Question about Brother Office Equipment & Supplies
The error light is flashing red and I am unable to print.
  • 3,530 Answers
Try to reset the printer by turning it off, removing the plug, let it sit for 5 mins ans plug it back again.
By the way, what is the model of the printer?
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on Oct 05, 2010
Red light on on my Buffalo HD
Red ERROR LED The way the unit gives diagnostic codes is by long and short flashes of the specific light. The number of long flashes give the first of two numbers and the number of short flashes give the second. For instance, one long flash and three short flashes would indicate an error of 13 -
E 00
(No light, beep only) - MPU error E 01 DRAM data line error E 02 DRAM address line error E 03 RTC chip error E 04 Flash rom error E 10 UPS power loss E 11 fan error (RPM too low or not functional) E 12 cooling error (unable to remove heat by the fan) E 15 disk error E 16 unable to locate internal HDD E 17 Unable to communicate with the RTC chip E 21 unable to communicate with the Phy chip E 22 mount error. The original Buffalo firmware has the following error messages based on the number of flashes:
3 Partition problem with hard drive. Reformat the hard drive. 4 Fan problem. 5 ROM problem. 6 Hard Drive can not be recognized. 7 Problem with motherboard (RAM, LAN, or Hard Drive controller). Exerted from http://buffalo.nas-central.org/wiki/Information/LSProLED
I hope this has been helpful, unfortunately without more information I cannot help any further.
Jul 20, 2011 | Buffalo Technology (USA), INC. - 500GB...
We have the E260d. What does it mean when the light bulb flashes. We are unable to print. What can we do?
You can unplug the printer from the wall, then leave it off for about 30 seconds then plug it back in. That should reset the printer, if not read what the message says on the screen, or you may have to navigate through the settings to see the error message.
Jun 29, 2011 | Lexmark C533DN InkJet Printer
Print unable 4F
nandkjwatson,
Good day!red light flashing causes some problems on your printer.Like empty inks,no paper,hardware error.Be sure to check all ink cartridges if its full and if all chips are good.Be sure to have paper loaded.
Regards,
Mastergani
Jul 06, 2010 | Brother DCP 130C All-In-One InkJet Printer
Printer status screen is red and will not print Canon i560 Inkjet
You need to count the number of flashes, usually long green then a certain number of flashes, sometimes alternating red and green flashes. I need to know the number of flashes to tell you what the error is.
Jun 18, 2009 | Canon BubbleJet i560 InkJet Printer
Kyocera Ecosys FS 920
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
Flashing light
Here is what HP has on the subject of the triangle light flashing:
c00028322.gif 1 - Attention Light 2 - Ready Light 3 - Go Light Figure 2: Printer light key c00028323.gif 1 - Symbol for light off 2 - Symbol for light on 3 - Symbol for light blinking
c00028328.gif Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Figure 8: Paper jam c00028328.gif 13.JJ.NT JAM IN TRAY 1
13.JJ.NT JAM IN TRAY X
The Attention LED is blinking. Check paper loading then open and close top cover.
When there is a jam in tray 1, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored.
When there is a jam in tray X, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored. These are the error explanations for just the flashing triangle light, there are many more, but none for just the flashing triangle.
If the light pattern is different let me know (other lights on as well)
-Hope this helps.
May 28, 2008 | HP LaserJet 1012 Printer
Error light and no printing
What does the status monitor message say? The red light is the most general error. It's bit like taking a 747 back to Boeing and saying there is something wrong with it.
If you do not have the status monitor installed, download it from Konica Minolta and run it. Once the status monitor is running it will read the error from the printer.
Sep 05, 2007 | Konica Minolta magicolor 2300DL Laser...
LIGHT FLASSING CANT PRINT
Error 50: Purge cam problem. mfc/dcp has to be taken to service. No chance to fix it by yourself. sorry!
Mar 29, 2007 | Brother MFC 210C All-In-One InkJet Printer
57 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
