Question about Philips Televison & Video
I am using 20GX8350/94R philips color tv since 14 years. Till now it is working well. But recently, when the power switch is on, the red LED flashes on the control panel. If we switch off and on a few times, then it is working normally. When the humidity is more in climate, this problem happens. Kindly suggest the solution.
    Problem Solver:
  • 17 Answers
Resolder all the loose part
Posted on Oct 05, 2010
No picture only sound.
Engineers are right, you need a new LED panel., or the component that supplies the light to the screen.
Mar 18, 2016 | Philips 55pfl4706df7 4000 Series Lcd...
The tv suddenly goes black and the power light blinks red
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
https://www.youtube.com/watch?v=TR2iWN6b-LY LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 12, 2015 | LG 37-inch Led-lcd Tv - 1080p 60hz Hdtv...
Philips Magnavox Plasma TV went off.
The red LED merely indicates that power is getting to your TV. There may have been a power supply failure, especially since your TV is a 2008 model
Jun 28, 2013 | Philips Magnavox 42MF521D/37 Television
Green LED always on, power switch has no effect
if using a box or receiver in line with the set unplug those as well. I assume the red light on the set is not coming on or a light is blinking?
Dec 18, 2012 | Sony Grand WEGA KDF-50WE655 50" Rear...
Philips LED 40PFL9704. Switches off before completing the warming up stage.
Sounds like shipping damage---maybe the display panel got damaged.
May 30, 2012 | Philips Televison & Video
TV went out, then came back on. Colors way off, no red .This is an LED tv. can it be repaired, or not?. What is the average years of use, with this type of Tv?
Yes,but it could be the incomming broadcasting cable itself,it the cause?Take another tv,test it out with that incomming broadcasting cable,see,if that tv also lost the red color?Yes,than the LED tv have a bad tv Tuner signal board,replaced this incomming tv Tuner signal board,will solved this problems.The average years are 9-10 years,with average of used like 10 hours a day.That how long the LED screen panel will last,but the electronic PCB boards circuitries are a difference story.Those parts on the PCB boards circuittries could last for a couple years are less.
pC
Nov 30, 2010 | Samsung 61" Slim-Depth LED DLP HDTV
We have just recently repositioned our Philips Model No. 42PFL7422D/37 Flat Screen TV and thought we had written down the proper wiring set up for connecting to Charter Communications etc. Is there any...
CHARTER BOX
3 CABLES
YELLOW - VIDEO
RED - R. AUDIO CHANNEL
WHITE - LEFT AUDIO CHANNEL
Hook them up to tv's INPUT of the same colors
Then turn tv to input or av channel.
Mar 31, 2010 | Philips 32PF7421D 32 in. LCD HDTV
Polaroid pla-4248 red color only in right lower side of screen, found 14 amp fuse blown on panel on right side,did not solve the problem
Looks like Y-Sustain board fails .First of all there is no 14 A.fuse used on this tv. and replase with the same Amperace.If you use bigger Amp, it could damage the power board
Jul 31, 2009 | Philips 50PF9630A 50 in. Plasma Television
Philips 29PT9418/69G
A qualified tech will need to practice visual acuity technique! Look at power supply circuit for signs of stress,dis-coloration and/or bad connects.Check for bad 47mf/25v cap in area of stress.Replace BC-327-25 xistor w/BC-328 and replace BC-337-25 w/BC-338,if present in your set's chassis style.
Sep 25, 2007 | Philips 25PS40S 25" TV
Televison & Video Logo
106 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
