Question about Kenwood KM800 Major Classic Stand Mixer
The sealing of the crank case - can I use silicone or should I use a gasket
Oil came from my mixer
You have a bad gasket in your mixer, the oil inside from KA is 6 oz. and the oil is due to separation, as KA uses a food safe vegetable based grease and after periods of non use it separates, liquids from solids, and leaks when the gasket seal goes. It is a messy fix but fairly easy, ereplacmentparts.com has a video on it. hope this helped
Feb 16, 2013 | KitchenAid KITCHEN AID 5 Quart Artisan...
My kitchen aid mixer is leaking oil
This seems to be a fairly common problem. If you are handy you can replace the transmission case gasket yourself. (Take pictures as you dissassemble it) and expect to get greasy. The website http://www.mendingshed.com/mixergasket.html has the gasket for the 4.5 and 5 quart model. You did not specify what you have. The gasket is only $3.50 plus S&H. They also have a downloadable PDF service manual which is very helpful. Good Luck!
Dec 22, 2010 | KitchenAid Food Mixers
Leaking oil around head
These mixers are filled with grease at the manufacturer, and the heat may have broken down the grease a bit and looking like oil. Without seeing the problem, or knowing the exact location of the leak, I would say that a gasket or "O" ring has failed. Contact Kitchenaid for a gasket/seal rebuild kit. If it is new(er), It may be covered under warranty.
Dec 22, 2010 | KitchenAid KSM103 Professional 5 Series...
Oil leak
instead of putting a gasket on tell him to take out all of the old grease out that is what has broken down and turning into oil causing a leak and if he can repace the seal around the agitator shaft replace the old grease with a high temp bearing grease or a good quality lithium grease
May 25, 2010 | Hobart A200 Stand Mixer
Oil leak
Hi, W3HAL ? How much oil are we talking about, and over what period? How old is your machine? Your KA mixer?s internal gears are factory packed with enough grease to last a 'lifetime' (whatever that means). Depending on the age of your mixer, where it was stored (warm temps possibly?) and how long it's been idle and/or how heavily it?s been used; these factors all will eventually cause grease?s base oil to separate from its additives, with the resultant oil seeping from openings beyond the gasket down the agitator shaft. Gravity can be very insidious. The inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case, try KSM90P, and select one of the files listed under Parts List (check to see it this matches your mixer model). Turn to pages 4 & 5, titled ?Case, Gearing and Planetary Unit?, which provides and exploded view for the disassembly and reassembly of your mixer, along with all the parts. Your transmission case gasket is Illus. # 18, which you might want to reorder for starters. Once apart you can check for any other unseemly wear and tear on the gears, etc. It can be messy but gratifying. As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com. Prices for the same part can vary widely between vendors, so do your comparison shopping. Finally, here's a link to an excellent site that details the disassembly and replacement of a mixer's grease, which might be helpful, too. http://www.foodonthefood.com/food_on_the_food/2009/04/how-to-repair-a-kitchenaid-mixer-yourself.html Good luck and have fun. I hope this helps. Howard, Burke, VA If this solution has helped you, please rate it, thanks! - hslincoln
Nov 30, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
My Kitchenaid Artisan Mixer is leaking oil or grease
Your kitchenaid mixer is meant to leak a tiny amount of oil around the rim of the planetary gear on the front of the machine. This is just a means of lubrication. If however you are getting alot of oil coming out of the sides of the unit, the transmission gasket may be worn or broken if this is the case it will have to be replaced. part number for the gasket is 4162324. If your getting alot of oil from the center of the unit this could indicate worn or broken seals. there are 4 located inside the unit, and would need to be dismantled in order to replace. part number for all four is 3180163. If you are leaking alot of oil or grease continued use of the mixer might cause it damage. Hope this helps
Thanks
Nov 03, 2009 | KitchenAid KSM150PS Artisan Series Stand...
K45ss mixer works fine except when whipping cream there are small black specs appearing in the bowl that probably have gone unnoticed with darker mixtures. I suspect some type of oil leak
Yes this is probably a oil leak. it can come from two possible location one of which can come from the transmission gasket that goes around the mixers center seem, if this is broken, worn or improperly seated it will need replacement. part number for the transmission gasket is 4162324. another possible location is around the cirrcular mixing gear at the front of the machine. if the seal inside the unit are damaged or worn this can cause oil to leak striaght down into the very food you are preparing. part number for the seals are 3180163. there are 4 of them, and they would require taking apart the whole unit. hope this helps.
Thanks
Sep 27, 2009 | KitchenAid K45SS Classic Stand Mixer
BMW door seal?
make sure you have the new one on hand also the glue you can pick up the glue at a local autoparts store. Now lay the new door seal out in the sun while you are taking the out one off so that its warm and stretches easy, once the old one is off clean the railing that holds the gasket with rubbing alcohol on a rag, then apply the glue as you put on the gasket
May 30, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Oil is leaking
The sealed bearing are probably leaking. They will need to be changed. Or, clean the unit well before using and wait for the bearing to start to freeze up, then get it fixed. Might work for a long time with weaping bearings.
Apr 30, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Kenwood KM800 Major Classic Stand Mixer Logo
18 people viewed this question
Top Kenwood Food Mixers Experts
ashburton
Treefrog15
Treefrog15
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
