rotor Position
Sensor Error
The Motor Control Module has found an error in the pattern received
from the Rotor Position Sensor. Likely causes of this fault are a bad
connection on the harness between the Rotor Position Sensor and the
Motor Control Module, or a faulty Rotor Position Sensor.
Primary Source: Wiring.
Action: 1. Check for corrosion on the edge connector of
the Rotor Position Sensor and the Motor
Control Module connector.
2. Check the contacts on the rotor positional
sensor end of the hall harness to see if any
have been damaged. (Each set of contacts in
the socket has two wipers. If the distance
between these wipers varies between
different contacts, replace the rotor positional
sensor harness.)
Secondary Source: Rotor Position Sensor.
Action: Check the Rotor Position Sensor with an R.P.S.
tester. Replace if faulty.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
131. (10000011) Phase 1 to 6 - Repetitive Rotor Position
Sensor Error
This fault is similar to fault number 130 above but differs slightly in that
it is a continuous condition.
Oct 02, 2012 | Fisher and Paykel IWL12 Top Load Washer
I have a fault code on off off off off off on on
That is fault code 131
Sensor Error
it is a continuous condition. See fault 130 for service procedure.
Sensor Error
sensor harness.)
Sep 17, 2012 | Fisher and Paykel Washing Machines
Fisher and Paykel Smartdrive washing machine won't fill up
Your fault code is 131,RPS faulty.
130. (10000010) Phase 1 to 6 Single Rotor Position Sensor Error
The Motor Controller has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness
between the Rotor Position Sensor and the Motor Controller, or a faulty Rotor
Position Sensor.
Action:
1) Check for corrosion on the edge connector of the Rotor Position Sensor and
the Motor Controller module connector.
2) Check the contacts on the rotor positional sensor end of the hall harness to
see if any have been damaged. (Each set of contacts in the socket has two
wipers. If the distance between these wipers varies between different
contacts, replace the rotor positional sensor harness).
Action:
Check the Rotor Position Sensor with an R.P.S. tester. Replace if faulty.
Tertiary Source: Motor Controller module.
Action:
Replace Motor Controller module.
131. (10000011) Phase 1 to 6 - Repetitive Rotor Position Sensor Error
This fault is similar to fault number 130 above but differs slightly in that it is a
continuous condition. See fault code 130 for service procedure
Mar 20, 2012 | Fisher and Paykel Washing Machines
Fill water squirts out "vents" at top and even
replace the valve rubber at the top of the inlet control
Sep 06, 2017 | Kohler Toilet - One Piece with Ingenium...
When you start the washer to fill,the water doesn't squirt continuously into the machine,it squirts on and off for a couple of seconds,then covers the bottom of the agitator,stops and starts beeping,lights...
Hi Linda just read your posting.Sorry to ask you this but could you confirm the lights that are lit when it is beeping.On the wash progress row of lights, starting from the left to right which ones are on?Is it the 2nd and 4th or the 3rd and 7th ---etc----?Please reply with additional information and I can help you rectify this fault.
Jul 09, 2010 | Washing Machines
Water squirts from tank while filling
Take lid off and check that the fill tube is in place. If so flush with lid off to see were the water is squirting from, be prepared to clean up water...If you can, do a slight flush. If there is water coming from any where but the bottom of fill valve and the fill tube you may need to replace the fill valve. In my experience, the fill tube is dissconected.
For Diagram
http://www.askmehelpdesk.com/attachments/plumbing/19906d1242687133-shut-off-valve-under-toilet-doesnt-work-fluidmaster-20ballcock.gif
Jul 06, 2010 | Kohler K-3386-0 Rialto one-piece...
Washing Machine starts, squirts water, then stops.
E5E  IS FOR  Communication problem. THERE IS 100 %WIRE SHORTING SOMEWHERE.PLEASE CHECK OUT.
ALSO OTHER ERRORS Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 To much soap.
Nov 12, 2008 | Frigidaire GLTF2940ES Front Load Washer
Bosch
f is fill fault to much or not enough water or water in the sump white plastic base the f code will not go away until you solve the problem when the f code shows up the drain motor will run all of the time
Apr 01, 2006 | Bosch 24 in. SHU6802UC / SHU6806UC...
Fisher and Paykel GWL11 Top Load Washer Logo
364 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
