Question about HP Officejet 5610 All-In-One InkJet Printer
This morning when I switch on the printer it tells me there is a cartridge error. Yesterday it was still working. I can't do anything with the printer not even using the setup functions. It blinks all the time cartridge error! Why is that?
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
You need to replace one or both cartridge if you have the old ones check to find out which one couse the error and you can replace it with a new one or refill the old like this
Posted on Oct 30, 2010
My Lexmark x8350 has suddenly come up with Cartridge Error, Error #1203. I've followed all the remove cartridge, power off, power on, reinstall steps, but no good. I think it's the colour...
Hi Alan I think it is the cartridge that is causing your issue but I cant promise that it is.I can tell you from many years experience it very rarely is an issue with the printer breaking it is 99% of the time inferior consumables causing printers to fail, and sometimes wrecking printers so even when the customer does use good consumables it is too late and the damage is done, but we can't be sure of anything unless we start with basics and get 100% brand new Original Equipment Manufacturers carts (OEM) and stick them in. (no I don't work for Lexmark;)
Oct 31, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
We are using HP Officejet J3608 All-in-One printer. One week back we have replaced the cartridges, till yesterday it was working fine. but today morning when i switched on the printer it is showing...
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken. Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using Fixya
Sep 20, 2011 | Office Equipment & Supplies
I just got my new printer Canon Pixma MX420 yesterday. When I turn on the printer, the error 5100 occurs. The scree of the pritner askes me to see the manual, but I can find the solution page. I dont know...
Hello and Welcome to FixYa!
If you are facing Error 5100 then it means that the cartridge can not be detected by the printer.
Actually when the printer is not actually load the cartridge it shows error 5100
To solve this error follow the given steps:-
First of all turn off printer and remove both the cartridges from the printer, Now use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches, Return the cartridges and turn on the printer.Error will be removed.
Let me know If you have any more Confusion, questions or issue regarding your problem
I hope this solution helps you. Thank you for using FixYa!
Aug 20, 2011 | Canon Pixma MX420 All-In-One Printer
Xerox c2424 fault code 37,008.44:54093
There are two things. I most likely suspect that the print head wiper blade has stuck to the print head. Very common problem after a power failure.
Not sure how I didnt see your post before now. But if your still having that problem let me know, I can tell you how to fix it.
Mar 04, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
Cartridge error, refer to device documentation for troubleshoot
show me a massage Cartridge error, refer to device documentation for troubleshoot printer model hp officejet 5610 all -in- one what is the problem and how do i solve thnk you
May 22, 2009 | HP Officejet 4315 All-in-One Printer
Won't print gives error message above power and function push button incorrect color cartridge installed---was working fine yesterday no cartridge was done...
uninstall and reinstall printer and make sure u follow the promp and put the right cartridge in the right spot....black and color....2 different chambers
Apr 19, 2009 | HP PSC 750 All-In-One InkJet Printer
Service required error
Try unplugging it for an hour first.
Thanks,
Lee
Jun 18, 2008 | Epson Stylus Pro 4800 Color Photo Printer...
Changing cartridges
I just turned on my hp psc 750 and an error message appeared. Incorrect black cartridge installed
I just used it yesterday, what is wrong???
Nov 06, 2007 | HP PSC 750 All-In-One InkJet Printer
Cartridge error
I switched my cartridges, color in black and vice versa, then printed test page then switched them back and they worked fine.
Oct 24, 2007 | Dell A940 All-In-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
90 people viewed this question
Seeker5211
Seeker5211
